Display not turning off
javisaman
Post by javisaman »
Hi,
I've noticed recently that the reef angel display on my plus unit is not turning off. I noticed that the joystick was stuck (kept scrolling down), so I cleaned the joystick with contact cleaner and added dielectric grease and it fixed that problem. However, the screen remains on. Is there something else I can try?
brennyn21
Re: Display not turning off
Post by brennyn21 »
It sounds like it still thinks the joy stick is being pressed or moved.
Here is the relevant code in the ReefAngel_1.5_LCD.h
void ReefAngelClass::CheckScreenSaver()
	// process screensaver timeout
	if ( Timer[LCD_TIMER].IsTriggered() )
		// Screensaver timeout expired
		LCD.BacklightOff();
	if ( Joystick.IsButtonPressed() )
		// turn the backlight on
		LCD.BacklightOn();
		// TODO check Timer[LCD_TIMER] code
		if ( Timer[LCD_TIMER].Trigger == 0 )
			Timer[LCD_TIMER].Start();
			return;
		PrepMenuScreen();
		// get out of this function and display the menu
		return;
#ifdef MAIN_2014
	if ( Joystick.IsUp() || Joystick.IsDown() )
#else
	if ( Joystick.IsUp() || Joystick.IsDown() || Joystick.IsRight() || Joystick.IsLeft() )
#endif // MAIN_2014
		// Turn backlight on
		LCD.BacklightOn();
Sincerely, Brennyn
