With a Water Level extension (but not multilevel water level) the Web Wizard generates the following statement for a timeout of 10 minutes on port 5:
ReefAngel.WaterLevelATO( Box1_Port5,10,15,600 );Code: Select all
ReefAngel.WaterLevelATO( Box1_Port5,600,98,100 );Checking the ReefAngel class the WaterLevelATO method is declared to have the following parameter order:
void ReefAngelClass::WaterLevelATO(byte ATORelay, int ATOTimeout, byte LowLevel, byte HighLevel)Thanks.
