Hi
Since yesterday I am getting this error when try to compile any code in webwizard
"Error compiling: [object Object]"
I am using windows 10. Unistalled the pluging and installed again, no effect.
As I said, even the simplest code get this result
Webwizard - Error compiling: [object Object]
libertyaquarium
Re: Webwizard - Error compiling: [object Object]
But I would recommend you accessing it over ssl on https://forum.reefangel.com/webwizard so your forum login gets preserved over the entire session.
libertyaquarium
Roberto
Still the same.
That's what I do: I go to forum.reefangel.com, log in using login and password, change the URL address to /webwizard (does not show me the message about logging in). Everything using HTTPS.
Still any code submited gets "Error compiling: [object Object]"
Still the same.
Can you try with the existing default code that already shows up when you go to webwizard?
Does it show the same error?
Try refreshing the webwizard page.
libertyaquarium
Roberto
Take a look at
https://sgapucminasbr-my.sharepoint.com ... g?e=liYgeC
I cleared all the browsing data (history, images, files, cookies and other site data). The same happened.
Take a look at
That prompt for the certificate is very strange.
I can't replicate that on any browser I tried.
libertyaquarium
Crazy... I did not accepted and run properly....
