problem rele raffreddamento
PostPosted: Tue Sep 11, 2018 4:21 pm
Ah, ok. The values have to be inverted position too.
PostPosted: Tue Sep 11, 2018 5:53 pm
No. The code was correct.
Are you using it to increase or decrease pH?
Make sure the values are in the correct order.
PostPosted: Tue Sep 11, 2018 10:51 pm
To decrease ph, how you can see from the code the values are right but the port can’t control properly because the on off cicle are inconsistent with values
Inviato dal mio iPhone utilizzando Tapatalk
PostPosted: Tue Sep 11, 2018 10:59 pm
You are using the wrong function...
pH Control:
This function turns on/off at specific pH readings. The device that uses this function must increase pH. Example of device that may use this function is a Kalk based Doser.
CO2 Control:
This function turns on/off at specific pH readings. The device that uses this function must lower pH. Example of device that may use this function is a calcium reactor.
Previous
Return to Standard
