Question. I'm looking at the portal and I see my Actinic channel running at 64 % and my Daylight channel running at 40%. In my code I have it set to ReefCrest 50,10 so I assumed, maybe incorrectly, that the mode starts at 50% and will flucuate +- 10% - so a minimum of 40 to a max of 60. I'm seeing it has high as 70% so wanted to see if I am understanding this or maybe something is over riding it. The portal shows the correct ReefCrest settings on the DC Pump graph.
if (hour()>=22 || hour()<8)
// Sleep mode - slow things down
ReefAngel.DCPump.SetMode( ReefCrest,40,10 );
else if (hour()>=8 && hour()<22){
ReefAngel.DCPump.SetMode( ReefCrest,50,10 );
ReefCrest DC Pump power question
Re: ReefCrest DC Pump power question
The DCPump class defines +/- 20 for ReefCrest and +/-10 for Lagoon.
It's hard coded.
The 10 in your code is the duration between change of speed.
It's hard coded.
saf1
Thanks. I didn't know that. Dumb follow up question but is a lower or higher duration between change of speed good?
I've been using a few different random patterns trying to adjust the flow a bit. I have a couple rose bubble tips that are starting to move around whereas before they didn't. I think part of the issue is the flow so I wanted to control it a bit more and I don't remember what the ReefCrest pattern looks like.
Duration would impact how often you want the speed to change.
Reefcrest and lagoon are both random patterns.
saf1
Thanks Rimai. Learn something new everyday
