the dosing pumps come with small hose barbs. what are their sizes? and where can I get replacement ones? I don't need replacements currently but you never know.
Sent from my Pixel 2 using Tapatalk
dosing pump hose barb
- Contact:
Re: dosing pump hose barb
The tubing is 0.15" OD.
If you ever need some, just send me a pm.
- Contact:
ok. good to know. thanks.rimai wrote:The tubing is 0.15" OD.
btw, when will you be getting the dosing pumps back in stock?
- Contact:
removing the out of stock or removing the pumps?rimai wrote:I am considering removing that.
- Contact:
ahhhh. well, I would understand if you did.rimai wrote:Removing the pumps.
I would be up for purchasing 1 or 2 more from you if you had any. plus depending on how long the pump heads last, I may want to consider getting some extra if you had those. in case you do discontinue them so I wouldn't be out of luck and have to replace the entire pump.
I'm just trying to support you for all your hard work and efforts. If you don't have any pumps, it's no biggie.
thanks!
