Cloud Wifi Hub compile error
Loose
Post by Loose »
I'm starting the initial setup of my Cloud Wifi hub using the Wizard.
I'm getting the following error when trying to compile the generated code:
Compiling code for RA_CLOUD board
Extra Temperature Probes
D:\Arduino\libraries\PubSubClient\PubSubClient.cpp:9:21: fatal error: avr/wdt.h: No such file or directory
#include
compilation terminated.
exit status 1
Progress: 55.17%
Your code has some errors and couldn't be compiled.
Please fix the errors above and try again.
Wizard generated code:
#include <SPI.h>
#include <WiFi101.h>
#include <PubSubClient.h>
#include <RA_CustomSettings.h>
#include <CloudGlobals.h>
// Change fallback ports below
// Fallback ports will be turned on when cloud connection is lost
// Add each port separated by a |
// For example, if you would like for port 1 and port 5 of Relay Box 1 to be turned on when cloud connection is lost,
// you should add Port1Bit | Port5Bit
// It would look like this:
// #define Relay1FallBack Port1Bit | Port5Bit
#define Relay1FallBack 0
#define Relay2FallBack 0
#define Relay3FallBack 0
#define Relay4FallBack 0
#define Relay5FallBack 0
#define Relay6FallBack 0
#define Relay7FallBack 0
#define Relay8FallBack 0
// Redirect expansion modules to another custom expansion field.
// This is only required if you have multiple modules of the same parameter.
// For example, if you have one Cloud module with an existing salinity module already and wants to add another Cloud module
// with anoter salinity module and report those readings as a Custom Expansion Module 1
// In this case you have to change the CloudCustomModule1 to CUSTOM_SALINITY.
// The values that can be entered are:
// CUSTOM_NONE	0
// CUSTOM_SALINITY	1
// CUSTOM_ORP	2
// CUSTOM_PHEXP	3
// CUSTOM_WL	4
// CUSTOM_MULTI_WL1	5
// CUSTOM_MULTI_WL2	6
// CUSTOM_MULTI_WL3	7
// CUSTOM_MULTI_WL4	8
#define CloudCustomModule1  CUSTOM_NONE
#define CloudCustomModule2  CUSTOM_NONE
#define CloudCustomModule3  CUSTOM_NONE
#define CloudCustomModule4  CUSTOM_NONE
#define CloudCustomModule5  CUSTOM_NONE
#define CloudCustomModule6  CUSTOM_NONE
#define CloudCustomModule7  CUSTOM_NONE
#define CloudCustomModule8  CUSTOM_NONE
// Assign Temperature probes ID
// Only assign temperature probes IDs that you currently are not using in the head unit.
// If you have a total of more than 3 probes, make sure to add the following line on the setup section of the head unit code:
// ReefAngel.AddExtraTempProbes();
// For example, if you only have 1 probe connected to the head unit, assign IDs 2 and 3.
// If you have 2 probes in the head unit and 2 probes in the Cloud Wifi Hub, you must add the above line and you would assign
// IDs 3 and 4.
// Assign ID 0 to unused probes in the Hub.
byte TempProbeIDs[] = {2, 0};
// Do not change anything below
#define LED_GREEN 7
#define LED_BLUE 6
#define LED_RED 0
#define TempPin 5
unsigned long wifi_connection = millis();
int status = WL_IDLE_STATUS;
byte data[2];
byte data2[12];
byte addr[8];
byte addr1[8];
byte addr2[8];
OneWire  ds(TempPin);
void MQTTSubCallback(char* topic, byte* payload, unsigned int length);
PubSubClient MQTTClient(MQTTServer, MQTTPORT, MQTTSubCallback, mqttclient);
  pinMode(LED_GREEN, OUTPUT);
  pinMode(LED_BLUE, OUTPUT);
  pinMode(LED_RED, OUTPUT);
  digitalWrite(LED_GREEN, HIGH);
  digitalWrite(LED_BLUE, LOW);
  digitalWrite(LED_RED, LOW);
  wdt_initialize();
  wdt_enable();
  randomSeed(analogRead(0));
  Serial.begin(57600);
  Serial.setTimeout(100);
  delay(1500);
  Serial.println("Init");
  Wire.begin();
  FoundIP = false;
  MQTTReconnectmillis = millis();
  MQTTSendmillis = millis();
  SalinityFound = false;
  ORPFound = false;
  PHExpFound = false;
  WLFound = false;
  MultiWLFound = false;
  HumidityFound = false;
  sprintf(pub_salinity, "sal");
  sprintf(pub_orp, "orp");
  sprintf(pub_phexp, "phe");
  sprintf(pub_wl, "wl");
  sprintf(pub_multiwl, "wl");
  sprintf(pub_humidity, "hum");
  // Temperature
  byte count = 0;
  while (ds.search(addr))
    if (addr[0] == 0x28)
      count++;
      if (count == 1) memcpy(addr1, addr, 8);
      if (count == 2) memcpy(addr2, addr, 8);
  ds.reset_search();
  Serial.print(count);
  Serial.println(" temperature probe(s) found");
  // Relay
  for ( byte EID = 0; EID < MAX_RELAY_EXPANSION_MODULES; EID++ )
    RelayDataE[EID] = 0;
    RelayMaskOnE[EID] = 0;
    RelayMaskOffE[EID] = 0xff;
  RelayFallBackE[0] = Relay1FallBack;
  RelayFallBackE[1] = Relay2FallBack;
  RelayFallBackE[2] = Relay3FallBack;
  RelayFallBackE[3] = Relay4FallBack;
  RelayFallBackE[4] = Relay5FallBack;
  RelayFallBackE[5] = Relay6FallBack;
  RelayFallBackE[6] = Relay7FallBack;
  RelayFallBackE[7] = Relay8FallBack;
  // Dimming
  lastcrc = -1;
  for ( byte a = 0; a < PWM_EXPANSION_CHANNELS; a++ )
    ExpansionChannel[a] = 0;
    ExpansionChannelOverride[a] = 255;
  // IO
  Params.IO = 63;
  OldParams.IO = 63;
  // Leak
  Params.Leak = 0;
  OldParams.Leak = 0;
  // ORP
  Params.ORP = 0;
  OldParams.ORP = 0;
  ORPCal = false;
  ORPMin = memory_read_int(Mem_I_ORPMin);
  if (ORPMin==65535) ORPMin=0;
  ORPMax = memory_read_int(Mem_I_ORPMax);
  // Salinity
  Params.Salinity = 0;
  OldParams.Salinity = 0;
  SalCal = false;
  SalMax = memory_read_int(Mem_I_SalMax);
  // pH Exp
  Params.PHExp = 0;
  OldParams.PHExp = 0;
  PHExpCal = false;
  PHExpMin = memory_read_int(Mem_I_PHExpMin);
  if (PHExpMin==65535) PHExpMin=0;
  PHExpMax = memory_read_int(Mem_I_PHExpMax);
  // Humidity
  Params.Humidity = 0;
  OldParams.Humidity = 0;
  // Water Level
  for (int a = 0; a < WL_CHANNELS; a++)
    Params.WL[a] = 0;
    OldParams.WL[a] = 0;
    WLCal[a] = false;
  WLMin[0] = memory_read_int(Mem_I_WaterLevelMin);
  WLMax[0] = memory_read_int(Mem_I_WaterLevelMax);
  WLMin[1] = memory_read_int(Mem_I_WaterLevel1Min);
  WLMax[1] = memory_read_int(Mem_I_WaterLevel1Max);
  WLMin[2] = memory_read_int(Mem_I_WaterLevel2Min);
  WLMax[2] = memory_read_int(Mem_I_WaterLevel2Max);
  WLMin[3] = memory_read_int(Mem_I_WaterLevel3Min);
  WLMax[3] = memory_read_int(Mem_I_WaterLevel3Max);
  WLMin[4] = memory_read_int(Mem_I_WaterLevel4Min);
  WLMax[4] = memory_read_int(Mem_I_WaterLevel4Max);
  for (int a=0; a<5; a++)
    if (WLMin[a]==65535) WLMin[a]=0;
  ApplyCalibration(1, CloudCustomModule1);
  ApplyCalibration(2, CloudCustomModule2);
  ApplyCalibration(3, CloudCustomModule3);
  ApplyCalibration(4, CloudCustomModule4);
  ApplyCalibration(5, CloudCustomModule5);
  ApplyCalibration(6, CloudCustomModule6);
  ApplyCalibration(7, CloudCustomModule7);
  ApplyCalibration(8, CloudCustomModule8);
  sprintf(clientid, "%s%02d", CLOUD_USERNAME, random(10000));
  sprintf(pub_buffer, "%s/in", CLOUD_USERNAME);
  sprintf(sub_buffer, "%s/out/#", CLOUD_USERNAME);
  Serial.println("Start");
  wdt_reset();
  status = WiFi.status();
  while ( status != WL_CONNECTED) {
    if (millis() - wifi_connection > 1000)
      Serial.print("Attempting to connect to Network named: ");
      Serial.println(WIFI_SSID);                   // print the network name (SSID);
      if (WiFi.begin(WIFI_SSID, WIFI_PASS) == WL_CONNECTED)
        server.begin();                           // start the web server on port 2000
        printWifiStatus();                        // you're connected now, so print out the status
        digitalWrite(LED_BLUE, HIGH);
  MQTTClient.loop();
  if (millis() - MQTTReconnectmillis > 5000)
    if (!MQTTClient.connected())
      Serial.println(F("MQTT Connecting..."));
      wdt_reset();
      if (MQTTClient.connect(clientid, CLOUD_USERNAME, CLOUD_PASSWORD))
        Serial.println(F("MQTT succeeded"));
        digitalWrite(LED_RED, HIGH);
        MQTTClient.subscribe(sub_buffer);
        Publish(pub_buffer, "all:0");
        wdt_reset();
        Serial.println(F("MQTT failed"));
        MQTTClient.disconnect();
  // Relay
    byte TempRelay = RelayDataE[EID];
    TempRelay &= RelayMaskOffE[EID];
    TempRelay |= RelayMaskOnE[EID];
      TempRelay = RelayFallBackE[EID];
    Wire.beginTransmission(I2CExpModule + EID);
    Wire.write(~TempRelay);  // MSB
    Wire.endTransmission();
  // Dimming
  byte thiscrc = 0;
    thiscrc += ExpansionChannel[a] * (a + 1);
    thiscrc += ExpansionChannelOverride[a] * (a + 1);
  if (millis() % 60000 < 200) lastcrc = -1;
  if (lastcrc != thiscrc || millis() < 5000)
    lastcrc = thiscrc;
    // setup PCA9685 for data receive
    // we need this to make sure it will work if connected ofter controller is booted, so we need to send it all the time.
    Wire.beginTransmission(I2CPWM_PCA9685);
    Wire.write((uint8_t)0);
    Wire.write(0xa1);
      int data;
      if (ExpansionChannelOverride[a] <= 100)
        data = ExpansionChannelOverride[a] * 40.96;
        data = ExpansionChannel[a] * 40.96;
      Wire.write(0x8 + (4 * a));
      Wire.write(data & 0xff);
      Wire.write(data >> 8);
  if (MQTTClient.connected())
    // IO
    Wire.requestFrom(I2CIO_PCF8574, 1);
    if (Wire.available())
      Params.IO = Wire.read();
    if (Params.IO != OldParams.IO)
      OldParams.IO = Params.IO;
      sprintf(buffer, "io:%d", Params.IO);
      Publish(pub_buffer, buffer);
    // Leak
    int iLeak = 0;
    Wire.requestFrom(I2CLeak, 2);
      iLeak = Wire.read();
      iLeak = iLeak << 8;
      iLeak += Wire.read();
      Params.Leak = iLeak > 2000;
    if (Params.Leak != OldParams.Leak)
      OldParams.Leak = Params.Leak;
      sprintf(buffer, "leak:%d", Params.Leak);
    if (millis() - Paramsmillis > 1000)
      Paramsmillis = millis();
      // Temperature
      if (addr1[0] != 0)
        ds.reset();
        ds.select(addr1);
        ds.write(0xBE);         // Read Scratchpad
        for (byte i = 0; i < 2; i++)
          data[i] = ds.read();
        Params.Temp[1] = (data[1] << 8) + data[0]; //take the two bytes from the response relating to temperature
        Params.Temp[1] = Params.Temp[1] / 1.6;
        if (Params.Temp[1] == 0) Params.Temp[1] = 0;
        if (Params.Temp[1] > 850) Params.Temp[1] = 0;
        Params.Temp[1] = Params.Temp[1] * 1.8 + 320;
        if (Params.Temp[1] != OldParams.Temp[1])
          OldParams.Temp[1] = Params.Temp[1];
          sprintf(buffer, "t:%d:%d",TempProbeIDs[0], Params.Temp[1]);
          if (TempProbeIDs[0]!=0) Publish(pub_buffer, buffer);
      if (addr2[0] != 0)
        ds.reset();
        ds.select(addr2);
        Params.Temp[2] = (data[1] << 8) + data[0]; //take the two bytes from the response relating to temperature
        Params.Temp[2] = Params.Temp[2] / 1.6;
        if (Params.Temp[2] == 0) Params.Temp[2] = 0;
        if (Params.Temp[2] > 850) Params.Temp[2] = 0;
        Params.Temp[2] = Params.Temp[2] * 1.8 + 320;
        if (Params.Temp[2] != OldParams.Temp[2])
          OldParams.Temp[2] = Params.Temp[2];
          sprintf(buffer, "t:%d:%d",TempProbeIDs[1], Params.Temp[2]);
          if (TempProbeIDs[1]!=0) Publish(pub_buffer, buffer);
      // ORP
      unsigned long temporp = 0;
      int iORP = 0;
      for (int a = 0; a < 20; a++)
        Wire.requestFrom(I2CORP, 2);
          iORP = Wire.read();
          iORP = iORP << 8;
          iORP += Wire.read();
        temporp += iORP;
      temporp = temporp / 20;
      if (temporp != 0)
        Params.ORP = map(temporp, ORPMin, ORPMax, 0, 470); // apply the calibration to the sensor reading
        Params.ORP = constrain(Params.ORP, 0, 550);
        if (pub_orp[0] == 'o') ORPFound = true;
      if (ORPCal)
        sprintf(buffer, "%sc:%d", pub_orp, temporp);
        if (Params.ORP != OldParams.ORP)
          OldParams.ORP = Params.ORP;
          sprintf(buffer, "%s:%d", pub_orp, Params.ORP);
      // Salinity
      unsigned long tempsal = 0;
      int iSAL = 0;
        Wire.requestFrom(I2CSalinity, 2);
          iSAL = Wire.read();
          iSAL = iSAL << 8;
          iSAL += Wire.read();
        tempsal += iSAL;
      tempsal = tempsal / 20;
      if (tempsal != 0)
        Params.Salinity = map(tempsal, 0, SalMax, 60, 350); // apply the calibration to the sensor reading
        if (pub_salinity[0] == 's') SalinityFound = true;
      if (SalCal)
        sprintf(buffer, "%sc:%d", pub_salinity, tempsal);
        if (Params.Salinity != OldParams.Salinity)
          OldParams.Salinity = Params.Salinity;
          sprintf(buffer, "%s:%d", pub_salinity, Params.Salinity);
      // pH Exp
      unsigned long tempphexp = 0;
      int iPHExp = 0;
        Wire.requestFrom(I2CPH, 2);
          iPHExp = Wire.read();
          iPHExp = iPHExp << 8;
          iPHExp += Wire.read();
        tempphexp += iPHExp;
      tempphexp = tempphexp / 20;
      if (tempphexp != 0)
        Params.PHExp = map(tempphexp, PHExpMin, PHExpMax, 700, 1000); // apply the calibration to the sensor reading
        Params.PHExp = constrain(Params.PHExp, 100, 1400);
        if (pub_phexp[0] == 'p') PHExpFound = true;
      if (PHExpCal)
        sprintf(buffer, "%sc:%d", pub_phexp, tempphexp);
        if (Params.PHExp != OldParams.PHExp)
          OldParams.PHExp = Params.PHExp;
          sprintf(buffer, "%s:%d", pub_phexp, Params.PHExp);
      // PAR
      unsigned long temppar = 0;
      int iPAR = 0;
        Wire.requestFrom(I2CPAR, 2);
          iPAR = Wire.read();
          iPAR = iPAR << 8;
          iPAR += Wire.read();
        temppar += iPAR;
      temppar = temppar / 20;
      if (temppar != 0)
        temppar *= 5000; // apply the calibration to the sensor reading
        temppar /= 8192;
        Params.PAR = temppar;
      if (Params.PAR != OldParams.PAR)
        OldParams.PAR = Params.PAR;
        sprintf(buffer, "par:%d", Params.PAR);
      // Humidity
      int iHumidity = 0;
      int reply[10];
      Wire.beginTransmission(I2CHumidity);
      Wire.endTransmission();  // For some reason, it needs this to work??? Bug with sensor??
      Wire.write(0x3); // 0x3 for read 0x10 for write to registers
      Wire.write((byte)0x0);  // start at address 0x0 for humidity
      Wire.write(2);  // request 2 bytes data for humidity or 4 bytes for temperature+humidity
      Wire.requestFrom(I2CHumidity, 6); // Request 6 bytes
      for (int i=0;i<6;i++)
        if(Wire.available()) reply[i] = Wire.read();
      if (reply[0]==0x3 && reply[1]==0x2) // The response need to contain function (0x3) and length of data (0x2)
        int crc=reply[5];
        crc<<=8;
        crc+=reply[4];
        if (crc == crc16(reply,4))
          iHumidity=reply[2];
          iHumidity<<=8;
          iHumidity+=reply[3];
      Params.Humidity=iHumidity;
      if (Params.Humidity != OldParams.Humidity)
        OldParams.Humidity = Params.Humidity;
        sprintf(buffer, "hum:%d", Params.Humidity);
      // Water Level
      for (int i = 0; i < WL_CHANNELS; i++)
        unsigned long tempwl = 0;
        int iWL = 0;
          if (i == 0)
            Wire.requestFrom(I2CWaterLevel, 2);
              iWL = Wire.read();
              iWL = iWL << 8;
              iWL += Wire.read();
            tempwl += iWL;
            if (tempwl != 0 && pub_wl[0] == 'w') WLFound = true;
            Wire.beginTransmission(I2CMultiWaterLevel);
            Wire.write(1); // Config Pointer
            byte addr = (0xb + i) << 4; // Select which channel to read
            addr += 0x03; // Programmable Gain
            Wire.write(addr);
            Wire.write(0x83);
            delay(10); // It takes 10ms for conversion to be completed
            Wire.write((uint8_t)0); // Convert Pointer
            Wire.requestFrom(I2CMultiWaterLevel, 2); // Request converted value
              iWL = Wire.read();
              iWL = iWL << 8;
              iWL += Wire.read();
            tempwl += iWL >> 4;
            if (tempwl != 0 && pub_multiwl[0] == 'w') MultiWLFound = true;
        tempwl = tempwl / 20;
        if (tempwl != 0)
          Params.WL[i] = map(tempwl, WLMin[i], WLMax[i], 0, 100); // apply the calibration to the sensor reading
          Params.WL[i] = constrain(Params.WL[i], 0, 255);
        if (WLCal[i])
          if (i == 0)
            if (pub_wl[0] == 'c')
              sprintf(buffer, "%s%d", pub_custom_wl, tempwl);
              sprintf(buffer, "%sc:%d", pub_wl, tempwl);
            if (pub_multiwl[0] == 'c')
              sprintf(buffer, "%s%d", pub_custom_multiwl, tempwl);
              sprintf(buffer, "%sc:%d", pub_multiwl, tempwl);
          if (Params.WL[i] != OldParams.WL[i])
            OldParams.WL[i] = Params.WL[i];
            if (i == 0)
                sprintf(buffer, "%s%d", pub_wl, Params.WL[i]);
                sprintf(buffer, "%s:%d:%d", pub_wl, i, Params.WL[i]);
                sprintf(buffer, "%s%d", pub_multiwl, Params.WL[i]);
                sprintf(buffer, "%s:%d:%d", pub_multiwl, i, Params.WL[i]);
      ds.reset();
      ds.select(addr1);
      ds.write(0x44, 0);
      ds.reset();
      ds.select(addr2);
      ds.write(0x44, 0);
void MQTTSubCallback(char* topic, byte* payload, unsigned int length) {
  boolean data_found = false;
  int payload_data = 0;
  byte data_index = 0;
  if (payload[0] == 'R' && payload[1] == 'O' && payload[2] == 'F' && payload[3] == 'F' && payload[5] == ':')
    data_found = true;
    data_index = payload[4] - '0' - 1;
    for (byte a = 6; a < length; a++)
      if (payload[a] != 10 && payload[a] != 13)
        payload_data *= 10;
        payload_data += payload[a] - '0';
    RelayMaskOffE[data_index] = payload_data;
  else if (payload[0] == 'R' && payload[1] == 'O' && payload[2] == 'N' && payload[4] == ':')
    data_found = true;
    data_index = payload[3] - '0' - 1;
    for (byte a = 5; a < length; a++)
        payload_data *= 10;
    RelayMaskOnE[data_index] = payload_data;
  else if (payload[0] == 'R' && payload[2] == ':')
    data_found = true;
    data_index = payload[1] - '0' - 1;
    for (byte a = 3; a < length; a++)
        payload_data *= 10;
    RelayDataE[data_index] = payload_data;
  else if (payload[0] == 'P' && payload[1] == 'W' && payload[2] == 'M' && payload[3] == 'E' && payload[5] == ':')
    data_found = true;
    data_index = payload[4] - '0';
        payload_data *= 10;
    ExpansionChannel[data_index] = payload_data;
  else if (payload[0] == 'P' && payload[1] == 'W' && payload[2] == 'M' && payload[3] == 'E' && payload[5] == 'O' && payload[6] == ':')
    data_found = true;
    for (byte a = 7; a < length; a++)
        payload_data *= 10;
    ExpansionChannelOverride[data_index] = payload_data;
  else if (payload[0] == 'O' && payload[1] == 'R' && payload[2] == 'P' && payload[3] == 'C' && payload[4] == ':' && ORPFound)
    Serial.println(F("ORP calibration"));
    data_found = true;
    if (payload[5] == '0')
      ORPCal = false;
    else if (payload[5] == '1')
      ORPCal = true;
    else if (payload[5] == '2')
          payload_data *= 10;
      CalVal1 = payload_data;
    else if (payload[5] == '3')
          payload_data *= 10;
      memory_write_int(Mem_I_ORPMin, CalVal1);
      memory_write_int(Mem_I_ORPMax, payload_data);
      ORPMin = CalVal1;
      ORPMax = payload_data;
      ORPCal = false;
  else if (payload[0] == 'S' && payload[1] == 'A' && payload[2] == 'L' && payload[3] == 'C' && payload[4] == ':' && SalinityFound)
    Serial.println(F("Sal calibration"));
    data_found = true;
      SalCal = false;
      SalCal = true;
          payload_data *= 10;
      memory_write_int(Mem_I_SalMax, payload_data);
      SalMax = payload_data;
      SalCal = false;
  else if (payload[0] == 'P' && payload[1] == 'H' && payload[2] == 'E' && payload[3] == 'C' && payload[4] == ':' && PHExpFound)
    Serial.println(F("PH Exp calibration"));
    data_found = true;
      PHExpCal = false;
      PHExpCal = true;
          payload_data *= 10;
          payload_data *= 10;
      memory_write_int(Mem_I_PHExpMin, CalVal1);
      memory_write_int(Mem_I_PHExpMax, payload_data);
      PHExpMin = CalVal1;
      PHExpMax = payload_data;
      PHExpCal = false;
  else if (payload[0] == 'W' && payload[1] == 'L' && payload[3] == 'C' && payload[4] == ':' && (WLFound || MultiWLFound))
    Serial.println(F("WL calibration"));
    data_found = true;
    data_index = payload[2] - '0';
      WLCal[data_index] = false;
      if (data_index == 0 && WLFound)
        WLCal[data_index] = true;
      if (data_index > 0 && MultiWLFound)
          payload_data *= 10;
          payload_data *= 10;
      if (data_index == 0)
        memory_write_int(Mem_I_WaterLevelMin, CalVal1);
        memory_write_int(Mem_I_WaterLevelMax, payload_data);
      if (data_index > 0 && data_index < 5)
        memory_write_int(Mem_I_WaterLevel1Min + (data_index * 2) - 2, CalVal1);
        memory_write_int(Mem_I_WaterLevel1Max + (data_index * 2) - 2, payload_data);
      WLMin[data_index] = CalVal1;
      WLMax[data_index] = payload_data;
  else if (payload[0] == 'C' && payload[1] == 'E' && payload[2] == 'X' && payload[3] == 'P' && payload[5] == 'C' && payload[6] == ':')
    Serial.println(F("Custom Exp calibration"));
    data_found = true;
    if (payload[7] == '0')
      if (pub_salinity[0] == 'c' && CustomExpansion[data_index] == CUSTOM_SALINITY) SalCal = false;
      if (pub_orp[0] == 'c' && CustomExpansion[data_index] == CUSTOM_ORP) ORPCal = false;
      if (pub_phexp[0] == 'c' && CustomExpansion[data_index] == CUSTOM_PHEXP) PHExpCal = false;
      if (pub_wl[0] == 'c' && CustomExpansion[data_index] == CUSTOM_WL) WLCal[0] = false;
      for (int a = 1; a < WL_CHANNELS; a++)
        if (pub_multiwl[0] == 'c' && CustomExpansion[data_index] >= CUSTOM_MULTI_WL1 && CustomExpansion[data_index] <= CUSTOM_MULTI_WL4) WLCal[a] = false;
    else if (payload[7] == '1')
      if (pub_salinity[0] == 'c' && CustomExpansion[data_index] == CUSTOM_SALINITY) SalCal = true;
      if (pub_orp[0] == 'c' && CustomExpansion[data_index] == CUSTOM_ORP) ORPCal = true;
      if (pub_phexp[0] == 'c' && CustomExpansion[data_index] == CUSTOM_PHEXP) PHExpCal = true;
      if (pub_wl[0] == 'c' && CustomExpansion[data_index] == CUSTOM_WL) WLCal[0] = true;
      if (pub_multiwl[0] == 'c' && CustomExpansion[data_index] == CUSTOM_MULTI_WL1) WLCal[1] = true;
      if (pub_multiwl[0] == 'c' && CustomExpansion[data_index] == CUSTOM_MULTI_WL2) WLCal[2] = true;
      if (pub_multiwl[0] == 'c' && CustomExpansion[data_index] == CUSTOM_MULTI_WL3) WLCal[3] = true;
      if (pub_multiwl[0] == 'c' && CustomExpansion[data_index] == CUSTOM_MULTI_WL4) WLCal[4] = true;
    else if (payload[7] == '2')
      for (byte a = 9; a < length; a++)
        payload_data *= 10;
    else if (payload[7] == '3')
        payload_data *= 10;
      if (pub_salinity[0] == 'c')
        SalCal = false;
      if (pub_orp[0] == 'c')
        ORPMin = CalVal1;
        ORPCal = false;
      if (pub_phexp[0] == 'c')
        PHExpMin = CalVal1;
        PHExpCal = false;
        WLMin[0] = CalVal1;
        WLMax[0] = payload_data;
        WLCal[0] = false;
        if (pub_multiwl[0] == 'c' && WLCal[a] == true)
          memory_write_int(Mem_I_WaterLevel1Min + (a * 2) - 2, CalVal1);
          memory_write_int(Mem_I_WaterLevel1Max + (a * 2) - 2, payload_data);
          WLMin[a] = CalVal1;
          WLMax[a] = payload_data;
          WLCal[a] = false;
  if (data_found)
    blink_data_led(30);
    for (int a = 0; a < length; a++)
      Serial.write(payload[a]);
    Serial.println();
const char* ip_to_str(const uint8_t* ipAddr)
  static char buf[16];
  sprintf(buf, "%d.%d.%d.%d", ipAddr[0], ipAddr[1], ipAddr[2], ipAddr[3]);
  return buf;
void ApplyCalibration(byte module, byte type)
  CustomExpansion[module - 1] = type;
  switch (type)
    case CUSTOM_SALINITY:
      sprintf(pub_salinity, "cexp:%d:", module - 1);
      break;
    case CUSTOM_ORP:
      sprintf(pub_orp, "cexp:%d:", module - 1);
      break;
    case CUSTOM_PHEXP:
      sprintf(pub_phexp, "cexp:%d:", module - 1);
      break;
    case CUSTOM_WL:
      sprintf(pub_wl, "cexp:%d:", module - 1);
      sprintf(pub_custom_wl, "cexpc:%d:", module - 1);
      break;
    case CUSTOM_MULTI_WL1:
    case CUSTOM_MULTI_WL2:
    case CUSTOM_MULTI_WL3:
    case CUSTOM_MULTI_WL4:
      sprintf(pub_multiwl, "cexp:%d:", module - 1);
      sprintf(pub_custom_multiwl, "cexpc:%d:", module - 1);
      break;
    case CUSTOM_NONE:
      break;
void blink_data_led(byte timer)
  delay(timer);
void Publish(char* pub_buffer, char* buffer)
  MQTTClient.publish(pub_buffer, buffer);
  Serial.println(buffer);
  blink_data_led(50);
byte memory_read_byte(int address)
  byte rdata = 0xFF;
  Wire.beginTransmission(I2CEEPROM1);
  Wire.write((int)(address >> 8));   // MSB
  Wire.write((int)(address & 0xFF)); // LSB
  Wire.requestFrom(I2CEEPROM1,1);
        rdata = Wire.read();
  return rdata;
void memory_write_byte(int address, const byte data)
  if (memory_read_int(address) != data)
    Wire.write(data);
    delay(10);
int memory_read_int(int address)
  int rdata = 0xFFFF;
  Wire.requestFrom(I2CEEPROM1,2);
        rdata += (Wire.read())<<8;
  return rdata;
void memory_write_int(int address, const int data)
    Wire.write(data%256);
    Wire.write(data>>8);
    delay(10);
void printWifiStatus() {
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
unsigned int crc16(int *ptr, byte len)
  unsigned int crc=0xFFFF;
  byte i;
  byte temp=0;
  int test;
  while(len--)
    crc^=*ptr++;
    for(i=0;i<8;i++)
      if(crc & 0x01)
        crc>>=1;
        crc^=0xA001;
        crc>>=1;
  return crc;
void wdt_initialize()
  GCLK->GENDIV.reg = GCLK_GENDIV_ID(2) | GCLK_GENDIV_DIV(4);
  GCLK->GENCTRL.reg = GCLK_GENCTRL_ID(2) |
                      GCLK_GENCTRL_GENEN |
                      GCLK_GENCTRL_SRC_OSCULP32K |
                      GCLK_GENCTRL_DIVSEL;
  while (GCLK->STATUS.bit.SYNCBUSY);  // Syncronize write to GENCTRL reg.
  GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID_WDT |
                      GCLK_CLKCTRL_CLKEN |
                      GCLK_CLKCTRL_GEN_GCLK2;
void wdt_enable()
  WDT->CTRL.reg &= ~WDT_CTRL_ENABLE;
  while (WDT->STATUS.bit.SYNCBUSY);  // Syncronize write to CTRL reg.
  WDT->CONFIG.reg = WDT_CONFIG_PER(0xA);  // 0xA = 8192 ms
  while (WDT->STATUS.bit.SYNCBUSY);  // Syncronize write to CONFIG reg.
  WDT->INTENCLR.reg |= WDT_INTENCLR_EW;
  WDT->CTRL.reg |= WDT_CTRL_ENABLE;
void wdt_disable()
void wdt_reset()
  WDT->CLEAR.reg = WDT_CLEAR_CLEAR_KEY;
  while (WDT->STATUS.bit.SYNCBUSY);  // Syncronize write to CLEAR reg.
// RA_STRING1=U2FsdGVkX1+v9maD6sR7lmfrBMXYH2hY/h8++Itviz0=
// RA_STRING2=U2FsdGVkX192Np27NDkaa73OUwJfOKtJ7zvgIZ/mfZo=
// RA_STRING3=netgearcannon
// RA_LABEL LABEL_ACTINIC=Blues
// RA_LABEL LABEL_ACTINIC2=Cool Whites
// RA_LABEL LABEL_DAYLIGHT2=Daylight 2
// RA_LABEL LABEL_PORT11=Heater 1
// RA_LABEL LABEL_PORT12=Return
// RA_LABEL LABEL_PORT13=Port 13
// RA_LABEL LABEL_PORT14=Skimmer
// RA_LABEL LABEL_PORT15=Port 15
// RA_LABEL LABEL_PORT16=Port 16
// RA_LABEL LABEL_PORT17=Port 17
// RA_LABEL LABEL_PORT18=Port 18
What am I doing wrong?
Re: Cloud Wifi Hub compile error
That code is only applicable to a very small amount of cloud wifi attachments we made, which are rev 1.
Some of them were very unstable and unreliable, so we built another one with another technology, which are the rev 2.
Can you open yours and check which revision you have?
Loose
Post by Loose »
Hey Roberto, I'll open it up when I get home this evening (at work right now) but I want to make sure of the terminology. I don't think I have a cloud wifi 'attachment,' I believe I have a cloud wifi 'hub' to go with my RA*. Also, I didn't upload the code since the initial version above, that the Wizard created, wouldn't compile.
Loose
Post by Loose »
The board is a Cloud Wifi Expansion v 1.4
Oh, you don't need to upload any code.
Look for the cloud wifi attachment 2.0 manual for instructions on how to set it up.
It uses the same technology.
Loose
Post by Loose »
That works. Thanks.
Loose
Post by Loose »
I used the cloud wifi attachment 2.0 manual and I can see it on my local network (flashing cyan light) but I haven't figured out how to access modules attached to it; currently having a Relay Expansion Box (configure #2) and a Dimming Expansion Module attached.
Use the web based uapp.
http://forum.reefangel.com/uapp
Loose
Post by Loose »
I am using the Uapp. I can see Expansion Box 2 but when I toggle the ports, they don't come on. I have the dip switches in the following positions: 1 - on, 2 - off, 3 - off
Is it working for box 1?
Loose
Post by Loose »
Box 1 is connected directly to the RA* head unit and ports do toggle with both Uapp and the Android App. Box 2 is connected to the Cloud Wifi hub and show the change on the screens, but the outlets don't come on.
Loose
Post by Loose »
To verify the cables and box worked, I connected Box 2 to the RA* (through an expansion hub) and the ports toggle off and on via the Uapp and Android App when connected that way.
Sorry, I missed the whole point.
It is connected to cloud wifi expansion.
Let me check some stuff and I'll get back to you.
Loose
Post by Loose »
Do you have Arduino IDE installed in your computer?
If not, download the Reef Angel Installer from the download section of the website and install it.
Connect the cloud wifi expansion to a USB in the computer.
Open Arduino and go to menu Tools->Serial port and select the serial port for the cloud wifi expansion.
The go to Tools->Serial Monitor and make sure that 57600 baud is selected.
Send the log you see on the monitor.
Loose
Post by Loose »
I do have Arduino IDE installed.
With the Cloud expansion connected, I am unable to select the serial port where it is attached.
When I go to tools in Arduino IDE, "Serial Port" is a grayed out option.
I have tried on the laptop that I use to upload code to the RA* and tried on another desktop with a fresh install of Arduino IDE with the same results; not found.
When I use Device manager (Windows 10) it shows connected there as a "CP2104 USB to UART Bridge Controller." The icon has a superimposed caution icon with the following Device status properties:
The drivers for this device are not installed. (Code 28)
There are no compatible drivers for this device.
To find a driver for this device, click Update Driver.
Download the driver from the manufacturer:
https://www.silabs.com/products/develop ... cp-drivers
Loose
Post by Loose »
Driver installed
Solid blue light
Output:
Failed, rc=-2 try again in 30 seconds
Connecting to cloud server...
Failed, rc=5 try again in 30 seconds
That means it is not connected.
Loose
Post by Loose »
Yep, got that part.
Try running the setup again while connected to the serial monitor and send the log again.
Loose
Post by Loose »
Looks like it's connected now. Thank you.
mounted file system
*WM: Adding parameter
*WM: Cloud Username
*WM: Cloud Password
*WM:
*WM: AutoConnect
*WM: Connecting as wifi client...
*WM: Using last saved values, should be faster
*WM: Connection result:
*WM: 0
*WM: SET AP STA
Entered config mode
*WM:
*WM: Configuring access point...
*WM: ReefAngelCloudHub
*WM: AP IP address:
*WM: 192.168.4.1
*WM: HTTP server started
*WM: Request redirected to captive portal
*WM: Handle root
*WM: Handle root
*WM: Handle root
*WM: Handle root
*WM: Handle root
*WM: Handle root
*WM: Handle root
*WM: Scan done
*WM: K2GVR
*WM: -67
*WM: NETGEARcannon
*WM: -83
*WM: carlsenfamily
*WM: -87
*WM: HP-Print-BA-LaserJet 1102
*WM: -89
*WM: Sent config page
*WM: WiFi save
*WM: Parameter
*WM: Cloud Username
*WM: Loose
*WM: Parameter
*WM: Cloud Password
*WM: +++++++++
*WM: Sent wifi save page
*WM: Connecting to new AP
Checking Wifi Credentials
*WM: 3
Should save config
username: Loose
Start
saving config
{"mqtt_username":"Loose","mqtt_password":"+++++++"}
IP address: 192.168.1.30
Connected
Subscribing to Loose/out/#
Loose/in: all:0
Loose/in: io:255
cloud:ATOLOW:0
cloud:ATOHIGH:0
cloud:EM:137
cloud:EM1:4
cloud:REM:3
cloud:BID:4
cloud:AF:0
cloud:SF:0
cloud:PWMD:0
cloud:PWMA:0
cloud:PWMDO:255
cloud:PWMAO:255
cloud:R1:247
R1:247
cloud:ROFF1:255
ROFF1:255
cloud:RON1:0
RON1:0
cloud:R2:2
R2:2
cloud:ROFF2:255
ROFF2:255
cloud:RON2:0
RON2:0
cloud:R3:0
R3:0
cloud:ROFF3:255
ROFF3:255
cloud:RON3:0
RON3:0
cloud:R4:0
R4:0
cloud:ROFF4:255
ROFF4:255
cloud:RON4:0
RON4:0
cloud:R5:0
R5:0
cloud:ROFF5:255
ROFF5:255
cloud:RON5:0
RON5:0
cloud:R6:0
R6:0
cloud:ROFF6:255
ROFF6:255
cloud:RON6:0
RON6:0
cloud:R7:0
R7:0
cloud:ROFF7:255
ROFF7:255
cloud:RON7:0
RON7:0
cloud:R8:0
R8:0
cloud:ROFF8:255
ROFF8:255
cloud:RON8:0
RON8:0
cloud:ALARM:0
cloud:PWMD2:0
cloud:PWMA2:0
cloud:PWMD2O:255
cloud:PWMA2O:255
cloud:WL:0
cloud:WL2:72
cloud:WL3:97
cloud:WL4:3
cloud:HUM:0
cloud:DCM:0
cloud:DCS:0
cloud:DCD:0
cloud:DCT:0
cloud:PWME0:0
PWME0:0
cloud:PWME1:0
PWME1:0
cloud:PWME2:0
PWME2:0
cloud:PWME3:0
PWME3:0
cloud:PWME4:0
PWME4:0
cloud:PWME5:0
PWME5:0
cloud:PWME0O:255
PWME0O:255
cloud:PWME1O:255
PWME1O:255
cloud:PWME2O:255
PWME2O:255
cloud:PWME3O:255
PWME3O:255
cloud:PWME4O:255
PWME4O:255
cloud:PWME5O:255
PWME5O:255
cloud:AIW:0
cloud:AIB:0
cloud:AIRB:0
cloud:RFM:0
cloud:RFS:0
cloud:RFD:0
cloud:RFW:0
cloud:RFRB:0
cloud:RFR:0
cloud:RFG:0
cloud:RFB:0
cloud:RFI:0
cloud:RFWO:0
cloud:RFRBO:0
cloud:RFRO:0
cloud:RFGO:0
cloud:RFBO:0
cloud:RFIO:0
cloud:IO:0
cloud:LEAK:0
cloud:C0:0
cloud:C1:0
cloud:C2:0
cloud:C3:0
cloud:C4:0
cloud:C5:0
cloud:C6:0
cloud:C7:0
cloud:R:0
cloud:ROFF:255
cloud:RON:0
cloud:T1:737
cloud:T2:766
cloud:T3:770
cloud:PH:796
cloud:T4:786
cloud:T5:0
cloud:T6:0
cloud:ORP:0
cloud:PHE:0
cloud:PAR:0
cloud:CEXP0:0
cloud:CEXP1:0
cloud:CEXP2:0
cloud:CEXP3:0
cloud:CEXP4:0
cloud:CEXP5:0
cloud:CEXP6:0
cloud:CEXP7:0
cloud:WL1:101
cloud:SAL:339
cloud:WL1:102
cloud:WL1:101
cloud:WL1:102
cloud:WL1:103
cloud:WL1:100
cloud:WL2:73
cloud:SAL:340
cloud:WL1:101
cloud:WL2:72
cloud:SAL:339
cloud:WL1:104
cloud:WL2:71
cloud:WL1:101
cloud:WL2:72
cloud:WL2:71
cloud:WL1:100
cloud:WL2:72
cloud:SAL:340
cloud:WL1:103
cloud:SAL:339
cloud:WL1:101
As a side note, did you happen to get the new boxes for it? I have to take the board out to do a factory reset since the hole doesn't line up with the switch... I can just drill a new hole as well.
Loose
Post by Loose »
Tried it with the Relay expansion box and can toggle the ports from Uapp and Android app (after I put it back together :-) ).
Thank again!
