No longer can connect to upload code
benjy1234
I have a macbook and the 1.0.43 plug in installed. When in web wizard it indicates that the plug in is found and connected but it posts an Error:404 whenever it connects. Also it will not detect the reef angel nor my wifi plug-in in the port.
Re: No longer can connect to upload code
Can you post a screenshot of the error? Are you using Chrome?
benjy1234
I can post a screenshot when I get home but it just says Error: 404 in the lower section of the web wizard display. Other than that everything appears to be working minus the not connecting. I am using chrome.
benjy1234
Attached is a screenshot of whats going on. No matter what I do I cant get the RA to communicate with computer
https://imgur.com/a/V95mmda
- mav3rick478
Do you have the cloud attachment or just the normal wifi attachment? I've never been able to upload from the web wizard with just the wifi attachment.
Sent from my Pixel 4 XL using Tapatalk
benjy1234
I have the cloud attachment. However I am unable to upload code to either the RA or the WIFI attachment. Im getting the same issue with both, the port is not recognizing that anything is plugged in.
