CODE CHECK
CASPAR
CODE CHECK
Can someone please check this code for me? Im hoping it is the current code i am using but dont want to mess things up. I think this is it, supposed to have the storm effects and ATO function and also am using port 5 & 6 for just a timer to control 2 small pumps for a water change.
CODE IS BELOW:
prog_char menu1_label[] PROGMEM = "Feeding Mode";
prog_char menu2_label[] PROGMEM = "Water Change Mode";
prog_char menu3_label[] PROGMEM = "Cloud On Demand";
prog_char menu4_label[] PROGMEM = "Clear ATO Timeout";
prog_char menu5_label[] PROGMEM = "Set Clock";
prog_char menu6_label[] PROGMEM = "Calibrate pH";
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label};
byte DaylightPWMValue=0;
boolean ForceCloud=false;
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry4()
ReefAngel.ATOClear();
void MenuEntry5()
ReefAngel.SetupDateTime();
void MenuEntry6()
ReefAngel.SetupCalibratePH();
byte x = 6;
byte y = 2;
byte t;
// Parameters
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(COLOR_INDIGO, 1, 11, 132, 11);
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 1, 102, "----------------------");
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 1, 126, "----------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,56,110, "ATO");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 2, 109, "*");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 2, 121, "*");
ReefAngel.LCD.DrawText(COLOR_GREEN,255, 45, 111, "H");
ReefAngel.LCD.DrawText(COLOR_GREEN,255, 45, 121, "I");
ReefAngel.LCD.DrawText(COLOR_GREEN,255, 77, 111, "L");
ReefAngel.LCD.DrawText(COLOR_GREEN,255, 77, 121, "O");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 126, 109, "*");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 126, 121, "*");
ReefAngel.LCD.DrawText(COLOR_RED,255,14,30,"TANK");
ReefAngel.LCD.DrawLargeText(COLOR_GREEN, 255, 10, 40, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,95,30,"PH");
ReefAngel.LCD.DrawLargeText(COLOR_GREEN, 255, 85, 40, text, Num8x16);
// Main Relay Box
ReefAngel.LCD.DrawOutletBox(12, 85, TempRelay);
ReefAngel.LCD.DrawText(COLOR_RED,255,8,58,"LED TEMP");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_NAVY, 15, 68, 10);
ReefAngel.LCD.DrawText(COLOR_RED,255,92,58,"ROOM");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_NAVY, 92, 68, 10);
ReefAngel.LCD.DrawText(COLOR_RED,255,10,110, "White");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 32, 119, "%");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,12,119, ReefAngel.PWM.GetDaylightValue());
//ReefAngel.PWM.GetDaylightValue(),
ReefAngel.LCD.DrawText(COLOR_RED,255,90,110, "Blue");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 114, 119, "%");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,92,119, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.FillCircle(57,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(57,122,3,COLOR_GREEN);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_GREEN);
//ReefAngel.PWM.GetActinicValue());
//ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
bool atoSpanReached; //flag to determine if the controller has been running long enough to start ATO functionality
ReefAngel.PHMin=305;
ReefAngel.PHMax=995;
ReefAngel.AddDateTimeMenu();
ReefAngel.AddCustomColors();
InternalMemory.OverheatTemp_write( 790 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port1,11,25,18,35 );
ReefAngel.StandardHeater( T1_PROBE,Port2,775,785 );
ReefAngel.StandardLights( Port3,18,30,11,30 );
ReefAngel.StandardLights( Port5,11,5,11,6 );
ReefAngel.StandardLights( Port6,11,0,11,1 );
ReefAngel.StandardLights( Port7,13,0,17,0 );
ReefAngel.LCD.BacklightOn();
ReefAngel.PWM.SetActinic( PWMSlope(11,30,18,30,11,40,60,0) );
DaylightPWMValue=PWMSlope(12,30,17,30,11,12,60,0);
CheckCloud();
ReefAngel.Portal( "CASPAR" );
int x,y;
// Parameters
// Main Relay Box
void CheckCloud()
#define Clouds_Every_X_Days 4
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resul
// could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the 250 minutes (or 500 minutes) can
// fit in that 510 minutes window.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
cloudstart=NumMins(hour(),minute())+1;
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,12,60);
ReefAngel.Relay.Off( Port8 );
if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<50)
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=85;
DaylightPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.DrawText(COLOR_BLUE,255,4,16,"CL");
ReefAngel.LCD.DrawText(0,255,20,16,"00:00");
ReefAngel.LCD.DrawText(COLOR_BLUE,255,75,16,"Li");
ReefAngel.LCD.DrawText(0,255,95,16,"00:00");
ReefAngel.LCD.DrawText(COLOR_BLUE,255,44,30,"Duration");
int x=0;
if ((cloudstart/60)>=10) x=20;
else x=26;
ReefAngel.LCD.DrawText(COLOR_RED,255,x,16,(cloudstart/60));
if ((cloudstart%60)>=10) x=38;
else x=44;
ReefAngel.LCD.DrawText(COLOR_RED,255,x,16,(cloudstart%60));
ReefAngel.LCD.DrawText(COLOR_GREEN,255,62,40,cloudduration);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=95;
else x=101;
ReefAngel.LCD.DrawText(COLOR_PURPLE,255,x,16,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=113;
else x=119;
ReefAngel.LCD.DrawText(COLOR_PURPLE,255,x,16,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
CODE IS BELOW:
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
byte x = 6;
byte y = 2;
byte t;
// Parameters
// Main Relay Box
CheckCloud();
int x,y;
// Parameters
// Main Relay Box
void CheckCloud()
// could happen.
#else
#endif
if (cloudchance)
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
if (cloudchance)
DaylightPWMValue=0;
delay(1);
cloudindex++;
int x=0;
else x=26;
else x=44;
int x=0;
else x=101;
else x=119;
cstart*=60;
cend*=60;
- brennyn21
Re: CODE CHECK
Hi Casper, looking at your code I fixed the Menu Options as it was changed how they were declared in the libraries a while back.
Right now the code does indeed have Storm Function, Light Control, Heater Control and Timed scheduled ports I will list them out below. I don't see anything for the ATO function if you need help setting that up it is pretty easy.
Relay Box Port1 Timer turning on at 11:25am and turning off at 6:35pm
Heater Control using T1 Probe and Port 2 on the Relay Box turning on at 77.5 and off at 78.5
Relay Box Port3 turning on at 6:30 Pm and off at 11:30 am
Relay Box Port5 turning on at 11:06 Am and off at 11:06 Am
Relay Box Port6 turning on at 11:00 Am and off at 11:01 Am
Relay Box Port7 turning on at 1:00 Pm and off at 5:00 Pm
Full Code with Menu declaration Fix.
ReefAngel.StandardLights( Port1,11,25,18,35 );Code: Select all
ReefAngel.StandardHeater( T1_PROBE,Port2,775,785 );Code: Select all
ReefAngel.StandardLights( Port3,18,30,11,30 );Code: Select all
ReefAngel.StandardLights( Port5,11,5,11,6 );Code: Select all
ReefAngel.StandardLights( Port6,11,0,11,1 );Code: Select all
ReefAngel.StandardLights( Port7,13,0,17,0 );Code: Select all
#include <avr/pgmspace.h>
const char menu1_label[] PROGMEM = "Feeding Mode";
const char menu2_label[] PROGMEM = "Water Change Mode";
const char menu3_label[] PROGMEM = "Cloud On Demand";
const char menu4_label[] PROGMEM = "Clear ATO Timeout";
const char menu5_label[] PROGMEM = "Set Clock";
const char menu6_label[] PROGMEM = "Calibrate pH";
PROGMEM const char * const menu_items[] = {menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label};
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
byte x = 6;
byte y = 2;
byte t;
// Parameters
// Main Relay Box
CheckCloud();
int x,y;
// Parameters
// Main Relay Box
void CheckCloud()
// could happen.
#else
#endif
if (cloudchance)
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
if (cloudchance)
DaylightPWMValue=0;
delay(1);
cloudindex++;
int x=0;
else x=26;
else x=44;
int x=0;
else x=101;
else x=119;
cstart*=60;
cend*=60;
}Sincerely, Brennyn
CASPAR
Re: CODE CHECK
Thanks brennyn21, how could i add the code for ATO ? My screen display shows the ATO high and lo for the float switches and they alternate when the floats move up and down. They were actually in the sump when i had saltwater setup, but now are still connected but no longer in a sump. I am currently converting to a large FW tank and am gonna use the RA+ to control it. Also when i verify the code above you tweaked i get this error ReefAngel.FeedingModeStart(); REEF ANGEL was not declared in this scope. Any help appreciated
CASPAR
Re: CODE CHECK
This part is in the code above and is what's probably making the display show a change when the floats are moved up or down
- brennyn21
CASPAR
- brennyn21
Re: CODE CHECK
Make sure you are using the online webwizard. forum.reefangel.com/webwizard
I tried compiling the code and it compiled fine.
As for adding the ATO you can use this line below. Place it in the void loop()
Please change the port to your liking and the 65 is timeout in seconds. so change it to your liking
Let me know if you have any other issues
ReefAngel.StandardATO( Port1,65 );Sincerely, Brennyn
CASPAR
Re: CODE CHECK
For the ATO, is that the code i would use if i have both a low level float and a high level float?
- brennyn21
CASPAR
Re: CODE CHECK
BRENNYN21,
LOOKING AT MY CODE ABOVE, WHAT ARE MY OPTIONS AS FAR AS CHANGING THE LIGHTING EFFECT FOR THE STORM? I.E. FLASHES, DIMMING ETC ETC WOULD LIKE TO KNOW IF I COULD GET IT TO KIND OF RAMP DOWN THEN GO INTO STORM MODE IF POSSIBLE THEN RAMP BACK TO NORMAL AS IF STORM HAS PASSED.
