Alexa Control
Seedlessone
Alexa Control
Has anyone figured out a way to say simple commands to the RA via Echo? I would like to get some simple commands working. Mainly, feed mode. Maybe using the web command, /mw?
Re: Alexa Control
I don't have one, but Google search leads to creating an Alexa skill, which requires you to sign up for a dev account.
After signing up and creating the skill, you should be able to send commands to RA
Seedlessone
Re: Alexa Control
That would be sweet. Would make life so much easier. I could ask my wife to feed the fish now
luckybaker4
Re: Alexa Control
Seedlessone - are you working on this? I was going to pick this up as a side project but ran across this thread.
Zexston
Re: Alexa Control
Don’t know if this helps, but it came across my YouTube feed:
https://youtu.be/3TaLlI4BqeI
It shows the setup process for an Alexa skill and RPi out the serial port.
Re: Alexa Control
Who wants to beta test?
pm me your email address that is linked to your alexa account.
Seedlessone
Re: Alexa Control
Roberto does it again. First controller on the market with Alexa support?
Its working great on my end so far!! Thanks
Seedlessone
Re: Alexa Control
The only command that hasn't worked yet, is "Alexa what is the temperature of ____". I've change the probe name a few times to make sure the echo could understand me. Its named "fish tank"now and she has no clue what I'm asking. LOL
Seedlessone
Re: Alexa Control
Hmmm. Just changed probe 1 name to display tank.rimai wrote:I used display tank with success
"Alexa, what is the temperature of display tank?"
"Sorry, I didn't find display tank"
Re: Alexa Control
Did you change it on the portal or the Alexa app?
When I changed names, I changed them in the portal then I went to Alexa app and deleted the old name device. Discovered devices again to find the one you deleted. It will come with the new name.
I didn't test if there was an easier way.
Seedlessone
Re: Alexa Control
Good to go now. Didnt even think about pulling the new device name into alexa app....duh!rimai wrote:Did you change it on the portal or the Alexa app?
Re: Alexa Control
I know you can change names on the Alexa app, and theoretically it should work without having to rename in the portal, but I didn't test.
Re: Alexa Control
The only thing I have programmed right now is:
Turn on ...
Turn off ...
Set ... to auto
What is the temperature of ...
Turn on ...
Turn off ...
Set ... to auto
- mav3rick478
Re: Alexa Control
I know this is an Alexa thread but is there any chance of the RA working with Google Assistant?
Sent from my Pixel XL using Tapatalk
Re: Alexa Control
I would need to look into how google handles everything.
Don't hold your breath though. It may take a while.
Seedlessone
Re: Alexa Control
Certainly not trying to rush, but what sort of timeline do you have on feeding and water change mode?rimai wrote:The only thing I have programmed right now is:
Turn on ...
Turn off ...
Set ... to auto
So far it has been 100%!!
Re: Alexa Control
Can you test feeding and water change mode?
You will need to discover devices again to enable the two modes.
89delta
Re: Alexa Control
So i'm trying to enable the skill and after the amazon login screen it takes me to the authorization page i guess and it remains blank. Any ideas?
Re: Alexa Control
I wasn't able to replicate.
I tried it on a new phone with a new amazon account.
icecool2
Re: Alexa Control
I just tried this myself and ran into an error trying to login.
I confirmed my username and password were correct by logging into the forum to double check. Same error comes up using Alexa app, Safari and Firefox. This is on ios12, not that I think that’s the issue.
icecool2
Re: Alexa Control
Just tried again hoping this would clear itself.... no dice. Still the same issue.
Re: Alexa Control
I just tested the amazon/reef angel skill linking and it went through just fine.
Try resetting the forum password and try again.
icecool2
Re: Alexa Control
That did the trick! Got the skill installed, but I'm getting device is unresponsive. I have the Wifi adapter, not the cloud adapter. Is that a problem?
It also only discovered my second relay box, not the first.
Re: Alexa Control
It actually only works with RA*.
I never tested with the cloud wifi attachment. It should work, but definitely not with the regular wifi attachment.
