Ok Roberto
I did some testing. For all tests, I used only RA * with Multi-Water Level directly connected through an Expansion Port. Everything else was disconnected.
I used the same lean code:
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.AddMultiChannelWaterLevelExpansion();
ReefAngel.Network.Cloud();
The result was this table below:
None of the tests gave an accurate result. I really have some problem.
As I already said, I am using this Multi-Water level for 2 years with RA+ untill last weekend when my RA* arrived and I decided to migrate.
May be something (or not) but very often when calibrating, I get 0 from the reading, and have to start all over again.
best regards
Rafa
