new equipment
bluwinghawk
new equipment
Post by bluwinghawk »
like to say hi to all first not sure if this right spot cant pm any1 yet how updated is online store and is that the only way to make purchase or is there another option like phone orders sorry for any inconvience
thanks Rick
Re: new equipment
I believe online ordering is the only way to do it. I'm pretty sure the online store is up to date. They are pretty accurate on availability and everything.
dedvalson
Re: new equipment
Post by dedvalson »
I just wanted to add,
I have placed several online orders from Reef Angel. Every order has shipped quickly and accurately. There is no need to be concerned about their online order system.
Don
bluwinghawk
Re: new equipment
thanks for the fast replys i just wanted to order off the menu per say and i couldnt pm yet lol but i can now put order in for RA and wifi and saltlity
bluwinghawk
Re: new equipment
ok everything ordered anything i need to do while i sit and wait for the mail man lol
bluwinghawk
Re: new equipment
ok got RA yesterday wifi just 15min ago been looking thu post not sure were to start but down loaded install for wifi cable drivers do i set RA to tank before pluging in or do i down load info first can some one point me in the right spot like to get this bad boy up an running thanks in advance
Rick
Seedlessone
Re: new equipment
Post by Seedlessone »
Forget about the wifi for now. Read the getting started guide. Download all the software you need. Make sure net frame work 3.0 is installed on your computer. Use the updater tool to update to development libraries. I would then try to just upload a simple code using Ragen. there is a lot of good info posted on these forums and some great people to help out. Have fun.
bluwinghawk
Re: new equipment
ok i think im doing that now lol but i thought i read a post that said to do wifi together its easier but to late now hope this works lol
bluwinghawk
Re: new equipment
ok im lost just had me upload Arduino file where is the updater tool and down loads go to guide links dont work where do i go
bluwinghawk
Re: new equipment
bb im clearining all programs and restoring pc. com 7, 8, or 9 , not being picked up start from scratch wish i new were to get downloads?
bluwinghawk
Re: new equipment
duh found them at store what do i download first or do i down load everything for windows?
Re: new equipment
Reef Angel Installer (for windows). Download and install first.
RAGen. Download and install next. Install Development Libraries during installation.
bluwinghawk
Re: new equipment
wont let me do RAG now im downloading net 4 ugh
Re: new equipment
bluwinghawk wrote:wont let me do RAG now im downloading net 4 ugh
RAGen should have all the requirements built into the installer. I doesn't require anything else provided you are running Windows XP or later.
bluwinghawk
Re: new equipment
ok unziped RAGen have updated libary files do i install these onto the ra or just pc?
bluwinghawk
Re: new equipment
this is getting to be really fustrating it all sounded real simple plug in and go i have no idea i need to walk awAy
Seedlessone
Re: new equipment
I had to install netframe3.0 to get Ragen to work for me. I was running a fresh copy of xp though.
Seedlessone
Re: new equipment
bluwinghawk wrote:ok unziped RAGen have updated libary files do i install these onto the ra or just pc?
What happens when you open Ragen? Have you tired to create a code file in Ragen?
Re: new equipment
The download files can be found on the website:
http://reefangel.com/Download.ashx
You need:
Reef Angel Installer: http://reefangel.com/files/ReefAngelInstaller.exe
RAGen: https://github.com/downloads/curtbinder ... taller.exe
Install both of them.
bluwinghawk
Re: new equipment
i already did the installer 2x
its when i try RAGen i get this and i even ignored it (RAGen-v110-v08519 Installer.exe is not commonly downloaded and could harm your computer.)
Re: new equipment
That's your anti-virus doing that.
bluwinghawk
Re: new equipment
ok watched youtube again the ragen i have looks different have no memory tab up top went into menu generated like on first youtube but cant find it in andrino only get mem.test wire time no generation code
cant spend another day what am i doing wrong
rossbryant1956
Re: new equipment
Post by rossbryant1956 »
In the current version of RAGen, the memory button is located on the button "controller." Then click "internal memory." Set the settings like you want then click "generate." Watch the bottom left corner of that screen and it will tell you the name of the file that was created for you.
Then go into Arduino, open that file name, should be labeled "memorytimedatestamp" or something like that. Upload that.
Search for my post labeled "click, click, click" when I suffered the same problems as you.
You can do this...it can be frustrating for us non-programmers out there, but it can be done.
bluwinghawk
Re: new equipment
hi all just checking in havent been able to get full use from angle yet pc software promblem my son inlaw found so been working on tank setup but what i did see working with angle was SWEET
