Did you do something from your end? It just started working i can see the alarms now.
Tried to add one and now it is not letting me see them again
RA+ to RA*
Re: RA+ to RA*
Yes.
I deleted the extra space you placed on one of the alert names.
I think for some reason it doesn't like the space at the end of the alert names. The last character cannot be a space.
I edited the name on the one you just entered again.
Can you see if you can get them to show up now?
Re: RA+ to RA*
just make sure you don't add a space at the end of the name as you did before.
Re: RA+ to RA*
It did it again. I got to add the alarm one. then tried to add one more for low temp and did it again. I do not think I had a space there. Could it be the < or > signs?
Maybe delete all of them for me and I will start again.
riggeek
Re: RA+ to RA*
Getting bus lock errors again. I have had 3 in the last 24 hours.
I have checked all the usb connectors,
I have remove all the expansion modules,
I have remove the USB expansion hub.
It is just the RA*, and the relay box. the relay box is plugged strait into the RA*
I also seen it do a random reboot on its own.
Any thoughts?
Any thoughts?
riggeek
Re: RA+ to RA*
Ok, so there is some noise coming in from somewhere.
I did get your PM.
Let me send you a radio and another usb cable for you to try.
I did get your PM.
