ReefAngel.WaterLevelATO(Port1,180,95,100);
ReefAngel.WaterLevelATO(1,Port1,180,95,100);
ReefAngel.WaterLevelATO(99,Port1,180,95,100);
Any suggestions?
// Updated 1/16/2018
ReefAngel.AddMultiChannelWaterLevelExpansion(); // Multi-Channel Water Level Expanion Module
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
// Custom Labels
ReefAngel.CustomLabels[0]="ATO";
ReefAngel.CustomLabels[1]="Heater";
ReefAngel.CustomLabels[2]="Skimmer";
ReefAngel.CustomLabels[3]="Wave Maker";
ReefAngel.CustomLabels[4]="Fan";
ReefAngel.CustomLabels[5]="Fuge Light";
ReefAngel.CustomLabels[6]="N/A";
ReefAngel.CustomLabels[7]="Return Pump";
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.DCPump.Threshold=30;
// ReefAngel.SingleATO( true,Port1,180,2 );
ReefAngel.StandardFan( Port5,770,850 );
ReefAngel.StandardLights( Port6,21,0,6,0 ); // Refugium Light
ReefAngel.DCPump.DaylightChannel = AntiSync;
if (hour()>=9 && hour()<11) // From 9am - 11am run a sine wave
ReefAngel.DCPump.SetMode(Sine,50,75,5);
else if (hour()>=14 && (hour()<=16 && minute()>=30) ) // From 2pm-4:30pm run NutrientTransport
ReefAngel.DCPump.SetMode(NutrientTransport,50,80,34);
else if (hour()>=19 || hour()<9) // From 7pm to 9am run Lagoon
ReefAngel.DCPump.SetMode(Lagoon,45,10);
else // Otherwise use what's in the memory
ReefAngel.Portal( "jetskiman98" );
ReefAngel.DDNS( "173.61.18.251" ); // Your DDNS is --------
Every time I've loaded the code and restarted the level has been above the minimum. In this case 95%. If I'm understanding correctly, the relay shouldn't open until the level hits 95% or lower. The last time I did it, the level was at 97% and instantly the ATO turned on.rimai wrote:Does it raise the level above 100% before the timeout?
