Is there a way to change the labels on these?
						RA Star Port Labels
- cosmith71
RA Star Port Labels
				cosmith2
Re: RA Star Port Labels
Wizard.  I can use the IDE if need be.
It seems like there was a function on the RA+ to assign labels on the screen. It's been a while and I can't remember.
				cosmith2
ReefAngel.CustomLabels is the function on the Plus.  Is there an equivalent on the Star?
On the webwizard, add these lines at the end of your code:
// RA_LABEL LABEL_TEMP1=Room
// RA_LABEL LABEL_TEMP2=Display
// RA_LABEL LABEL_ATOLOW=ATO
// RA_LABEL LABEL_ATOHIGH=Skimmate
// RA_LABEL LABEL_ACTINIC=Gyre 1
// RA_LABEL LABEL_ACTINIC2=Actinic 2
// RA_LABEL LABEL_DAYLIGHT2=Daylight 2
// RA_LABEL LABEL_PORT11=ATS Pump
// RA_LABEL LABEL_PORT12=ATO
// RA_LABEL LABEL_PORT13=Fan
// RA_LABEL LABEL_PORT14=ATS Light
// RA_LABEL LABEL_PORT15=Gyre
// RA_LABEL LABEL_PORT16=Heater
// RA_LABEL LABEL_PORT17=Skimmer
// RA_LABEL LABEL_PORT18=Return
						- cosmith71
Got it.  Thanks!
I also found out the Wizard can do it, if I'd bother to enter in the labels.
 - Contact:
What about using the IDE?  Is it inside RA_CustomLabels.h ?
 - Contact:
awesome thanks! that's what I thought (I discovered it after I posted my question).rimai wrote:You can change the file RA_CustomLabels.h
Sent from my Pixel 2 using Tapatalk
