No problem. I appreciate any help you can give me.lnevo wrote:Ok give me a little time and try to parse through your code and then see what we can do.
Lee's Feature Complete PDE
Re: Lee's Feature Complete PDE
Ok, definitely need to think about how I'm going to best do this... are you looking to acclimate all 3 spectrums? I think I have to abstract the code a bit so you can pass some parameters to how each channel is being acclimated. It may be an improvement on my code as well. Give me some more time.
I usually run my red/green/uv lights with my actinic channel. So i would just need to make sure they aren't at 100% when the rest of the lights are at 50%. If it makes it easier to add the sunlocation code to get this to work it can be added, I have been planning on using that code, just haven't had a chance to get it coded in yet.
I ran my 6-channel LEDs on the pwm channels. I ran my reds and greens with the white channel and UV with my blues. Sunrise location is within my code.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Hi,
Im new to RA but not so new to Arduinos.
Running the Mac Arduino IDE from the RA website, 1.0.1, with Lee's code and I am receiving many errors when i try to verify the sketch. All the library folders have been copied into place.
I've also tried many other codes from the forums and receive many errors on them too. Maybe I'm missing something for setting the RA software initially?
Can some one point me in the right direction of RA's sample code? I don't see it anywhere to download and its not included in the mac download.
Many thanks
Many thanks
Number of Relay Expansion Modules: 3
Number of Menu Options: 9
Reef_Angel_Lee.cpp: In function 'void setup()':
Reef_Angel_Lee:256: error: 'class ReefAngelClass' has no member named 'InitMenu'
Reef_Angel_Lee:281: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee.cpp: In function 'void CheckPower()':
Reef_Angel_Lee:341: error: 'class RelayClass' has no member named 'IsRelayPresent'
Reef_Angel_Lee:354: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:359: error: 'class RelayClass' has no member named 'IsRelayPresent'
Reef_Angel_Lee.cpp: In function 'void SetSun()':
Reef_Angel_Lee:434: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:439: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:440: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:442: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:443: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:448: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:449: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:451: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:452: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:457: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:458: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:460: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:461: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:466: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:467: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:469: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:470: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:475: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:476: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:478: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:479: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void SetMoon()':
Reef_Angel_Lee:517: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:518: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:523: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:524: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:528: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:529: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:533: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:534: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:538: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:539: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void FillInMoon()':
Reef_Angel_Lee:554: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:557: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:558: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:559: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:560: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:562: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:563: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void AcclimateLED()':
Reef_Angel_Lee:575: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:577: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:579: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:581: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void LEDPresets()':
Reef_Angel_Lee:604: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:605: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:606: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:607: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:608: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:609: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void UpdateLED()':
Reef_Angel_Lee:732: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:733: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:734: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:735: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:736: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:737: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:741: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:742: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:743: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:744: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void SetTide()':
Reef_Angel_Lee:759: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee.cpp: In function 'void SetRF()':
Reef_Angel_Lee:769: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:770: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:786: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:787: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:797: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee.cpp: In function 'void RFCustom()':
Reef_Angel_Lee:839: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee:843: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:848: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:853: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:858: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:863: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:868: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:924: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee:925: error: 'class ReefAngelClass' has no member named 'RF'
Reef_Angel_Lee.cpp: In function 'void CheckATO()':
Reef_Angel_Lee:936: error: 'class ReefAngelClass' has no member named 'WaterLevel'
Reef_Angel_Lee:942: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee.cpp: In function 'void RefillATO()':
Reef_Angel_Lee:965: error: 'class ReefAngelClass' has no member named 'WaterLevel'
Reef_Angel_Lee.cpp: In function 'void LogFeedings()':
Reef_Angel_Lee:1026: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee.cpp: In function 'void adjustAlk()':
Reef_Angel_Lee:1152: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee:1153: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee:1158: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee:1166: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee.cpp: In function 'void LogDosingPumps()':
Reef_Angel_Lee:1193: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee:1199: error: 'class ReefAngelClass' has no member named 'CustomVar'
Reef_Angel_Lee.cpp: In function 'void LockPorts()':
Reef_Angel_Lee:1301: error: 'class ReefAngelClass' has no member named 'OverridePortsE'
Reef_Angel_Lee:1302: error: 'class ReefAngelClass' has no member named 'OverridePortsE'
Reef_Angel_Lee:1304: error: 'class ReefAngelClass' has no member named 'OverridePortsE'
Reef_Angel_Lee:1305: error: 'class ReefAngelClass' has no member named 'OverridePortsE'
Reef_Angel_Lee.cpp: In function 'void DailyReport()':
Reef_Angel_Lee:1332: error: 'class ReefAngelClass' has no member named 'WaterLevel'
Reef_Angel_Lee.cpp: In function 'void MenuEntry8()':
Reef_Angel_Lee:1402: error: 'class ReefAngelClass' has no member named 'SetupCalibrateWaterLevel'
Reef_Angel_Lee.cpp: In function 'void DrawParams(int, int)':
Reef_Angel_Lee:1467: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1469: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee.cpp: In function 'void DrawStatus(int, int)':
Reef_Angel_Lee:1478: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1479: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1496: error: 'class ReefAngelClass' has no member named 'WaterLevel'
Reef_Angel_Lee:1497: error: 'class ReefAngelClass' has no member named 'WaterLevel'
Reef_Angel_Lee:1504: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1505: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1506: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1507: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1508: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1509: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1510: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1511: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1512: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee:1513: error: 'class RA_NokiaLCD' has no member named 'DrawLargeText'
Reef_Angel_Lee.cpp: In function 'void DrawSunMoon(int, int)':
Reef_Angel_Lee:1562: error: 'MoonPhaseLabel' was not declared in this scope
Reef_Angel_Lee:1567: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:1568: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee.cpp: In function 'void DrawRelays(int, int)':
Reef_Angel_Lee:1580: error: 'class RelayClass' has no member named 'RelayDataE'
Reef_Angel_Lee:1581: error: 'class RelayClass' has no member named 'RelayMaskOffE'
Reef_Angel_Lee:1582: error: 'class RelayClass' has no member named 'RelayMaskOnE'
Reef_Angel_Lee:1586: error: 'class RelayClass' has no member named 'RelayDataE'
Reef_Angel_Lee:1587: error: 'class RelayClass' has no member named 'RelayMaskOffE'
Reef_Angel_Lee:1588: error: 'class RelayClass' has no member named 'RelayMaskOnE'
Reef_Angel_Lee.cpp: In function 'void Strike()':
Reef_Angel_Lee:1899: error: 'class ReefAngelClass' has no member named 'PWM'
Reef_Angel_Lee:1906: error: 'class ReefAngelClass' has no member named 'PWM'
It looks like it's not finding the libraries. You copied them to ~/Documents/Arduino?
The example code should be visible in the menus if the folder is in the right spot.
They are in the correct library folder. I've looked through the library folders and none of them contain example files.lnevo wrote:It looks like it's not finding the libraries. You copied them to ~/Documents/Arduino?
Going to try the windows software next.
Something is either wrong in your arduino gui settings, i would check the preferences, as you said you arent new to arduino so maybe its referencing a different folder in your prefs. The arduino folder that comes on the mac image should contain the examples, wizard, and the feature directory not just the libraries. The errors you are getting are 100% telling me its not finding the libraries.
Maybe I'm looking in the wrong place here, I downloaded the libraries from GitHub as there were no libraries included in the mac img download. Just a help doc, wifi utility and Arduino IDE. Which when run was using my library folder in my documents. I can see the libraries listed when going to sketch, include library....lnevo wrote:Something is either wrong in your arduino gui settings, i would check the preferences, as you said you arent new to arduino so maybe its referencing a different folder in your prefs. The arduino folder that comes on the mac image should contain the examples, wizard, and the feature directory not just the libraries. The errors you are getting are 100% telling me its not finding the libraries.
Yeah thats the problem if you only downloaded the libraries. In the dmg file there should be an Arduino folder that you're supposed to drag to Documents. If you already had that folder then maybe it dropped into there. Either way check the dmg again and grab the contents of the Arduino folder and make sure they are in the documents/arduino folder.
You may also want to remove the prefernces file for the arduino ide just to make sure nothing was lingering.
And for the record, I made this same mistake when I installed
Ok I found them in the img. My fault, I hadn't actually clicked on the 'folder' which contains all the files needed. As the icon is what looks like a help doc for Arduino I hadn't clicked on it. Sorry for the confusion. Will try again later on.
On another note, I installed the 1.6.8 dev copy on windows and that's working ok so far.
Thanks for your help
Cool. Like I said, been there done that. Easy mistake glad that helped.
If I try to compile your project with the standard RA its too big but no other errors, however when choosing the RA+ I see lots of Ethernet errors.
This is on the 1.6.8 so my guess is the library is out of date.
C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\Ethernet.cpp: In member function 'void EthernetClass::begin(uint8_t*, IPAddress, IPAddress, IPAddress, IPAddress)':
C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:64:39: error: no matching function for call to 'W5100Class::setIPAddress(IPAddress::<anonymous union>&)'
W5100.setIPAddress(local_ip._address);
C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:64:39: note: candidate is:
In file included from C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:1:0:
C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\utility/w5100.h:392:6: note: void W5100Class::setIPAddress(uint8_t*)
void W5100Class::setIPAddress(uint8_t *_addr) {
C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\utility/w5100.h:392:6: note: no known conversion for argument 1 from 'IPAddress::<anonymous union>' to 'uint8_t* {aka unsigned char*}'
C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:65:38: error: no matching function for call to 'W5100Class::setGatewayIp(IPAddress::<anonymous union>&)'
W5100.setGatewayIp(gateway._address);
C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:65:38: note: candidate is:
C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\utility/w5100.h:368:6: note: void W5100Class::setGatewayIp(uint8_t*)
void W5100Class::setGatewayIp(uint8_t *_addr) {
C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\utility/w5100.h:368:6: note: no known conversion for argument 1 from 'IPAddress::<anonymous union>' to 'uint8_t* {aka unsigned char*}'
C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:66:38: error: no matching function for call to 'W5100Class::setSubnetMask(IPAddress::<anonymous union>&)'
W5100.setSubnetMask(subnet._address);
C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\Ethernet.cpp:66:38: note: candidate is:
C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\utility/w5100.h:376:6: note: void W5100Class::setSubnetMask(uint8_t*)
void W5100Class::setSubnetMask(uint8_t *_addr) {
C:\Users\danstevens\Documents\Arduino\libraries\Ethernet\utility/w5100.h:376:6: note: no known conversion for argument 1 from 'IPAddress::<anonymous union>' to 'uint8_t* {aka unsigned char*}'
The libraries dont work with the 1.6.8, Roberto posted a beta version with the dev library.
You have to use the Arduino release in the dmg package.
It's compiled differently from the standard arduino ide so it allows to use the wizard and the other tools.
Roberti what happened with the dev release of the new ide csn't find the post?
At the time i was using the 1.6.8 dev RA package on windows.rimai wrote:You have to use the Arduino release in the dmg package.
Was just checking out the coordinates my Sunrise/Sunset was linked to and then was just curious how accurate the calculations are. While not exact, they're pretty damn close. I'm satisfied
What my RA says
Sunrise: 10:10
Sunset: 23:33
What timeanddate says
Sunrise 6:02 AM
Sunset 7:27 PM
What my RA says
Sunrise: 10:10
Sunset: 23:33
Sunrise 6:02 AM
Sunset 7:27 PM
Just posted my latest code. Did a lot of improvement to the CheckATO function that measures the rate of evaporation by keeping a rolling 12 hour average of the % drop in my ATO reservoir. I did this so I can better set alerts if my ATO is either not dropping as expected or is dropping too fast.
I've been trying to adapt your code to my setup and am getting a "'class ReefAngelClass' has no member named 'LCD'" error in the validation process. Is this related to the NokiaLCD.h? I'm not sure how to continue from this point.
Edit: reinstalled arduino software and it seems to be fine now.
OK, new stumbling block. I have two lights with two channels each (SBReef 16"). I have channel 11 running the actinics and 12 running the whites off of the relay dimming ports. I'm not sure how to make the changes to adapt your code that uses the dimming expansion to the relay box dimming outputs that I'm using (getting a 'class RA_PWMClass' has no member named 'Channel11PWMSlope' error). Can you point me in the right direction?
#include <SunLocation.h>
// Define Custom Memory Locations
#define Mem_I_Latitude 108
#define Mem_I_Longitude 110
#define Mem_B_AcclRiseOffset 112
#define Mem_B_AcclSetOffset 113
#define Mem_B_AcclDay 114
#define Mem_B_LightMode 160
#define Mem_B_LightOffset 161
#define Mem_I_RiseOffset 162
#define Mem_I_SetOffset 164
#define Mem_B_AcclActinicOffset 166
#define Mem_B_AcclDaylightOffset 167
#define Mem_B_LightsOffPerc 171
#define Mem_B_EnableStorm 178
#define Mem_B_PrintDebug 198
#define Mem_B_ResetMemory 199
void init_memory() {
// Initialize Custom Memory Locations
InternalMemory.write_int(Mem_I_Latitude,21);
InternalMemory.write_int(Mem_I_Longitude,-73);
InternalMemory.write(Mem_B_AcclRiseOffset,4);
InternalMemory.write(Mem_B_AcclSetOffset,2);
InternalMemory.write(Mem_B_AcclDay,0);
InternalMemory.write(Mem_B_LightOffset,20);
InternalMemory.write(Mem_B_LightMode,1);
InternalMemory.write_int(Mem_I_RiseOffset,-1);
InternalMemory.write_int(Mem_I_SetOffset,-1);
InternalMemory.write(Mem_B_AcclActinicOffset,100);
InternalMemory.write(Mem_B_AcclDaylightOffset,100);
InternalMemory.write(Mem_B_LightsOffPerc,1);
InternalMemory.write(Mem_B_EnableStorm,true);
InternalMemory.write(Mem_B_ResetMemory,false);
// Define Relay Ports by Name
#define Skimmer 1
#define Heater 2
#define Reactor 3
#define Refugium 4
#define Daylight 5
#define Actinic 6
#define Return 7
#define ATO 8
#define Wave 1 Box1_Port1
#define Wave 2 Box1_Port2
#define Unused Box1_Port3
#define Unused Box1_Port4
#define Unused Box1_Port5
#define Unused Box1_Port6
#define Unused Box1_Port7
#define Utility Box1_Port8
// Custom classes
SunLocation sun;
// For Cloud and preset code
int DaylightPWMValue=0;
int ActinicPWMValue=0;
int DaylightPWMValue0=0; // For cloud code, channel 0
int DaylightPWMValue2=0; // For cloud code, chennel 2
int ActinicPWMValue1=0; // For cloud code, channel 0
int ActinicPWMValue3=0; // For cloud code, chennel 2
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit;
ReefAngel.LightsOnPortsE[0] = Port3Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port2,796,798 );
ReefAngel.StandardLights( Port4,18,0,12,0 ); // Refugium light
ReefAngel.StandardATO( Port8,1200 );
ReefAngel.Wavemaker( Box1_Port1,60 );
ReefAngel.Relay.Set( Box1_Port2, !ReefAngel.Relay.Status( Box1_Port1 ) );
// Lighting and Flow
SetSun(); // Setup Sun rise/set lighting
AcclimateLED(); // Apply acclimation dimming
LEDPresets();
CheckCloud(); // Check for cloud and lightning.
UpdateLED();
ReefAngel.Portal("madweazl");
void SetSun() {
// Start acclimation routine
int acclRiseOffset=InternalMemory.read(Mem_B_AcclRiseOffset)*60;
int acclSetOffset=InternalMemory.read(Mem_B_AcclSetOffset)*60;
byte acclDay=InternalMemory.read(Mem_B_AcclDay);
// See if we are acclimating corals and decrease the countdown each day
static boolean acclCounterReady=false;
if (now()%SECS_PER_DAY!=0) acclCounterReady=true;
if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) {
acclDay--;
InternalMemory.write(Mem_B_AcclDay,acclDay);
// End acclimation
// Add some customizable offsets
sun.Init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
int riseOffset=InternalMemory.read_int(Mem_I_RiseOffset);
int setOffset=InternalMemory.read_int(Mem_I_SetOffset);
sun.SetOffset(riseOffset,(acclDay*acclRiseOffset),setOffset,(-acclDay*acclSetOffset)); // Bahamas
sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
byte lightOffset=InternalMemory.read(Mem_B_LightOffset); // left right separation
byte actinicOffset=InternalMemory.ActinicOffset_read();
// Make sure light resets to zero at night.
for(int i=0;i<4;i++) { ReefAngel.PWM.SetChannel(i,0); }
switch(InternalMemory.read(Mem_B_LightMode)) {
case 0: {
// Daylights
ReefAngel.PWM.Channel11PWMSlope(lightOffset,0);
// Actinics
ReefAngel.PWM.Channel12PWMSlope(actinicOffset+lightOffset,actinicOffset);
break;
case 1: {
// Daylights
ReefAngel.PWM.Channel11PWMParabola(lightOffset,0);
// Actinics
ReefAngel.PWM.Channel12PWMParabola(actinicOffset+lightOffset,actinicOffset);
break;
case 2: {
// Daylights
ReefAngel.PWM.Channel11PWMSmoothRamp(lightOffset,0);
// Actinics
ReefAngel.PWM.Channel12PWMSmoothRamp(actinicOffset+lightOffset,actinicOffset);
break;
case 3: {
// Daylights
ReefAngel.PWM.Channel11PWMSigmoid(lightOffset,0);
// Actinics
ReefAngel.PWM.Channel12PWMSigmoid(actinicOffset+lightOffset,actinicOffset);
break;
case 4: { // Reverse the actinics in the morning
// Daylights
ReefAngel.PWM.Channel11PWMParabola(lightOffset+actinicOffset,0);
// Actinics
ReefAngel.PWM.Channel12PWMParabola(lightOffset,actinicOffset);
break;
void AcclimateLED() {
if (acclDay > 0) {
float acclActinicOffset=acclDay*(40.95*(((float)InternalMemory.read(Mem_B_AcclActinicOffset)/100)));
float acclDaylightOffset=acclDay*(40.95*((float)InternalMemory.read(Mem_B_AcclDaylightOffset)/100));
float endPerc;
endPerc=40.95*InternalMemory.PWMSlopeEnd1_read();
ReefAngel.PWM.SetChannelRaw(1,map(ReefAngel.PWM.GetChannelValueRaw(1),0,endPerc,0,endPerc-acclActinicOffset));
endPerc=40.95*InternalMemory.PWMSlopeEnd3_read();
ReefAngel.PWM.SetChannelRaw(3,map(ReefAngel.PWM.GetChannelValueRaw(3),0,endPerc,0,endPerc-acclActinicOffset));
endPerc=40.95*InternalMemory.PWMSlopeEnd0_read();
ReefAngel.PWM.SetChannelRaw(0,map(ReefAngel.PWM.GetChannelValueRaw(0),0,endPerc,0,endPerc-acclDaylightOffset));
endPerc=40.95*InternalMemory.PWMSlopeEnd2_read();
ReefAngel.PWM.SetChannelRaw(2,map(ReefAngel.PWM.GetChannelValueRaw(2),0,endPerc,0,endPerc-acclDaylightOffset));
#define LED_1to1 Box1_Port1
#define LED_4to1 Box1_Port2
#define LED_3to1 Box1_Port3
#define LED_2to1 Box1_Port4
#define LED_BLUE Box1_Port5
#define LED_WHITE Box1_Port6
#define LED_STORM Box1_Port8
void resetRelayBox(byte ID) {
// toggle all relays except for the one selected
for (int i=Box1_Port1;i<=Box1_Port4;i++) {
if (i!=ID) ReefAngel.Relay.Auto(i);
void LEDPresets() {
static byte lastPreset=0;
DaylightPWMValue0=ReefAngel.PWM.GetChannelValueRaw(0);
ActinicPWMValue1=ReefAngel.PWM.GetChannelValueRaw(1);
DaylightPWMValue2=ReefAngel.PWM.GetChannelValueRaw(2);
ActinicPWMValue3=ReefAngel.PWM.GetChannelValueRaw(3);
DaylightPWMValue=ReefAngel.PWM.GetDaylightValueRaw();
ActinicPWMValue=ReefAngel.PWM.GetActinicValueRaw();
if (ReefAngel.Relay.isMaskOn(LED_1to1)) {
if (lastPreset!=1) resetRelayBox(LED_1to1);
DaylightPWMValue0=90*40.95;
ActinicPWMValue1=10*40.95;
DaylightPWMValue2=90*40.95;
ActinicPWMValue3=10*40.95;
lastPreset=1;
if (ReefAngel.Relay.isMaskOff(LED_1to1)) {
if (lastPreset!=2) resetRelayBox(LED_1to1);
DaylightPWMValue0=10*40.95;
ActinicPWMValue1=90*40.95;
DaylightPWMValue2=10*40.95;
ActinicPWMValue3=90*40.95;
lastPreset=2;
if (ReefAngel.Relay.isMaskOn(LED_2to1)) {
if (lastPreset!=3) resetRelayBox(LED_2to1);
DaylightPWMValue0=60*40.95;
ActinicPWMValue1=40*40.95;
DaylightPWMValue2=60*40.95;
ActinicPWMValue3=40*40.95;
lastPreset=3;
if (ReefAngel.Relay.isMaskOff(LED_2to1)) {
if (lastPreset!=4) resetRelayBox(LED_2to1);
DaylightPWMValue0=40*40.95;
ActinicPWMValue1=60*40.95;
DaylightPWMValue2=40*40.95;
ActinicPWMValue3=60*40.95;
lastPreset=4;
if (ReefAngel.Relay.isMaskOn(LED_3to1)) {
if (lastPreset!=5) resetRelayBox(LED_3to1);
DaylightPWMValue0=75*40.95;
ActinicPWMValue1=25*40.95;
DaylightPWMValue2=75*40.95;
ActinicPWMValue3=25*40.95;
lastPreset=5;
if (ReefAngel.Relay.isMaskOff(LED_3to1)) {
if (lastPreset!=6) resetRelayBox(LED_3to1);
DaylightPWMValue0=25*40.95;
ActinicPWMValue1=75*40.95;
DaylightPWMValue2=25*40.95;
ActinicPWMValue3=75*40.95;
lastPreset=6;
if (ReefAngel.Relay.isMaskOn(LED_4to1)) {
if (lastPreset!=7) resetRelayBox(LED_4to1);
DaylightPWMValue0=80*40.95;
ActinicPWMValue1=20*40.95;
DaylightPWMValue2=80*40.95;
ActinicPWMValue3=20*40.95;
lastPreset=7;
if (ReefAngel.Relay.isMaskOff(LED_4to1)) {
if (lastPreset!=8) resetRelayBox(LED_4to1);
DaylightPWMValue0=20*40.95;
ActinicPWMValue1=80*40.95;
DaylightPWMValue2=20*40.95;
ActinicPWMValue3=80*40.95;
lastPreset=8;
if (ReefAngel.Relay.isMaskOn(LED_BLUE)) {
if (lastPreset!=9) resetRelayBox(LED_BLUE);
lastPreset=9;
if (ReefAngel.Relay.isMaskOff(LED_BLUE)) {
if (lastPreset!=10) resetRelayBox(LED_BLUE);
ActinicPWMValue1=0;
ActinicPWMValue3=0;
lastPreset=10;
if (ReefAngel.Relay.isMaskOn(LED_WHITE)) {
if (lastPreset!=11) resetRelayBox(LED_WHITE);
ActinicPWMValue1=0;
ActinicPWMValue3=0;
lastPreset=11;
if (ReefAngel.Relay.isMaskOff(LED_WHITE)) {
if (lastPreset!=12) resetRelayBox(LED_WHITE);
lastPreset=12;
// Write updated values to the channels
void UpdateLED() {
ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);
ReefAngel.PWM.SetChannelRaw(1,ActinicPWMValue1);
ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);
ReefAngel.PWM.SetChannelRaw(3,ActinicPWMValue3);
ReefAngel.PWM.SetDaylightRaw(DaylightPWMValue);
ReefAngel.PWM.SetActinicRaw(ActinicPWMValue);
byte LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
if (ReefAngel.PWM.GetChannelValueRaw(0)>=LightsOffPerc) ReefAngel.Relay.On(Daylight); else ReefAngel.Relay.Off(Daylight);
if (ReefAngel.PWM.GetChannelValueRaw(1)>=LightsOffPerc) ReefAngel.Relay.On(Actinic); else ReefAngel.Relay.Off(Actinic);
if (ReefAngel.PWM.GetChannelValueRaw(2)>=LightsOffPerc) ReefAngel.Relay.On(Daylight); else ReefAngel.Relay.Off(Daylight);
if (ReefAngel.PWM.GetChannelValueRaw(3)>=LightsOffPerc) ReefAngel.Relay.On(Actinic); else ReefAngel.Relay.Off(Actinic);
// Menu Code
void MenuEntry1() {
ReefAngel.FeedingModeStart();
void MenuEntry2() {
void MenuEntry3() {
ReefAngel.ATOClear();
void MenuEntry4() {
ReefAngel.OverheatClear();
void MenuEntry5() {
ReefAngel.SetupCalibratePH();
void MenuEntry6() {
ReefAngel.SetupDateTime();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 7
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
// In this example, start cloud after noon
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(21,00)
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
// of effects or unforseen result could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
// 250 minutes (or 500 minutes) can fit in that 510 minutes window.
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Calm, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = {Mega2,Mega,Mega};
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
// Send the trigger
Strike();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
Strike();
break;
case Fast:
Strike();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=4095;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
/*ReefAngel.LCD.Clear(255,0,120,132,132);
ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
int x=0;
else x=17;
//ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
else x=35;
//ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
//ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
else x=57;
//ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
else x=75;
//ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
// Flash on
int newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*0)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
Wire.write(0x8+(4*2)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
// Flash off. Return to baseline.
newdata=ReefAngel.PWM.GetChannelValueRaw(0); // Use the channel number you're flashing here
Wire.beginTransmission(0x40); // Same as above
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset(); // Reset watchdog timer to avoid re-boots
cstart*=60;
cend*=60;
if (n>cend) return (int) PWMStart;
If you have Channel 11 and 12 then I'm guessing you have a custom 16 channel module?
If so then the correct function to use instead of:
Use:
ReefAngel.PWM.SIXTEENChannelPWMSlope(11, 0, 100, 60, lightOffset, 0); // Channel / Start % / End % / Duration / PreOffset / PostOffset
There's no function to call this from direct memory
Use:
No 16ch module, just the original relay box (channel 11 and 12 in the manual). I believe you call them with "actinic" and "daylight" based on the standard code but I wasnt positive on how to tackle that.lnevo wrote:If you have Channel 11 and 12 then I'm guessing you have a custom 16 channel module?
Use:
Would ReefAngel.PWM.SetActinic( PWMSlope(10, 10, 60, lightOffset, 0) ); work? My lights only dim to 10%.
I had a question regarding the setRF() class in Lee's complete PDE. IIRC, this class is suppose to go into NTM mode after a feeding mode, and then back to the mode that it was in prior to being put into feeding mode? I wasn't able to tell where the code puts it back the original mode prior to feeding was enabled.
Tim
Tim
vtMode is being set at the top of the function by reading the InternalMemory variables for these settings. Then once the delay is set, then it get's picked up by the if and gets set to SmartNTM which finally get's written with RF.SetMode at the end of the function.
Okay cool. Thanks lnevo for clearing that up for me. I thought that once it set the vtMode to NTM in the if statement I didn't see anywhere in the function that would reset it back to a previous setting.
Tim
Tim
So after a very long hiatus, I've gotten back to my tank....
I had shorted a few outlets which I managed by shuffling a few outlets and taking my dosers offline. They weren't doing anything anyway so no big loss. I have now come to discover that this was also screwing with my ph reading so I finally swapped the box out.
I also took care of an issue with my Auto-Water-Change pump which was taking out more water than it was putting in. I was trying to compensate with extra salinity, but it looks like it was like a 60% delta. Since the AWC pump has 3 peristaltic heads and I was only using 2, I moved the new water line to a different head and now it's spot on exact.
I installed a Klir Di-4 filter in my sump and so far it's fantastic. The only issue I had was that the water level when the system was down or in feeding mode would cause the water level to trigger the optical sensor and the roll to continue forever. Problem solved by putting the power on the same outlet as my skimmer.
I detected a leak in my RO filter. Looks like the teflon wore off in the fitting. In order to not have to disassemble the entire thing, I will cut it in half and replace it with a straight fitting. Waiting for the part.
My MP40QWD wet side magnet exploded, so I ordered new ones and managed to get an RMA on it anyway That should be in shortly.
I thought I had a leak on my tank, the carpet all around my fish cabinet and tank is soaked... turned out to be my AC dripping... I now have a new AC unit. Now that the relay box was replaced, I connected back my fan array for cooling the tank. Temp was up to 84 degrees on my tank.
Lastly, I changed the bulkheads on my clearwater algae scrubber to use uniseals giving more room inside the scrubber for the mesh to hang and also to address a small leak I had there. It was impossible to tighten the bulkhead with the limited space. Much better now
My water has never been clearer. Having an automated 5 micon filter sock is fantastic I highly recommend the Klir filter.
nice.
sounds like you have had some experiences to say the least least.
glad to hear that you are back to your tank.
