Dimming Kessil
- chachew
Dimming Kessil
I have a RA+, will the dimming ports work with the Kessil or do I need an expansion module?
- chachew
Re: Dimming Kessil
So I just need to buy the RA kessil cable? And connect it to one of the dimming ports?rimai wrote:Yes, it will as long as your dimming signal is analog
Re: Dimming Kessil
Yes. But it uses both channels. One controls intensity and another color
- chachew
Re: Dimming Kessil
Perfect. Exactly what I needed to know. So can you control the PWM as well? So to create a sunrise/sunset type effect?rimai wrote:Yes. But it uses both channels. One controls intensity and another color
Re: Dimming Kessil
Not with PWM signal. Kessil lights actually use analog signal.
But if you do have analog signal on the dimming channels, yes, you can control it to dim the lights.
- chachew
Re: Dimming Kessil
Oh ok. So the kessils can dim from the RA+ dimming ports with the RA+ kessil cable?rimai wrote:Not with PWM signal. Kessil lights actually use analog signal.
