RA* relay update question
grafxalien
Hello- I am thinking about updating to the RA*. I purchased a RANET relay a few years ago, but it never kept a good wireless connection so it has been sitting in a closet collecting dust. Can this relay be used directly with the RA*? Also, when I received it, multiple of the ports were unusable because the copper connections in the plugs were bent. I I tried opening the unit today to see if I could bend them back. I took out all of the screws on the board, but it is still firmly attached to the front plastic cover. Are there some snaps somewhere that I am not finding? Thanks
Re: RA* relay update question
Yes, you can use it with RA* too.
To detach the board, just pry the front plastic from the board apart. There are no snaps.
If you want to send it back, I can do it for you.
grafxalien
i got the board off, took more force than anticipated. Multiple of the sockets have very bent copper plates and some even had loose connectors. Is there any way to get replacement sockets?
I don't have them.
I'll have to order them from China and it may take a while.
Can you wait a little?
