UAPP Graph data
Appleseed
UAPP Graph data
Post by Appleseed »
Hi,
I have moved my RA+ (with the original wifi module) to use the UAPP portal and everything seems to work fine except that i get an error stating "no data to display" when trying to access any of the graphs.
Any ideas would be appreciated.
thanks
Andy
brennyn21
Re: UAPP Graph data
Post by brennyn21 »
Did you update your code on your Reef Angel and Wifi attachment? It doesn't seem to be sending data to the server.
Sincerely, Brennyn
Appleseed
Re: UAPP Graph data
Post by Appleseed »
i updated the code on the controller using the webwizard and I was sure I had updated the config on the wifi module (checked by using the get everything cmd) but it seems that it didnt take.
I have tried again the module using terraterm but it did something weird and all the characters went messed up as the baud rate went back to 9600 but even then it was screwy.
So i applied the config manually using putty and it looks like it is sending data :)
One last question, should we stop using the Arduino app to configure the RA+ controllers?
thanks
Andy
