Wave pump mode new RA*
riggeek
Does anyone have any idea why the uapp faults out when I try to swap pump modes?
I programmed it on lagoon and can not change it. I just used the wizard to programming.
When I try to change it it just times out, and does not change.
Any idea?
thanks
Any idea?
thanks
riggeek
- Contact:
Re: Wave pump mode new RA*
did you hard code the mode? or did you program the controller to use the internal memory?
riggeek
though I selected internal memory. I can change light time, and levels, kalk dosing, and other things. I just can not change the pumps.
riggeek
riggeek
- Contact:
post your code.riggeek wrote:Do we still think it is programing
riggeek
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit;
ReefAngel.WaterChangePortsE[1] = 0;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port4Bit | Port5Bit;
ReefAngel.LightsOnPortsE[0] = Port3Bit | Port5Bit;
InternalMemory.OverheatTemp_write( 790 );
ReefAngel.SingleATOLow( Box1_Port1 );
ReefAngel.DosingPumpRepeat1( Box1_Port2 );
ReefAngel.Relay.Set( Box1_Port3, !ReefAngel.Relay.Status( Box1_Port5 ) );
ReefAngel.StandardHeater1( Box1_Port4 );
ReefAngel.StandardLights( Box1_Port5 );
ReefAngel.DCPump.SetMode( Lagoon,50,10 );
ReefAngel.DCPump.Daylight2Channel = Sync;
ReefAngel.DCPump.Actinic2Channel = AntiSync;
boolean buzzer=false;
if ( ReefAngel.isATOTimeOut() ) buzzer=true;
if ( ReefAngel.isOverheat() ) buzzer=true;
if ( ReefAngel.isBusLock() ) buzzer=true;
ReefAngel.Network.Cloud();
// RA_STRING1=U2FsdGVkX19aL/7SAbcu/cSNYLbA2zgwzRGnL+NV8E0=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_ACTINIC2=Actinic 2
// RA_LABEL LABEL_DAYLIGHT2=Daylight 2
// RA_LABEL LABEL_PORT11=ATO
// RA_LABEL LABEL_PORT12=Kalk
// RA_LABEL LABEL_PORT13=Rlight
// RA_LABEL LABEL_PORT14=Heater
// RA_LABEL LABEL_PORT15=LED
// RA_LABEL LABEL_PORT16=Rpump
// RA_LABEL LABEL_PORT17=Skim
// RA_LABEL LABEL_PORT18=Wave
// RA_LABEL LABEL_PORT21=Port 21
// RA_LABEL LABEL_PORT22=Port 22
// RA_LABEL LABEL_PORT23=Port 23
// RA_LABEL LABEL_PORT24=Port 24
// RA_LABEL LABEL_PORT25=Port 25
// RA_LABEL LABEL_PORT26=Port 26
// RA_LABEL LABEL_PORT27=Port 27
// RA_LABEL LABEL_PORT28=Port 28
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
riggeek
- Contact:
This line says it all:
Your DC Pump control is hard coded and will not use the internal memory at all. It will always use this:
So, if you want to use the internal memory and control it remotely, you will need to remove the SetMode(Lagoon) line and change the memory line to this:
Then the controller will always use what values are in Internal Memory. Which means you should set them to a sensible value first, then change the UseMemory line and remove the SetMode line.
ReefAngel.DCPump.UseMemory = false;Code: Select all
ReefAngel.DCPump.UseMemory = true;-
riggeek
- Contact:
it seems like they always are...riggeek wrote:thanks
still a working in progress at this point.
I know mine is.
riggeek
Still not working right
here is the code again
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
ReefAngel.FeedingModePortsE[0] = Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port8Bit;
// RA_STRING1=U2FsdGVkX1+A7n1/gG5uO89kqJa/wC0XzX2jNCiREAY=
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_ACTINIC2=wave 2
// RA_LABEL LABEL_DAYLIGHT2=wave 1
// RA_LABEL LABEL_PORT17=Skimmer
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
// RA_STRING2=null
// RA_STRING3=null
riggeek
- Contact:
remove this line entirely:
that overrides anything that gets read from memory.
ReefAngel.DCPump.SetMode( Lagoon,50,10 );Sent from my XT1585 using Tapatalk
riggeek
Thanks again
that got it.
I had it that way the first try remote uploaded the code and got distracted. guess it never loaded. lol
thanks
that got it.
thanks
riggeek
- Contact:
welcome.
glad it’s working now.
