Posts: 177 Joined: Fri Dec 26, 2014 6:38 pm
 Posted: Sun Jan 20, 2019 10:16 pm
fyi, heres my latest code: - Code: Select all
#include <ReefAngel_Features.h> #include <Globals.h> #include <RA_Wifi.h> #include <Wire.h> #include <OneWire.h> #include <Time.h> #include <DS1307RTC.h> #include <InternalEEPROM.h> #include <RA_NokiaLCD.h> #include <RA_ATO.h> #include <RA_Joystick.h> #include <LED.h> #include <RA_TempSensor.h> #include <Relay.h> #include <RA_PWM.h> #include <Timer.h> #include <Memory.h> #include <InternalEEPROM.h> #include <RA_Colors.h> #include <RA_CustomColors.h> #include <Salinity.h> #include <RF.h> #include <IO.h> #include <ORP.h> #include <AI.h> #include <PH.h> #include <WaterLevel.h> #include <Humidity.h> #include <DCPump.h> #include <PAR.h> #include <ReefAngel.h>
void SeasonalDaylight () { static int daylightArray[][4] = { {13,0,22,0}, // default in case of error in month=0 (May) {15,0,22,0}, //January (winter) {14,30,22,0}, //February (winter) {14,0,22,0}, //March (early spring) {13,30,22,0}, //April (spring) {13,0,22,0}, //May (spring) {12,30,22,0}, //June (early summer) {12,0,22,0}, //July (summer) {12,30,22,0}, //August (summer) {13,0,22,0}, //September (early fall) {13,30,22,0}, //October (fall) {14,0,22,0}, //November (fall) {14,30,22,0} //December (early winter) };
// Port 2 is power supply for Day lights ReefAngel.PWM.SetDaylightRaw(PWMSlopeHighRes( daylightArray[month()][0], daylightArray[month()][1], daylightArray[month()][2], daylightArray[month()][3], InternalMemory.PWMSlopeStartD_read(), InternalMemory.PWMSlopeEndD_read(), InternalMemory.PWMSlopeDurationD_read(), ReefAngel.PWM.GetDaylightValueRaw() )); /* TODO comment out the next line if the power supply for the lights is not needed and the lights are plugged into a power strip. Otherwise, if the lights are plugged into the relay, you will need to toggle the port to turn the lights off */ ReefAngel.StandardLights(Port2, daylightArray[month()][0], daylightArray[month()][1], daylightArray[month()][2], daylightArray[month()][3]); }//end SeasonalDaylight
void SeasonalActiniclight () { static int actinicArray[][4] = { {12,30,22,30}, // default in case of error in month=0 (May) {14,30,22,30}, //January (winter) {14,0,22,30}, //February (winter) {13,30,22,30}, //March (early spring) {13,0,22,30}, //April (spring) {12,30,22,30}, //May (spring) {12,0,22,30}, //June (early summer) {11,30,22,30}, //July (summer) {12,0,22,30}, //August (summer) {12,30,22,30}, //September (early fall) {13,0,22,30}, //October (fall) {13,30,22,30}, //November (fall) {14,0,22,30} //December (early winter) };
// Port 1 is power supply for Actinic Lights ReefAngel.PWM.SetActinicRaw(PWMSlopeHighRes( actinicArray[month()][0], actinicArray[month()][1], actinicArray[month()][2], actinicArray[month()][3], InternalMemory.PWMSlopeStartA_read(), InternalMemory.PWMSlopeEndA_read(), InternalMemory.PWMSlopeDurationA_read(), ReefAngel.PWM.GetActinicValueRaw() )); /* TODO comment out the next line if the power supply for the lights is not needed and the lights are plugged into a power strip. Otherwise, if the lights are plugged into the relay, you will need to toggle the port to turn the lights off */ ReefAngel.StandardLights(Port1, actinicArray[month()][0], actinicArray[month()][1], actinicArray[month()][2], actinicArray[month()][3]); }//end SeasonalActinics
void setup() { // This must be the first line InternalMemory.LCDID_write(0); //this line was added when i got a replacement RA+ board ReefAngel.Init(); //Initialize controller ReefAngel.Use2014Screen(); // Let's use 2014 Screen // Ports toggled in Feeding Mode ReefAngel.FeedingModePorts = Port5Bit | Port6Bit; // Ports toggled in Water Change Mode ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit; // Ports toggled when Lights On / Off menu entry selected ReefAngel.LightsOnPorts = Port1Bit | Port2Bit; // Ports turned off when Overheat temperature exceeded ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit; // Use T1 probe as temperature and overheat functions ReefAngel.TempProbe = T1_PROBE; ReefAngel.OverheatProbe = T1_PROBE;
// Feeeding and Water Change mode speed ReefAngel.DCPump.FeedingSpeed=0; ReefAngel.DCPump.WaterChangeSpeed=0;
// Ports that are always on ReefAngel.Relay.On( Port4 );
////// Place additional initialization code above here }
void loop() { //ReefAngel.ActinicLights( Port1 ); //ReefAngel.DayLights( Port2 ); // Light code SeasonalDaylight(); SeasonalActiniclight();
ReefAngel.StandardHeater( Port3 ); ReefAngel.Relay.DelayedOn(Port5 ); ReefAngel.DosingPumpRepeat1( Port7 ); ReefAngel.DosingPumpRepeat2( Port8 ); //ReefAngel.PWM.DaylightPWMSlope(); //ReefAngel.PWM.ActinicPWMSlope(); ReefAngel.DCPump.LowATOChannel = Sync; // WP40 ReefAngel.DCPump.HighATOChannel = AntiSync; // SW-8 ReefAngel.DCPump.AntiSyncOffset = 125;
// Wavemaker
if ( ((hour() >= 2) && (hour() < 8)) || ((hour() >= 15) && (hour() < 19)) ) // off from 2am-8am & 3pm-7pm { ReefAngel.Relay.Off(Port6); } else { ReefAngel.WavemakerRandom( Port6, 30, 150 ); // random between 30 and 150 seconds }
// DC pumps.................................... static int rmode; static boolean changeMode=true;
// These are the modes we can cycle through. You can add more and even repeat... byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
if (now()%1800==0 || changeMode==true) // Change every 30 mins (1800seconds) or controller reboot { rmode=random(100)%sizeof(modes); // Change the mode by picking from our array changeMode=false; }
// Set timer when in feeding mode static unsigned long feeding; if (ReefAngel.DisplayedMenu==FEEDING_MODE) feeding=now();
// Continue NutrientTranspot Mode for 30 minutes after feeding if (now()-feeding<1800) { ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read(); ReefAngel.DCPump.Mode=ReefCrest; ReefAngel.DCPump.Speed=75; }
// Night/Quiet mode else if (hour()>=2 && hour()<8 ) // 2am to 8am { ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.SetMode( Gyre,40,10 ); } else if (hour()>=15 && hour()<19) // 3pm and 7pm { ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.SetMode( ShortPulse,40,30 ); }
//Storm mode else if (hour()>=1 && hour()<2) // 1am and 2am { ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.SetMode( Else,70,15 ); } else if (hour()>=11 && hour()<12) // 11am and 12pm { ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.SetMode( ReefCrest,80,15 ); }
// Custom Mode and nothing else going on else if (InternalMemory.DCPumpMode_read()==11) { ReefAngel.DCPump.UseMemory=false; ReefAngel.DCPump.Duration=InternalMemory.DCPumpDuration_read(); ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :) ReefAngel.DCPump.Speed=InternalMemory.DCPumpSpeed_read(); // Set speed from portal } else { ReefAngel.DCPump.UseMemory=true; // Will reset all values from memory } ////// Place your custom code above here
// This should always be the last line ReefAngel.Portal( "" ); ReefAngel.DDNS( "" ); // Your DDNS is ReefAngel.ShowInterface(); }
