Reef Angel Web Wizard
I think it is the same
I kept getting Error 400 last night. I'll try again tonight.
Sent from my Pixel XL using Tapatalk |
I just got the Cloud Portal. I downloaded the latest RA code, ReefAngelInstaller_1.1.3.exe. (I had 1.1.1 installed before that).
Installed. Per the docs, used the WebWizard. Got a sketch. Copied it to my development machine (I use vMicro, but for this I used the RA Arduino fork executable). A snippet of the problem code:
I get an error:
Indeed, I downloaded the Github code (https://github.com/reefangel/Libraries) and find that the word "CloudPortal" does not exist in any of the library files, and is not a member of ReefAngel.cpp. I even followed breadcrumbs to https://github.com/lnevo but it's the same as what's checked in under ReefAngel. So what do I have to do to get this to compile? Thanks, == John == |
Try using the dev branch of the github
That seems better, BUT ... Then the "Dev" branch needs to be copied over, or the docs need updating. This is crazy. I copied over the dev branch to my user folder (%USER%\Arduino) and now I'm getting a ton of compiler errors. Can't quite tell if the Dev branch is Arduino 1.0.1 or something newer. This is harder than it should be. Is this product dead? ![]() |
No. The dev branch is the latest. It is what it is used on the web wizard.
I decided not use the Arduino IDE for mainstream anymore. It is only used for development. The webwizard is what you want to use if you don't want to worry about compile errors. Link for webwizard: webwizard Now, if you are talking about doing library development, then it is another story. You will need the IDE. So, I would suggest just going to webwizard and doing all the compiling and uploading in there. Roberto.
I am doing development
![]() Or, I was ... I copied over my code into the web wizard and at least sort of got it to work. |
Joined: Mon Sep 17, 2012 12:41 pm Location: Lincoln Park, Chicago, IL, USA 60614 |
But how do you suggest we do this if we use the Bluetooth adapter for upload? |
Copy and paste into the Audrino app and upload with the Bluetooth adapter, it's just more convenient because it's wireless. Sent from my Pixel XL using Tapatalk |
But that’s the problem. The web wizard is using the dev branch, which works with the cloud portal. The 1.1.3 libraries don’t support this in Arduino. And the web wizard doesn’t support the Bluetooth adapter.
Just a few posts above, it sounded like copying the dev branch locally was causing a bunch of compile errors. I haven’t tried doing this myself yet, though. Seems odd to me that the web wizard would be using the dev branch and not a release branch. And why hasn’t the cloud portal made it into a release branch yet if it’s being sold? |
