Hello,
I just changed my provider box and now the Wifi module seems to don't want to connect.
Do you know if my access point is compatible with the Wifi attachment ?
Before I had the previous version of the box (called V5 http://fr.wikipedia.org/wiki/Freebox#Wi-Fi).
The Wifi configuration didn't change. It's configured in the admin provider web configuration (When you reboot your box, it push the configuration what ever your box is).
My box : Wi-Fi 802.11n MIMO 3x3 / 2,4 GHz (450 Mb/s max) Card mini PCI Express Marvell 88W8366
I'm in WPA2 (TKIP)
SSID : "xender"
key : ********
DHCP : ON
Wifi Graphical utility :
mode 4
port : 2000
Logs :
No IP
AUTH-error
I have the V6 Version called "FreeBox Révolution" : http://en.wikipedia.org/wiki/Freebox
FR version more complete :http://fr.wikipedia.org/wiki/Freebox
RA Wifi module : http://www.rovingnetworks.com/products/RN_131
Thanks for your help
WIFI PB with French Box "Freebox Révolution"
- Xender
Fresh Water Aquarium 180*60*80
Salt Water Aquarium 60*60*60
- Xender
Re: WIFI PB with French Box "Freebox Révolution"
I investigated on the web and I maybe found something.
Some of users have problems also with Ipad and Wifi n with the Freebox Revolution.
They have to activate : "Proxy Http auto mode" in the wifi settings
Can we setup that in the wifi configuration?
other thing:
Some of them setup de wifi box with a different rate of the canal. They setup the "Low Canal" (canal Inférieur)
I can setup different settings : 20 MHz or 40 MHz ?
http://www.abricocotier.fr/15013-proble ... ion-wifi-n
I will try different configuration tonight.
Some help in Wifi Channel And rate:
EN http://en.wikipedia.org/wiki/List_of_WLAN_channels
FR http://fr.wikipedia.org/wiki/Liste_des_canaux_Wi-Fi
other thing:
- Contact:
The Channel frequency doesn't matter for wireless N. The wifi adapter is a G only adapter. So you must make sure that your router also supports G in addition to N and that it allows G devices to connect to it.
- Xender
It's working.
Here is the config :
Auth mode 4
Enjoy French Users
Auth mode 4
Enjoy French Users
