ATO Not working
PostPosted: Sun Feb 04, 2018 6:47 am
for some reason my ato is not functioning. When i operate it through the app it works fine but it will not come on automatically when my float is low.
    ReefAngel.OverheatShutoffPorts = Port4Bit | Port6Bit;
    InternalMemory.OverheatTemp_write( 835 );
    ReefAngel.Relay.DelayedOn( Port2,8 );
    ReefAngel.StandardLights( Port3,19,0,10,0 );
    ReefAngel.StandardLights( Port4,14,0,20,0 );
    ReefAngel.StandardHeater( Port6,790,800 );
    ReefAngel.SingleATO( true,Port7,180,0 );
PostPosted: Mon Feb 05, 2018 1:26 pm
Did you test the port and float switch?
Do you have it connected too the correct ato port?
PostPosted: Mon Feb 05, 2018 8:53 pm
Yes,
When the float is activated, it shows on the app that it is in the low position. But the pump relay dos not activate.
PostPosted: Mon Feb 05, 2018 10:09 pm
Strange.
Everything looks fine.
Can you try the High ATO port?
PostPosted: Tue Feb 06, 2018 3:59 pm
i switched the port that the float was plugged into and the ATO high indicated red when the float was floated. Is that good enough for a test?
should i try the other float? I cannot see how that would help though i am kind of grasping at straws. I was really hoping you would find a flaw in the code.
Is there another way to write the ATO line to see if maybe a slightly different syntax would work?
PostPosted: Tue Feb 06, 2018 4:27 pm
So, do you see it turning both red and green as you move the float switches up and down?
I want to make sure both float switches are working and both ports are also working.
since i am grasping at straws, i also noticed that my portal seems to think i have a whole second relay box. I do not have one or any other expansion at this time and i did not include it in my code (i used the wizard to make it). I cannot figure out why it has the 8 extra slots when i bring up the portal though.
Maybe this is a clue???
PostPosted: Tue Feb 06, 2018 4:36 pm
I tested my other float and it seems to work. I feel a bit silly but i reconfirmed all of my previous statements. I tested the float i am having issues with and it checks out. But the other float actually works
PostPosted: Tue Feb 06, 2018 10:16 pm
And you are positive that it is not on ato timeout, right?
Try this code:
ReefAngel.Relay.Set(Port7,ReefAngel.LowATO.IsActive());
PostPosted: Thu Feb 08, 2018 5:36 am
it is not in time out, it is working with the other float now
Return to Ask anything here
