Hi, I would have a problem with the orp probe. I lost the bnc ahead, how can I calibrate it
Inviato dal mio CLT-L09 utilizzando Tapatalk
Problem orp
ROBBYMAN86
Re: Problem orp
Done but nothing happens, the reader has always been 0 even with the probe inserted.rimai wrote:Use a paper clip to short out the center pin to the outer shell.
ROBBYMAN86
Re: Problem orp
ROBBYMAN86
Re: Problem orp
There is no way to understand if it works?rimai wrote:It may be your orp module if it is showing always zero.
Re: Problem orp
Make sure the usb cable is plugged correctly and power supply too.
If they are and you still get zero, it can only be the module.
ROBBYMAN86
Re: Problem orp
Ok I try and update you
