diy leds to RA*
PostPosted: Tue Feb 27, 2018 9:05 pm
I connected my leds to the dimming port of the star but they will not respond to dimming. i checked and im getting 5 volts to the driver going in the dimming inputs. Any ideas
my code from the web wizard
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port3Bit | Port5Bit;
ReefAngel.FeedingModePortsE[1] = 0;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port5Bit;
ReefAngel.WaterChangePortsE[1] = 0;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port4Bit;
ReefAngel.OverheatShutoffPortsE[1] = 0;
ReefAngel.LightsOnPortsE[1] = 0;
ReefAngel.StandardHeater( T1_PROBE,Box1_Port2,750,770 );
ReefAngel.SingleATO( true,Box1_Port3,120,0 );
ReefAngel.StandardLights( Box1_Port4,10,0,22,0 );
ReefAngel.Relay.DelayedOn( Box1_Port5,2 );
ReefAngel.StandardLights( Box1_Port6,6,0,12,0 );
ReefAngel.PWM.SetDaylight( PWMSlope( 13,0,21,0,5,70,100,0 ) );
ReefAngel.PWM.SetActinic( PWMSlope( 10,0,21,0,10,100,100,0 ) );
ReefAngel.PWM.SetDaylight2( PWMSlope( 13,0,21,0,5,70,100,0 ) );
ReefAngel.PWM.SetActinic2( PWMSlope( 10,0,21,0,10,100,100,0 ) );
boolean buzzer=false;
if ( ReefAngel.isATOTimeOut() ) buzzer=true;
ReefAngel.Network.Cloud();
// RA_STRING1=U2FsdGVkX1+GGNHNdCwVcHPfkCqY6YdqeXBCpjNczyo=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_ACTINIC2=Actinic 2
// RA_LABEL LABEL_DAYLIGHT2=Daylight 2
// RA_LABEL LABEL_PORT11=Return
// RA_LABEL LABEL_PORT12=Heater
// RA_LABEL LABEL_PORT13=ATO
// RA_LABEL LABEL_PORT14=ReefBrites
// RA_LABEL LABEL_PORT15=Skimmer
// RA_LABEL LABEL_PORT16=Scrubber light
// RA_LABEL LABEL_PORT17=Port 7
// RA_LABEL LABEL_PORT18=Port 8
// RA_LABEL LABEL_PORT21=Port 21
// RA_LABEL LABEL_PORT22=Port 22
// RA_LABEL LABEL_PORT23=Port 23
// RA_LABEL LABEL_PORT24=Port 24
// RA_LABEL LABEL_PORT25=Port 25
// RA_LABEL LABEL_PORT26=Port 26
// RA_LABEL LABEL_PORT27=Port 27
// RA_LABEL LABEL_PORT28=Port 28
PostPosted: Wed Feb 28, 2018 12:40 am
If you are getting the correct dimming signal to the driver, it probably has nothing to do with the code.
It's got to be something on the driver or the wiring.
Return to Standard
