Hooked it all up and added the new Ph probe.
Selected to calibrate the Ph Exp from the setup menu. The levels are extremely off. Ph7 is reading at 1150 and PH10 is reading about the same.
Is there anything i can do? Am i missing something?
Everything sounds awesome and would be awesome, if i can just get it working
btw the new temp probe works
In the process of calibrating the new Ph probe (for controller PH). Probe seems to be working ok.
