problem rele raffreddamento
salve,
ho un problema con la funzione del raffreddamento.
metto che si attiva a 25.8 e si disattiva a 25. pero si stacca a 25.8 non so come risolvere grazie di seguito il codice:
ReefAngel.FeedingModePorts = Port4Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port5Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 294 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( T1_PROBE,Port1,220,252 );
ReefAngel.StandardATO( Port2,10 );
ReefAngel.Relay.DelayedOn( Port3,2 );
ReefAngel.PHControl( Port4,695,646 );
ReefAngel.StandardFan( T1_PROBE,Port8,258,255 );
ReefAngel.PWM.SetDaylight( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.PWM.SetActinic( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.Portal( "ROBBYMAN86" );
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
He said that have an issues with fan function although he programmed on 25,5 and off 25,0, once the Temperature go down 25,5 the fan stop . The fan start at 25,6
Inviato dal mio iPhone utilizzando Tapatalk
Re: problem rele raffreddamento
no one who can help me? I'm also trying to send a message to rimai, but I'm not authorized
I think it should be 255,258.
Did you use the wizard and entered the correct values?
thanks for the answer, I used the wizard and on turned on I put 25.8 and off at 25.5rimai wrote:I think it should be 255,258.
Here this picture
Inviato dal mio CLT-L09 utilizzando Tapatalk
The fan will turn on at 25.8 and continue to run until temperature lowers to 25.5. it will not turn on again until the temperature increases to 25.8 again. So there can be a 0.3 degree fluctuation of temperature.
So it should be, instead at 25.8 it goes outbinder wrote:The fan will turn on at 25.8 and continue to run until temperature lowers to 25.5. it will not turn on again until the temperature increases to 25.8 again. So there can be a 0.3 degree fluctuation of temperature.
hi, problem solved thanks to sebimme,
the problem was in the code that was created by the online widard, I redid the code with the arduino program and it went well,
but there is a problem I do not download the labels from the portal
Hi guys, please Roberto look at the code generatated with webwizard because if you program with it the standardfan function don’t work fine, while if you program with wizard inside arduino program it work good...
Any update
You said ...I’ll look into it....
Do you find the problem?
Ciao Roberto
Same error for ph controlled port continuously on off, like the chiller
Is the same of the first post by ROBBYMAN86
No. The code was correct.
Are you using it to increase or decrease pH?
Make sure the values are in the correct order.
To decrease ph, how you can see from the code the values are right but the port can’t control properly because the on off cicle are inconsistent with values
You are using the wrong function...
pH Control:
This function turns on/off at specific pH readings. The device that uses this function must increase pH. Example of device that may use this function is a Kalk based Doser.
CO2 Control:
This function turns on/off at specific pH readings. The device that uses this function must lower pH. Example of device that may use this function is a calcium reactor.
pH Control:
CO2 Control:
