Hi, I've been trying to come up with a code to make the pump run at one mode and speed at day and another at night but everything I've tried just runs them constantly at the night setting I want for them, constant 25%. Any help with this will be really appreciate it. Thanks
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port5 );
ReefAngel.SingleATO( true,Port1,240,0 );
ReefAngel.StandardLights( Port3,10,30,20,30 );
ReefAngel.StandardLights( Port4,10,30,20,30 );
ReefAngel.StandardHeater( Port7,790,800 );
if (hour()>=1000 && hour()<=2100) // Day mode between 10:00am and 9:00pm
ReefAngel.DCPump.SetMode( LongPulse,100,25 );
else if (hour()>=2101 || hour()<=959) // Night mode between 9:01pm and 9:59am
ReefAngel.DCPump.SetMode( Constant,25,0 );
ReefAngel.AddWifi();
Help with day/night mode Jebao code
Piper
Re: Help with day/night mode Jebao code
Try changing this section:
to this:
} Code: Select all
if (hour()>=10 && hour()<=21) // Day mode between 10:00am and 9:00pm
