AI Sol Nano - PWMSlope Question
SuperDodge
Post by SuperDodge »
I have quickly pieced together a pde file. My big question is in the last section.
The three lines where I defined a PWMSlope...what do the 3 and 8's at the end of the PWMSlope function do exactly?
Re: AI Sol Nano - PWMSlope Question
Those are the "default" values that get returned / used when the PWMSlope function is in the "off" state. In short, it's the values that get used during the "off" time. Typically that should be the minimum value that your LED drivers can display.
SuperDodge
binder wrote:Those are the "default" values that get returned / used when the PWMSlope function is in the "off" state. In short, it's the values that get used during the "off" time. Typically that should be the minimum value that your LED drivers can display.
Thanks for the quick answer, that was driving me crazy!
But since my pde file uses a seperate function for the moonlighting (if, else) it really doesn't matter in my case, does it?
Most likely it does not. If you were concerned about it, you could always change them to 0 but it's highly unlikely that it will be causing any problems or noticeable changes.
