Lee's Feature Complete PDE
PostPosted: Fri Jun 17, 2016 8:46 am
Just posted my latest code. Did a lot of improvement to the CheckATO function that measures the rate of evaporation by keeping a rolling 12 hour average of the % drop in my ATO reservoir. I did this so I can better set alerts if my ATO is either not dropping as expected or is dropping too fast.
PostPosted: Sun Jul 10, 2016 5:17 pm
I've been trying to adapt your code to my setup and am getting a "'class ReefAngelClass' has no member named 'LCD'" error in the validation process. Is this related to the NokiaLCD.h? I'm not sure how to continue from this point.
Edit: reinstalled arduino software and it seems to be fine now.
PostPosted: Mon Jul 11, 2016 1:52 pm
OK, new stumbling block. I have two lights with two channels each (SBReef 16"). I have channel 11 running the actinics and 12 running the whites off of the relay dimming ports. I'm not sure how to make the changes to adapt your code that uses the dimming expansion to the relay box dimming outputs that I'm using (getting a 'class RA_PWMClass' has no member named 'Channel11PWMSlope' error). Can you point me in the right direction?
#include <SunLocation.h>
        #define Mem_I_Latitude        108
        #define Mem_I_Longitude       110
        #define Mem_B_AcclRiseOffset  112
        #define Mem_B_AcclSetOffset   113
        #define Mem_B_AcclDay         114
        #define Mem_B_LightMode       160
        #define Mem_B_LightOffset     161
        #define Mem_I_RiseOffset      162
        #define Mem_I_SetOffset       164
        #define Mem_B_AcclActinicOffset     166
        #define Mem_B_AcclDaylightOffset    167
        #define Mem_B_LightsOffPerc   171
        #define Mem_B_EnableStorm     178
        #define Mem_B_PrintDebug      198
        #define Mem_B_ResetMemory     199
        void init_memory() {
          InternalMemory.write_int(Mem_I_Latitude,21);
          InternalMemory.write_int(Mem_I_Longitude,-73);
          InternalMemory.write(Mem_B_AcclRiseOffset,4);
          InternalMemory.write(Mem_B_AcclSetOffset,2);
          InternalMemory.write(Mem_B_AcclDay,0);
          InternalMemory.write(Mem_B_LightOffset,20);
          InternalMemory.write(Mem_B_LightMode,1);
          InternalMemory.write_int(Mem_I_RiseOffset,-1);
          InternalMemory.write_int(Mem_I_SetOffset,-1);
          InternalMemory.write(Mem_B_AcclActinicOffset,100);
          InternalMemory.write(Mem_B_AcclDaylightOffset,100);
          InternalMemory.write(Mem_B_LightsOffPerc,1);
          InternalMemory.write(Mem_B_EnableStorm,true);
          InternalMemory.write(Mem_B_ResetMemory,false);
    // Define Relay Ports by Name
    #define Skimmer            1
    #define Heater             2
    #define Reactor            3
    #define Refugium           4
    #define Daylight           5
    #define Actinic            6
    #define Return             7
    #define ATO                8
    #define Wave 1             Box1_Port1
    #define Wave 2             Box1_Port2
    #define Unused             Box1_Port3
    #define Unused             Box1_Port4
    #define Unused             Box1_Port5
    #define Unused             Box1_Port6
    #define Unused             Box1_Port7
    #define Utility            Box1_Port8
    // Custom classes
    SunLocation sun;
   // For Cloud and preset code
int DaylightPWMValue=0;
int ActinicPWMValue=0;
int DaylightPWMValue0=0;        // For cloud code, channel 0
int DaylightPWMValue2=0;        // For cloud code, chennel 2
int ActinicPWMValue1=0;        // For cloud code, channel 0
int ActinicPWMValue3=0;        // For cloud code, chennel 2
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit;
ReefAngel.LightsOnPortsE[0] = Port3Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port2,796,798 );
ReefAngel.StandardLights( Port4,18,0,12,0 ); // Refugium light
ReefAngel.StandardATO( Port8,1200 );
ReefAngel.Wavemaker( Box1_Port1,60 );
ReefAngel.Relay.Set( Box1_Port2, !ReefAngel.Relay.Status( Box1_Port1 ) );
     // Lighting and Flow
          SetSun();               // Setup Sun rise/set lighting
          AcclimateLED();         // Apply acclimation dimming
          LEDPresets();
          CheckCloud();           //  Check for cloud and lightning.
          UpdateLED();
ReefAngel.Portal("madweazl");
        void SetSun() {
          // Start acclimation routine
          int acclRiseOffset=InternalMemory.read(Mem_B_AcclRiseOffset)*60;
          int acclSetOffset=InternalMemory.read(Mem_B_AcclSetOffset)*60;
          byte acclDay=InternalMemory.read(Mem_B_AcclDay);
          // See if we are acclimating corals and decrease the countdown each day
          static boolean acclCounterReady=false;
          if (now()%SECS_PER_DAY!=0) acclCounterReady=true;
          if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) {
            acclDay--;
            InternalMemory.write(Mem_B_AcclDay,acclDay);
          // End acclimation
          // Add some customizable offsets
          sun.Init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
          int riseOffset=InternalMemory.read_int(Mem_I_RiseOffset);
          int setOffset=InternalMemory.read_int(Mem_I_SetOffset);
          sun.SetOffset(riseOffset,(acclDay*acclRiseOffset),setOffset,(-acclDay*acclSetOffset)); // Bahamas
          sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
          byte lightOffset=InternalMemory.read(Mem_B_LightOffset); // left right separation
          byte actinicOffset=InternalMemory.ActinicOffset_read();
          // Make sure light resets to zero at night.
          for(int i=0;i<4;i++) { ReefAngel.PWM.SetChannel(i,0); }
          switch(InternalMemory.read(Mem_B_LightMode)) {
            case 0: {
              // Daylights
              ReefAngel.PWM.Channel11PWMSlope(lightOffset,0);
              // Actinics
              ReefAngel.PWM.Channel12PWMSlope(actinicOffset+lightOffset,actinicOffset);
              break;
            case 1: {
              // Daylights
              ReefAngel.PWM.Channel11PWMParabola(lightOffset,0);
              // Actinics
              ReefAngel.PWM.Channel12PWMParabola(actinicOffset+lightOffset,actinicOffset);
              break;
          case 2: {
              // Daylights
              ReefAngel.PWM.Channel11PWMSmoothRamp(lightOffset,0);
              // Actinics
              ReefAngel.PWM.Channel12PWMSmoothRamp(actinicOffset+lightOffset,actinicOffset);
              break;
          case 3: {
              // Daylights
              ReefAngel.PWM.Channel11PWMSigmoid(lightOffset,0);
              // Actinics
              ReefAngel.PWM.Channel12PWMSigmoid(actinicOffset+lightOffset,actinicOffset);
              break;
          case 4: { // Reverse the actinics in the morning
              // Daylights
              ReefAngel.PWM.Channel11PWMParabola(lightOffset+actinicOffset,0);
              // Actinics
              ReefAngel.PWM.Channel12PWMParabola(lightOffset,actinicOffset);
              break;
        void AcclimateLED() {
          if (acclDay > 0) {
            float acclActinicOffset=acclDay*(40.95*(((float)InternalMemory.read(Mem_B_AcclActinicOffset)/100)));
            float acclDaylightOffset=acclDay*(40.95*((float)InternalMemory.read(Mem_B_AcclDaylightOffset)/100));
            float endPerc;
            endPerc=40.95*InternalMemory.PWMSlopeEnd1_read();
            ReefAngel.PWM.SetChannelRaw(1,map(ReefAngel.PWM.GetChannelValueRaw(1),0,endPerc,0,endPerc-acclActinicOffset));
            endPerc=40.95*InternalMemory.PWMSlopeEnd3_read();
            ReefAngel.PWM.SetChannelRaw(3,map(ReefAngel.PWM.GetChannelValueRaw(3),0,endPerc,0,endPerc-acclActinicOffset));
            endPerc=40.95*InternalMemory.PWMSlopeEnd0_read();
            ReefAngel.PWM.SetChannelRaw(0,map(ReefAngel.PWM.GetChannelValueRaw(0),0,endPerc,0,endPerc-acclDaylightOffset));
            endPerc=40.95*InternalMemory.PWMSlopeEnd2_read();
            ReefAngel.PWM.SetChannelRaw(2,map(ReefAngel.PWM.GetChannelValueRaw(2),0,endPerc,0,endPerc-acclDaylightOffset));
        #define LED_1to1  Box1_Port1
        #define LED_4to1  Box1_Port2
        #define LED_3to1  Box1_Port3
        #define LED_2to1  Box1_Port4
        #define LED_BLUE  Box1_Port5
        #define LED_WHITE Box1_Port6
        #define LED_STORM Box1_Port8
        void resetRelayBox(byte ID) {
          // toggle all relays except for the one selected
          for (int i=Box1_Port1;i<=Box1_Port4;i++) {
            if (i!=ID) ReefAngel.Relay.Auto(i);
        void LEDPresets() {
          static byte lastPreset=0;
          DaylightPWMValue0=ReefAngel.PWM.GetChannelValueRaw(0);
          ActinicPWMValue1=ReefAngel.PWM.GetChannelValueRaw(1);
          DaylightPWMValue2=ReefAngel.PWM.GetChannelValueRaw(2);
          ActinicPWMValue3=ReefAngel.PWM.GetChannelValueRaw(3);
          DaylightPWMValue=ReefAngel.PWM.GetDaylightValueRaw();
          ActinicPWMValue=ReefAngel.PWM.GetActinicValueRaw();
          if (ReefAngel.Relay.isMaskOn(LED_1to1)) {
            if (lastPreset!=1) resetRelayBox(LED_1to1);
            DaylightPWMValue0=90*40.95;
            ActinicPWMValue1=10*40.95;
            DaylightPWMValue2=90*40.95;
            ActinicPWMValue3=10*40.95;
            lastPreset=1;
          if (ReefAngel.Relay.isMaskOff(LED_1to1)) {
            if (lastPreset!=2) resetRelayBox(LED_1to1);
            DaylightPWMValue0=10*40.95;
            ActinicPWMValue1=90*40.95;
            DaylightPWMValue2=10*40.95;
            ActinicPWMValue3=90*40.95;
            lastPreset=2;
          if (ReefAngel.Relay.isMaskOn(LED_2to1)) {
            if (lastPreset!=3) resetRelayBox(LED_2to1);
            DaylightPWMValue0=60*40.95;
            ActinicPWMValue1=40*40.95;
            DaylightPWMValue2=60*40.95;
            ActinicPWMValue3=40*40.95;
            lastPreset=3;
          if (ReefAngel.Relay.isMaskOff(LED_2to1)) {
            if (lastPreset!=4) resetRelayBox(LED_2to1);
            DaylightPWMValue0=40*40.95;
            ActinicPWMValue1=60*40.95;
            DaylightPWMValue2=40*40.95;
            ActinicPWMValue3=60*40.95;
            lastPreset=4;
          if (ReefAngel.Relay.isMaskOn(LED_3to1)) {
            if (lastPreset!=5) resetRelayBox(LED_3to1);
            DaylightPWMValue0=75*40.95;
            ActinicPWMValue1=25*40.95;
            DaylightPWMValue2=75*40.95;
            ActinicPWMValue3=25*40.95;
            lastPreset=5;
          if (ReefAngel.Relay.isMaskOff(LED_3to1)) {
            if (lastPreset!=6) resetRelayBox(LED_3to1);
            DaylightPWMValue0=25*40.95;
            ActinicPWMValue1=75*40.95;
            DaylightPWMValue2=25*40.95;
            ActinicPWMValue3=75*40.95;
            lastPreset=6;
          if (ReefAngel.Relay.isMaskOn(LED_4to1)) {
            if (lastPreset!=7) resetRelayBox(LED_4to1);
            DaylightPWMValue0=80*40.95;
            ActinicPWMValue1=20*40.95;
            DaylightPWMValue2=80*40.95;
            ActinicPWMValue3=20*40.95;
            lastPreset=7;
          if (ReefAngel.Relay.isMaskOff(LED_4to1)) {
            if (lastPreset!=8) resetRelayBox(LED_4to1);
            DaylightPWMValue0=20*40.95;
            ActinicPWMValue1=80*40.95;
            DaylightPWMValue2=20*40.95;
            ActinicPWMValue3=80*40.95;
            lastPreset=8;
          if (ReefAngel.Relay.isMaskOn(LED_BLUE)) {
            if (lastPreset!=9) resetRelayBox(LED_BLUE);
            lastPreset=9;
          if (ReefAngel.Relay.isMaskOff(LED_BLUE)) {
            if (lastPreset!=10) resetRelayBox(LED_BLUE);
            ActinicPWMValue1=0;
            ActinicPWMValue3=0;
            lastPreset=10;
          if (ReefAngel.Relay.isMaskOn(LED_WHITE)) {
            if (lastPreset!=11) resetRelayBox(LED_WHITE);
            ActinicPWMValue1=0;
            ActinicPWMValue3=0;
            lastPreset=11;
          if (ReefAngel.Relay.isMaskOff(LED_WHITE)) {
            if (lastPreset!=12) resetRelayBox(LED_WHITE);
            lastPreset=12;
        // Write updated values to the channels
        void UpdateLED() {
          ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);
          ReefAngel.PWM.SetChannelRaw(1,ActinicPWMValue1);
          ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);
          ReefAngel.PWM.SetChannelRaw(3,ActinicPWMValue3);
          ReefAngel.PWM.SetDaylightRaw(DaylightPWMValue);
          ReefAngel.PWM.SetActinicRaw(ActinicPWMValue);
          byte LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
          if (ReefAngel.PWM.GetChannelValueRaw(0)>=LightsOffPerc) ReefAngel.Relay.On(Daylight); else ReefAngel.Relay.Off(Daylight);
          if (ReefAngel.PWM.GetChannelValueRaw(1)>=LightsOffPerc) ReefAngel.Relay.On(Actinic); else ReefAngel.Relay.Off(Actinic);
          if (ReefAngel.PWM.GetChannelValueRaw(2)>=LightsOffPerc) ReefAngel.Relay.On(Daylight); else ReefAngel.Relay.Off(Daylight);
          if (ReefAngel.PWM.GetChannelValueRaw(3)>=LightsOffPerc) ReefAngel.Relay.On(Actinic); else ReefAngel.Relay.Off(Actinic);
        // Menu Code
        void MenuEntry1() {
          ReefAngel.FeedingModeStart();
        void MenuEntry2() {
        void MenuEntry3() {
          ReefAngel.ATOClear();
        void MenuEntry4() {
          ReefAngel.OverheatClear();
        void MenuEntry5() {
          ReefAngel.SetupCalibratePH();
        void MenuEntry6() {
          ReefAngel.SetupDateTime();
         void CheckCloud()
            #define Clouds_Every_X_Days 1
              // Minimum number of minutes for cloud duration.  Don't use max duration of less than 6
            #define Min_Cloud_Duration 7
            #define Max_Cloud_Duration 7
            #define Min_Clouds_per_Day 1
            #define Max_Clouds_per_Day 2
            #define Start_Cloud_After NumMins(12,00)
            #define End_Cloud_Before NumMins(21,00)
              // Add Random Lightning modes
            #define Calm 0    // No lightning
            #define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
            #define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
            #define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
            #define Mega2 4   // Like Mega, but with more lightning
              // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
              // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
              byte LightningModes[] = {Mega2,Mega,Mega};
              static byte cloudchance=255;
              static byte cloudduration=0;
              static int cloudstart=0;
              static byte numclouds=0;
              static byte cloudindex=0;
              static int LastNumMins=0;
              static byte lightningMode=0;
              static time_t DelayCounter=millis();    // Variable for lightning timing.
              static int DelayTime=random(1000);      // Variable for lightning timimg.
            #ifdef forcecloudcalculation
              if (cloudchance==255)
            #else
            #endif
                  randomSeed(millis());    // Seed the random number generator
                  cloudchance=random(100);
                  // If we have cloud today
                  if (cloudchance)
                    lightningchance=random(100);
              if (cloudchance)
                //is it time for cloud yet?
                  DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
                  if (chooseLightning)
                    chooseLightning=false;
                  switch (lightningMode)
                  case Calm:
                    break;
                  case Mega:
                    // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                      // Send the trigger
                      Strike();
                      DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
                      DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
                    break;
                  case Mega2:
                    // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
                      Strike();
                    break;
                  case Fast:
                      Strike();
                    break;
                  case Slow:
                    // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
                      else lightningstatus=0;
                      if (lightningstatus)
                        DaylightPWMValue=4095;
                        DaylightPWMValue=0;
                      delay(1);
                    break;
                  default:
                    break;
                  cloudindex++;
                  if (cloudindex < numclouds)
                /*ReefAngel.LCD.Clear(255,0,120,132,132);
                 ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
                  int x=0;
                  else x=17;
                  //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
                  else x=35;
                  //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
                //ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
                ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
                if (lightningchance)
                  int x=0;
                  else x=57;
                  //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
                  ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
                  else x=75;
                  //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
            void Strike()
              int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
              for (int i=0; i<a; i++)
                // Flash on
                int newdata=4095;
                Wire.beginTransmission(0x40);      // Address of the dimming expansion module
                Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
                Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
                Wire.write(newdata>>8);            // This sends the MSB
                Wire.endTransmission();
                Wire.write(0x8+(4*2));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
                int randy=random(20,80);    // Random number for a delay
                if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
                delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
                // Flash off.  Return to baseline.
                newdata=ReefAngel.PWM.GetChannelValueRaw(0);   // Use the channel number you're flashing here
                Wire.beginTransmission(0x40);    // Same as above
                delay(random(30,50));                // Wait from 30 to 49 ms
                wdt_reset();    // Reset watchdog timer to avoid re-boots
              cstart*=60;
              cend*=60;
PostPosted: Mon Jul 11, 2016 7:25 pm
If you have Channel 11 and 12 then I'm guessing you have a custom 16 channel module?
If so then the correct function to use instead of:
Use:
ReefAngel.PWM.SIXTEENChannelPWMSlope(11, 0, 100, 60, lightOffset, 0); // Channel / Start % / End % / Duration / PreOffset / PostOffset
There's no function to call this from direct memory
PostPosted: Tue Jul 12, 2016 4:42 am
lnevo wrote:If you have Channel 11 and 12 then I'm guessing you have a custom 16 channel module?
Use:
No 16ch module, just the original relay box (channel 11 and 12 in the manual). I believe you call them with "actinic" and "daylight" based on the standard code but I wasnt positive on how to tackle that.
Would ReefAngel.PWM.SetActinic( PWMSlope(10, 10, 60, lightOffset, 0) ); work? My lights only dim to 10%.
PostPosted: Fri Feb 09, 2018 6:17 pm
I had a question regarding the setRF() class in Lee's complete PDE. IIRC, this class is suppose to go into NTM mode after a feeding mode, and then back to the mode that it was in prior to being put into feeding mode? I wasn't able to tell where the code puts it back the original mode prior to feeding was enabled.
Tim
PostPosted: Sat Feb 10, 2018 8:30 pm
vtMode is being set at the top of the function by reading the InternalMemory variables for these settings. Then once the delay is set, then it get's picked up by the if and gets set to SmartNTM which finally get's written with RF.SetMode at the end of the function.
PostPosted: Mon Feb 12, 2018 11:09 am
Okay cool. Thanks lnevo for clearing that up for me. I thought that once it set the vtMode to NTM in the if statement I didn't see anywhere in the function that would reset it back to a previous setting.
Tim
Previous
Return to My PDE/INO file
