Bus locks
Re: Bus locks
When you power cycle, does it become responsive?
Are you the one that replaced the board? If so, can you double check the display flex cable you had to insert when replacing the board?
Re: Bus locks
Yeah it's good again after I unplug and plug back....I didn't replace the board this is a week old. I just put Jumpers for pwm 0-5 volts
Re: Bus locks
Ok, can you double check the display flex cable?
When you opened it, it may have been pulled and is having a bad connection now.
