Feed Mode for powerhead on 2nd Relay Box
mav3rick478
Post by mav3rick478 »
So I have a 3rd powerhead being controlled on the second relay box in my setup, it does the timed on and off functions without any issues. I can control it through the Android Reef Angel app but when I activate Feed Mode or Water Change Mode it will not turn off with the rest of my powerheads, skimmer and dosing pump on the first relay box. Can anyone help me out TIA
Here's my current code:
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit | Box1_Port6;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit | Box1_Port6;
ReefAngel.WaterChangePortsE[1] = 0;
InternalMemory.OverheatTemp_write( 790 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.DosingPumpRepeat( Port1,0,60,660 );
ReefAngel.StandardLights( Port2,0,0,8,0 );
ReefAngel.Wavemaker( Box1_Port6,900 );
ReefAngel.Portal( "mav3rick478" );
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT1=Port 1
// RA_LABEL LABEL_PORT11=Port 11
// RA_LABEL LABEL_PORT12=Port 12
// RA_LABEL LABEL_PORT13=Port 13
// RA_LABEL LABEL_PORT14=Port 14
// RA_LABEL LABEL_PORT15=Port 15
// RA_LABEL LABEL_PORT16=Port 16
// RA_LABEL LABEL_PORT17=Port 17
// RA_LABEL LABEL_PORT18=Port 18
// RA_LABEL LABEL_PORT2=Port 2
// RA_LABEL LABEL_PORT3=Port 3
// RA_LABEL LABEL_PORT4=Port 4
// RA_LABEL LABEL_PORT5=Port 5
// RA_LABEL LABEL_PORT6=Port 6
// RA_LABEL LABEL_PORT7=Port 7
// RA_LABEL LABEL_PORT8=Port 8
Re: Feed Mode for powerhead on 2nd Relay Box
Set this to whatever PortX_Bit you need
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port6Bit;
mav3rick478
lnevo wrote:Set this to whatever PortX_Bit you need
Thank you worked like a charm. So that I understand, the line that I transferred the port for my powerhead to is that for what's connected to my Expansion Relay?
Sent from my Pixel XL using Tapatalk
Yes, exactly. Each variable controls one relay box. In each one you need to set the bits you want on/off.
