Bus locks
bkc6868
Bus locks
Post by bkc6868 »
Last couple days my RA* has been getting bus locks. There are no expansions connected so I'm not sure where to start looking for the side of the problem
Re: Bus locks
Is the touch screen responsive?
bkc6868
Re: Bus locks
Post by bkc6868 »
No...I have to unplug and plug back in again
Re: Bus locks
When you power cycle, does it become responsive?
Are you the one that replaced the board? If so, can you double check the display flex cable you had to insert when replacing the board?
bkc6868
Re: Bus locks
Post by bkc6868 »
Yeah it's good again after I unplug and plug back....I didn't replace the board this is a week old. I just put Jumpers for pwm 0-5 volts
Re: Bus locks
Ok, can you double check the display flex cable?
When you opened it, it may have been pulled and is having a bad connection now.
