Uapp Graph shows no Data to display always.
SouthernReefer
How do i get Uapp to actually graph for me? Now that the tanks been up and cycling for a few weeks, id like to graph the Temps over time to test that out. Everytime i do, i get no data to display.. Any ideas?
Re: Uapp Graph shows no Data to display always.
Your controller is not sending data to the server.
SouthernReefer
Interesting... OK so how do i get it to send? Cloud works otherwise, It allows me full control, but id like to get that working if we can. Im cycling so nows the time to get it workingrimai wrote:Your controller is not sending data to the server.
That's odd. Did you try rebooting the controller?
SouthernReefer
Yes actually I rebooted it yesterday as it was locked up. As a side note how can I tell what's locking it up? The screen was unresponsive and a timeout in Uapp. Reboot fixed it tho. Either way is there a way to troubleshoot why I wouldn't be sending data?rimai wrote:That's odd. Did you try rebooting the controller?
Are you able to connect the controller to a computer and open serial monitor?
SouthernReefer
rimai wrote:Are you able to connect the controller to a computer and open serial monitor?
I'd have to take it off the side of the tank and essentially take the tank offline, as I don't have a laptop or a pc close to the controller.
SouthernReefer
If it helps. Network wise I am conencted to a Mesh wifi adapter that is then connected back to my Netgear router wirelessly though their protocol. cloud works well.
The only issues im seeing right now, is that im not getting data to you, which concerns me from an alerting standpoint going forward, and ive froze up a couple times.
I did the standard web wizard setup, but i didnt see anything for that in there.
The last log shows 9/28.
Nothing after that. Was anything changed during that time?
SouthernReefer
rimai wrote:The last log shows 9/28.
09-28-20 was when we worked through the issues with AVRDUDE to get my code pushed. that was my first code push, and then i got cloud working. I can move my all in one out to the tank if i need to, but will that kill my relay box running the tank while we monitor?
SouthernReefer
Im also assuming this is why the ATO alerts ive configured have not sent me emails too, while i was testing.
SouthernReefer
Also is there a step by step guide to get the logs for you, or is is something that we need to coordinate so I do it while you watch your side? Just want to make sure i catch everything right, as i can setup a temp station for PC tonight.rimai wrote:The last log shows 9/28.
SouthernReefer
I e run a test direct cable vs my netgear adapter to see if it's that causing issuesm let me know of you suddenly see logs.
I don't think it made a difference. Last log is still 09/28.
The alerts are not firing because the server never got data to fire the alerts.
All you need to do is connect the controller on your computer and open serial monitor on Arduino IDE.
The controller will start logging stuff. Wait about 10 to 15 minutes to make sure we catch a couple tries of the controller trying to send data.
SouthernReefer
And then just send you the output?rimai wrote:I don't think it made a difference. Last log is still 09/28.
SouthernReefer
Ok. I will do this aftwr work. I'll have to move the PC out there but I can make that work I think so I don't have to unplug everything to get this accomplished.infofured network was worth a test, but clearly wired direct to main wifi router makes no difference.rimai wrote:Yes
SouthernReefer
SouthernReefer
Here is the serialrimai wrote:The last log shows 9/28.
RA Init
SPI Init
LCD Init
Network Init
Touch Init
SD Found: 1
SD Init
192.168.1.19
MQTT Connecting...
MQTT failed
MQTT Connecting...
Channel 5MQTT succeeded
Channel 5all:0
Channel 5Portal Call
Channel 5Data Sent
Channel 5HTTP/1.1 400 Bad Request
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Date: Fri, 30 Oct 2020 20:24:07 GMT
Connection: close
Content-Length: 311
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request</h2>
<hr><p>HTTP Error 400. The request is badly formed.</p>
</BODY></HTML>
ÿDisconnected
Channel 5Connecting...
Channel 5Connected
Date: Fri, 30 Oct 2020 20:24:08 GMT
Connection: close
Content-Length: 339
Data: 339
Channel 5Header: 0
Channel 5Disconnected
Channel 5Data Sent
Date: Fri, 30 Oct 2020 20:29:08 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Channel 5Connected
Date: Fri, 30 Oct 2020 20:29:10 GMT
Connection: close
Content-Length: 339
Data: 339
Channel 5Header: 0
Channel 5Data Sent
Date: Fri, 30 Oct 2020 20:34:09 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Channel 5Connected
Date: Fri, 30 Oct 2020 20:34:10 GMT
Connection: close
Content-Length: 339
Data: 339
Channel 5Header: 0
Channel 5Data Sent
Date: Fri, 30 Oct 2020 20:39:10 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Channel 5Connected
Date: Fri, 30 Oct 2020 20:39:11 GMT
Connection: close
Content-Length: 339
Data: 339
Channel 5Header: 0
Channel 5Data Sent
Date: Fri, 30 Oct 2020 20:44:12 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Channel 5Connected
Date: Fri, 30 Oct 2020 20:44:13 GMT
Connection: close
Content-Length: 339
Data: 339
Channel 5Header: 0
Channel 5
Definitely something going on there.
Can you please post your code?
SouthernReefer
#include <Salinity.h>rimai wrote:Definitely something going on there.
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
ReefAngel.Star();
ReefAngel.FeedingModePortsE[0] = Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePortsE[1] = 0;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit;
ReefAngel.Relay.DelayedOn( Box1_Port4,10 );
ReefAngel.Relay.DelayedOn( Box1_Port6,10 );
ReefAngel.SingleATO( true,Box1_Port7,45,0 );
ReefAngel.StandardLights( Box1_Port8,22,0,10,0 );
boolean buzzer=false;
if ( ReefAngel.isATOTimeOut() ) buzzer=true;
if ( ReefAngel.isOverheat() ) buzzer=true;
if ( ReefAngel.isBusLock() ) buzzer=true;
if ( ReefAngel.Params.Temp[ T1_PROBE ] >= 820 ) ReefAngel.Relay.Off( Port1 );
if ( ReefAngel.Params.Temp[ T1_PROBE ] <= 775 ) ReefAngel.Relay.On( Port1 );
ReefAngel.Network.Cloud();
// RA_STRING1=U2FsdGVkX18SRGs3W6Nho4tbkPQm9kNx1zw1++/r4LSB5npUkT/wWfcMeCtcWzAq
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_PORT16=Skimmer
// RA_LABEL LABEL_PORT14=Dosing Pump
// RA_LABEL LABEL_PORT17=ATO
// RA_LABEL LABEL_PORT15=PowerHeads
// RA_LABEL LABEL_PORT13=Return Pump
// RA_LABEL LABEL_PORT18=Cheato Reactor Light
// RA_LABEL LABEL_PORT11=Heater Controller
// RA_LABEL LABEL_PORT12=Cheato Reactor
SouthernReefer
i have 2 code sets that i had started with im 99 percent sure the one i posted is what is on there. Is there a way to tell which one i actually uploaded to make sure im 100 percent good?
There is no way to find out which code you have.
I also cannot replicate the problem. I tried the exact same code and it connects fine for me.
Can you try creating a new forum username and password?
I am not sure if this will work, but it is worth a try.
The only thing different is the username and password, because I used the exact same code.
SouthernReefer
rimai wrote:There is no way to find out which code you have.
Will that break anything? Will I need to re upload code? Does it maybe not like special characters?
SouthernReefer
Could it be something my ISP is blocking as well?rimai wrote:There is no way to find out which code you have.
You would need to generate a new code.usimg the new username and upload it to the controller.
SouthernReefer
rimai wrote:You would need to generate a new code.usimg the new username and upload it to the controller.
I tried to create a new account using same email and it won't let me. That's my only email address.
Ok, let's try this....
Login with the username and password I PM you.
Load the code below and open serial monitor.
Let's see if it makes any difference.
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
ReefAngel.Star();
Port1 );
Port1 );
// RA_STRING1=U2FsdGVkX19jYtoXu4XqRVPLLcwq6OqB5Y/7iQ0mRvU=
// RA_STRING2=null
// RA_STRING3=null
SouthernReefer
Doing it now.rimai wrote:Ok, let's try this....
Let's see if it makes any difference.Code: Select all
#include <Salinity.h> #include <ReefAngel_Features.h> #include <Globals.h> #include <RA_TS.h> #include <RA_TouchLCD.h> #include <RA_TFT.h> #include <RA_TS.h> #include <Font.h> #include <RA_Wifi.h> #include <RA_Wiznet5100.h> #include <SD.h> #include <SPI.h> #include <Ethernet.h> #include <EthernetDHCP.h> #include <PubSubClient.h> #include <Wire.h> #include <OneWire.h> #include <Time.h> #include <DS1307RTC.h> #include <InternalEEPROM.h> #include <RA_ATO.h> #include <LED.h> #include <RA_TempSensor.h> #include <Relay.h> #include <RA_PWM.h> #include <Timer.h> #include <Memory.h> #include <InternalEEPROM.h> #include <RA_Colors.h> #include <RA_CustomColors.h> #include <RA_CustomLabels.h> #include <RF.h> #include <IO.h> #include <ORP.h> #include <AI.h> #include <PH.h> #include <WaterLevel.h> #include <Humidity.h> #include <PAR.h> #include <DCPump.h> #include <ReefAngel.h> #include <SoftwareSerial.h> ////// Place global variable code below here ////// Place global variable code above here void setup() { // This must be the first line ReefAngel.Init(); //Initialize controller ReefAngel.Star(); // Ports toggled in Feeding Mode ReefAngel.FeedingModePorts = 0; ReefAngel.FeedingModePortsE[0] = Port7Bit; ReefAngel.FeedingModePortsE[1] = 0; // Ports toggled in Water Change Mode ReefAngel.WaterChangePorts = 0; ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit; ReefAngel.WaterChangePortsE[1] = 0; // Ports turned off when Overheat temperature exceeded ReefAngel.OverheatShutoffPorts = 0; ReefAngel.OverheatShutoffPortsE[0] = Port1Bit; ReefAngel.OverheatShutoffPortsE[1] = 0; // Ports toggled when Lights On / Off menu entry selected ReefAngel.LightsOnPorts = 0; ReefAngel.LightsOnPortsE[0] = 0; ReefAngel.LightsOnPortsE[1] = 0; // Use T1 probe as temperature and overheat functions ReefAngel.TempProbe = T1_PROBE; ReefAngel.OverheatProbe = T1_PROBE; // Set the Overheat temperature setting InternalMemory.OverheatTemp_write( 820 ); // Ports that are always on ReefAngel.Relay.On( Box1_Port1 ); ReefAngel.Relay.On( Box1_Port2 ); ReefAngel.Relay.On( Box1_Port3 ); ReefAngel.Relay.On( Box1_Port5 ); ////// Place additional initialization code below here ////// Place additional initialization code above here } void loop() { ReefAngel.Relay.DelayedOn( Box1_Port4,10 ); ReefAngel.Relay.DelayedOn( Box1_Port6,10 ); ReefAngel.SingleATO( true,Box1_Port7,45,0 ); ReefAngel.StandardLights( Box1_Port8,22,0,10,0 ); boolean buzzer=false; if ( ReefAngel.isATOTimeOut() ) buzzer=true; if ( ReefAngel.isOverheat() ) buzzer=true; if ( ReefAngel.isBusLock() ) buzzer=true; if ( buzzer ) ReefAngel.BuzzerOn(2); else ReefAngel.BuzzerOff(); if ( ReefAngel.Params.Temp[ T1_PROBE ] >= 820 ) ReefAngel.Relay.Off( Port1 ); if ( ReefAngel.Params.Temp[ T1_PROBE ] <= 775 ) ReefAngel.Relay.On( Port1 ); ////// Place your custom code below here ////// Place your custom code above here ReefAngel.Network.Cloud(); // This should always be the last line ReefAngel.ShowTouchInterface(); } // RA_STRING1=U2FsdGVkX19jYtoXu4XqRVPLLcwq6OqB5Y/7iQ0mRvU= // RA_STRING2=null // RA_STRING3=null // RA_LABEL LABEL_PORT16=Skimmer // RA_LABEL LABEL_PORT14=Dosing Pump // RA_LABEL LABEL_PORT17=ATO // RA_LABEL LABEL_PORT15=PowerHeads // RA_LABEL LABEL_PORT13=Return Pump // RA_LABEL LABEL_PORT18=Cheato Reactor Light // RA_LABEL LABEL_PORT11=Heater Controller // RA_LABEL LABEL_PORT12=Cheato Reactor
SouthernReefer
No Dice....
RA Init
SPI Init
LCD Init
Network Init
Touch Init
SD Found: 1
SD Init
192.168.1.19
MQTT Connecting...
MQTT failed
MQTT Connecting...
Channel 5Data Sent
Date: Sat, 31 Oct 2020 00:53:28 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Channel 5Connected
Date: Sat, 31 Oct 2020 00:53:29 GMT
Connection: close
Content-Length: 339
Data: 339
Channel 5Header: 0
Channel 5D
