cloud wifi
yellowtang
cloud wifi
hi just wondering if the cloud wifi works with a reef angel plus controller.
Re: cloud wifi
Yes. That is what intended for, since RA* already has ethernet with cloud capability.
yellowtang
Re: cloud wifi
ok for the reef angel + controller how do you get access from outside your home network just not receiving anything when i leave the house.
Re: cloud wifi
I don't even see data sent to the server under this username.
Are you sure you are using the cloud wifi attachment and it is connected to the internet?
yellowtang
Re: cloud wifi
yes cloud WiFi attachment on my router hub it is showing connected? use to have old WiFi attachment worked like a charm, but eventually broke wife got a new router and everything gone down hill from there.
yellowtang
Re: cloud wifi
InternalMemory.OverheatTemp_write( 270 );
ReefAngel.StandardFan( T1_PROBE,Port4,256,261 );
ReefAngel.StandardHeater( T1_PROBE,Port5,245,252 );
ReefAngel.PWM.SetDaylight( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.PWM.SetActinic( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.CloudPortal();
// RA_STRING1=U2FsdGVkX1+Yt5FRRs7SPB8gt9oLTN55xtYBbF871xw=
// RA_STRING2=U2FsdGVkX1/bqOD7CNdeldRn+yiy3J1BLxZeEI7g2S8=
// RA_STRING3=SKY5AAFE
Re: cloud wifi
That code looks good.
What is the color of the led on the cloud wifi attachment?
Re: cloud wifi
Blink magenta= Connecting to cloud server
That indicates that the username and/or password is most likely wrong.
Make sure you enter the the username and password correctly when setting up the unit. Both fields are case sensitive.
You should get a solid cyan when it is connected to the cloud server.
yellowtang
Re: cloud wifi
is it the user name and password for the reef angel forum
yellowtang
Re: cloud wifi
done that nothing happens just says connecting and when you refresh says disconnected. just don't think its going to work some how, filled top three lines in on uapp and get data but soon as you go outside nothing.
yellowtang
Re: cloud wifi
if i fill just cloud server lines in get nothing only connecting
yellowtang
Re: cloud wifi
is there anyway of re doing it
Re: cloud wifi
Yes.
https://www.dropbox.com/s/zpifv3to1fc5w ... 1.pdf?dl=0
Please check the reset to factory on the manual.
yellowtang
Re: cloud wifi
did the factory re-set went green like it said the led gone off altogether? great.
Re: cloud wifi
Hummm.
Not sure what happened.
Can you connect it to your USB-TTL cable, open Arduino and go to Tools->Serial Monitor.
Make sure you have set at 57600 baud.
Then, open the unit and locate the debug and master button.
Press debug and hold. Then press master and release both.
You should get something on the monitor.
yellowtang
Re: cloud wifi
yes got some thing on screen
yellowtang
Re: cloud wifi
the led is very faint looks red
