Power Control Expansion
PostPosted: Wed Jul 04, 2018 10:56 am
Can I see the code?
PostPosted: Wed Jul 04, 2018 4:51 pm
Here you go.
// Define Relay Ports by Name
#define Return_Pump     1
#define Extra1          2
#define Skimmer         3
#define Heater          4
#define Fuge_Light      5
#define GFO_Pump        6
#define SaltMixPump     7
#define PowerCtlExp     8
//Define Relay 1 Ports by Name
#define FragHeater      Box1_Port1
#define FragPowerhead   Box1_Port2
#define FragLED1        Box1_Port3
#define WaterChange     Box1_Port4
#define FragLED2        Box1_Port5
#define FragFilter      Box1_Port6
#define BrutePump       Box1_Port7
#define SaltUV          Box1_Port8
//Define Power Control Expansion Ports by Name
  ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
  ReefAngel.FeedingModePorts = Port1Bit | Port3Bit;
  ReefAngel.WaterChangePorts = Port1Bit | Port3Bit;
  ReefAngel.Relay.On( Return_Pump );
  ReefAngel.Relay.On( FragPowerhead);
  ReefAngel.Relay.On( WaterChange);
  ReefAngel.Relay.On( BrutePump);
  ReefAngel.Relay.On( FragFilter);
  ReefAngel.Relay.On( GFO_Pump);
  ReefAngel.Relay.On( SaltMixPump);
  ReefAngel.Relay.On( Extra1);
  ReefAngel.Relay.On( PowerCtlExp);
  ReefAngel.Relay.On( SaltUV);
  ReefAngel.Relay.DelayedOn( Skimmer,10 );
  ReefAngel.StandardHeater( Heater,750,790 );
  ReefAngel.StandardLights( Fuge_Light,21,0,11,0 );
  ReefAngel.StandardLights( FragLED1,12,0,21,0);
  ReefAngel.StandardLights( FragLED2,15,0,18,0);
  //if Display Water Level Sensor Active, then turn off Return pump
  if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Return_Pump);
  else ReefAngel.Relay.On(Return_Pump);
  //If Skimmate Water Level Sensor Active, then turn of Skimmer pump
  if (!ReefAngel.LowATO.IsActive()) ReefAngel.Relay.Off(Skimmer);
  else ReefAngel.Relay.On(Skimmer);
  //frag tank heater control with T2 probe
  if (ReefAngel.Params.Temp[T2_PROBE]>790) ReefAngel.Relay.Off( FragHeater );
  if (ReefAngel.Params.Temp[T2_PROBE]<750) ReefAngel.Relay.On( FragHeater );
  //Enter feeding mode to correspond with automatic feeder at 11AM and 2PM
  if(hour()==11 && minute()==0 && second()==0) ReefAngel.FeedingModeStart();
  if(hour()==14 && minute()==0 && second()==0) ReefAngel.FeedingModeStart();
  ReefAngel.Portal( "XXXXXXXXXXX" );
  ReefAngel.DDNS( "Reef" ); // Your DDNS is XXXXXXXXXXXXX
PostPosted: Wed Jul 04, 2018 7:10 pm
You don't have any box2 port in the code.
PostPosted: Thu Jul 05, 2018 5:16 pm
I added a test line, but still not working. What am I missing? Still not showing up in head unit either.
#define Dose1 Box2_Port1
ReefAngel.Relay.On( Dose1);
#define Extra1          2
#define Skimmer         3
#define Heater          4
#define GFO_Pump        6
#define Dose2           Box2_Port2
#define Dose3           Box2_Port3
#define Dose4           Box2_Port4
  ReefAngel.Portal( "" );
  ReefAngel.DDNS( "Reef" ); // Your DDNS is .myreefangel.com
PostPosted: Thu Jul 05, 2018 5:54 pm
When I load this code, I get the 3 relay screens on the head unit.
One thing I noticed is the DDNS line. Remove that. The server is not working with that feature anymore and that may be why the portal is not accepting your requests.
PostPosted: Mon Jul 09, 2018 4:14 am
Success! Thank you!
PostPosted: Mon Jul 09, 2018 4:43 am
here's an alternate way to do the dynamic dns for your controller.
https://r.tapatalk.com/shareLink?url=ht ... are_type=t
PostPosted: Mon Jul 09, 2018 5:26 pm
The dynamic DNS allows you to control via the universal app? However, the data on the universal app is still correct?
PostPosted: Mon Jul 09, 2018 6:41 pm
ucez wrote:The dynamic DNS allows you to control via the universal app? However, the data on the universal app is still correct?
Yes it should be.
I'm not sure you will need to use the dynamic dns with the universal app. I was sharing it in case you needed it (since you had been using the reefangel dynamic dns).
Previous
Return to Addons
