No Data for graphs
89delta
No Data for graphs
I checked the Uapp yesterday and today to see what my tank was doing and I saw the live values. One thing I couldn't get was anything on the graphs for the past values. I did check http://forum.reefangel.com/status/param ... id=89delta and it says last time anything was logged was 6/11/18. Any ideas? I've rebooted my controller and router several times already. Thanks.
89delta
Re: No Data for graphs
I have the cloud wifi attachment and switched the code from reg wifi portal to cloud
If you reboot the cloud wifi attachment, does it make any difference?
89delta
No, not at all. I still get my live readings but still no data to graph any values.
You have a portal key setup on your portal settings.
Remove it and you should be able to receive data again.
89delta
Ok that fixed it. But yet I still had that portal key when I first setup the wifi cloud attachment and it graphed everything. Oh well.....it's running now. Thanks
