Water level sensor
mav3rick478
Water level sensor
Post by mav3rick478 »
Hey Roberto,
Is there any chance of making one of these? First time I've seen any controller use anything like ultra sound but when you think about it, it's pretty genius as long as it works properly.
https://www.ekoral.io/products/level-sensor.html
Sent from my Pixel XL using Tapatalk
lucho
Re: Water level sensor
Post by lucho »
Roberto, this would be great. I have a tall mixing container and the pressure water lever sensor reads 100 mid way through and above (too much pressure I guess), so I can either know if it is low or high, but not both. An ultrasonic water level sensor would be great. Is this possible?
Lucho, did you adjust your gain at all? That can increase the sensitivity of the measurement.
Sonic sensor would be cool :)
lucho
Post by lucho »
Yes, I did that, but did not help with the overall measurement. I guess it is too deep and therefore the pressure exceed the maximum. Unless I did something wrong. I think I read in a thread from you how to adjust the gain as I believe you were doing the same.
lucho
Post by lucho »
There is a guy in R2R who built an arduino controller and is using an ultrasonic water level sensor. Maybe we can ask him?
mav3rick478
Thanks to whoever asked the guy in R2R about what sensor he uses, HC-SR04 and I found a tutorial on how someone was using it. Quite interesting, would definitely have to figure out some sort of enclosure and holder but also how durable this unit is with indirect moisture exposure.
https://howtomechatronics.com/tutorials ... r-hc-sr04/
lucho
Post by lucho »
That was me asking the guy. I think this is promising. I am sure we can find an enclosure. Looking forward to trying this.
Thanks for the tutorial!
