Alexa Control
PostPosted: Tue May 15, 2018 5:39 am
Feeding mode would be most useful!
PostPosted: Sun May 20, 2018 12:04 am
Can you test feeding and water change mode?
You will need to discover devices again to enable the two modes.
PostPosted: Sun May 27, 2018 8:15 pm
Feeding mode worked nicely :)
PostPosted: Tue Jun 05, 2018 6:37 pm
So i'm trying to enable the skill and after the amazon login screen it takes me to the authorization page i guess and it remains blank. Any ideas?
PostPosted: Tue Jun 05, 2018 9:51 pm
I wasn't able to replicate.
I tried it on a new phone with a new amazon account.
PostPosted: Fri Oct 26, 2018 11:45 pm
I just tried this myself and ran into an error trying to login.
I confirmed my username and password were correct by logging into the forum to double check. Same error comes up using Alexa app, Safari and Firefox. This is on ios12, not that I think that’s the issue.
PostPosted: Tue Oct 30, 2018 9:50 am
Just tried again hoping this would clear itself.... no dice. Still the same issue.
PostPosted: Tue Oct 30, 2018 10:40 am
I just tested the amazon/reef angel skill linking and it went through just fine.
Try resetting the forum password and try again.
PostPosted: Tue Oct 30, 2018 1:00 pm
That did the trick! Got the skill installed, but I'm getting device is unresponsive. I have the Wifi adapter, not the cloud adapter. Is that a problem?
It also only discovered my second relay box, not the first.
PostPosted: Tue Oct 30, 2018 1:09 pm
It actually only works with RA*.
I never tested with the cloud wifi attachment. It should work, but definitely not with the regular wifi attachment.
PreviousNext
Return to Standard
