How to use the trigger options in the Portal
Related to the Portal
jsclownfish
Post by jsclownfish »
I'm really looking forward to adding a few more email alerts to my code. Some things look obvious, like temperature or pH, but how do you code alerts for the other options? Maybe a key as to what the codes in the drop down menu represent would help?
Thanks and great work!
-Jon
Re: How to use the trigger options in the Portal
T1 - Temperature Probe 1
T2 - Temperature Probe 2
T3 - Temperature Probe 3
PH - pH
SAL - Salinity
ORP - ORP
ATOHIGH - Status of ATO High port
ATOLOW - Status of ATO Low port
PWMA - PWM % of Actinic Channel
PWMD - PWM % of Daylight Channel
R - Decimal number representing the Main Relay Box status
RON - Relay Mask On for Main Relay Box
ROFF - Relay Mask Off for Main Relay Box
R1 - Decimal number representing the Expansion Relay Box 1 status
RON1 - Relay Mask On for Expansion Relay Box 1
ROFF1 - Relay Mask On for Expansion Relay Box 1
R2 - Decimal number representing the Expansion Relay Box 2 status
RON2 - Relay Mask On for Expansion Relay Box 2
ROFF2 - Relay Mask On for Expansion Relay Box 2
R3 - Decimal number representing the Expansion Relay Box 3 status
RON3 - Relay Mask On for Expansion Relay Box 3
ROFF3 - Relay Mask On for Expansion Relay Box 3
R4 - Decimal number representing the Expansion Relay Box 4 status
RON4 - Relay Mask On for Expansion Relay Box 4
ROFF4 - Relay Mask On for Expansion Relay Box 4
R5 - Decimal number representing the Expansion Relay Box 5 status
RON5 - Relay Mask On for Expansion Relay Box 5
ROFF5 - Relay Mask On for Expansion Relay Box 5
R6 - Decimal number representing the Expansion Relay Box 6 status
RON6 - Relay Mask On for Expansion Relay Box 6
ROFF6 - Relay Mask On for Expansion Relay Box 6
R7 - Decimal number representing the Expansion Relay Box 7 status
RON7 - Relay Mask On for Expansion Relay Box 7
ROFF7 - Relay Mask On for Expansion Relay Box 7
R8 - Decimal number representing the Expansion Relay Box 8 status
RON8 - Relay Mask On for Expansion Relay Box 8
ROFF8 - Relay Mask On for Expansion Relay Box 8
PWME0 - PWM % of PWM Expansion Channel 0
PWME1 - PWM % of PWM Expansion Channel 1
PWME2 - PWM % of PWM Expansion Channel 2
PWME3 - PWM % of PWM Expansion Channel 3
PWME4 - PWM % of PWM Expansion Channel 4
PWME5 - PWM % of PWM Expansion Channel 5
AIW - Intensity % of Aqua Illumination White Channel
AIB - Intensity % of Aqua Illumination Blue Channel
AIRB - Intensity % of Aqua Illumination Royal Blue Channel
RFM - Vortech Mode
RFS - Vortech Speed
RFD - Vortech Duration
RFW - Intensity % of Radion white Channel
RFRB - Intensity % of Radion Royal BlueChannel
RFR - Intensity % of Radion Red Channel
RFG - Intensity % of Radion Green Channel
RFB - Intensity % of Radion Blue Channel
RFI - Intensity % of Radion Master Channel
IO - Decimal number representing the I/O Expansion status
C0 - Custom Field 0
C1 - Custom Field 1
C2 - Custom Field 2
C3 - Custom Field 3
C4 - Custom Field 4
C5 - Custom Field 5
C6 - Custom Field 6
C7 - Custom Field 7
PHE - pH Expansion
WL - Water Level
Custom fields have not been tested yet, nor have a place defined on the dashboard yet.
This is where you would be able to place customs numbers such as your flow and light meters :)
jsclownfish
Nice! :D
So to try this, should I just define a variable (ie. flow) as C1 and then ask for an email alert if C1=0 to tell me that the pump has stopped?
int C1:
flow=C1;
Jon
Actually, I need to patch the Portal and get Curt to upate RAGen too in order to get the custom variables to work.
jsclownfish
Ok thanks! How does it know if the value is from say PWME0? Could I just fake it for now and give another variable the same name? Or should I just be patient? ;) :)
They are all working, with exception of the custom fields.
PWME0 is sent automatically when you enable PWM expansion.
In fact, everything is sent automatically when the feature is enabled :)
Ok, so I fixed the portal and you can now use the custom fields.
You need this on the features file:
#define CUSTOM_VARIABLES
Because RAGen still doesn't have the option, you will need to manually add it until we get next update from Curt.
Then, on your code, you can use this:
ReefAngel.CustomVar[0]=100;
You can replace the 0 with any number from 0 to 7.
Check off another item added to RAGen. A screenshot to preview...
lukeluke
Post by lukeluke »
there is a way to check if the Relay is set manually to on or off ? and not in auto ?
last summer i have a problem, someone in internet set my Fan relay to OFF :-(
lukeluke
Post by lukeluke »
T probe, the value is 251 or 25.1 or 25,1 °C ? :-D
lukeluke
Post by lukeluke »
The Portal say:
"Send email notifications:
For multiple email addresses, separate them with a comma. Only one email notification will be sent during one hour period. "
One email for every trigger ?
lukeluke wrote:there is a way to check if the Relay is set manually to on or off ? and not in auto ?
It will show ON or OFF if it is manually set to one of those. If it is auto it will show AUTO.
lukeluke
Post by lukeluke »
For make it , i use :
RON > 0 for check force ON state
ROFF < 255 for check force OFF state
lukeluke
Post by lukeluke »
how can i check the ATO or overheat alarms ?
lukeluke wrote:how can i check the ATO or overheat alarms ?
You would have to monitor them separately. They would need to be handled in the custom variables.
lukeluke
Post by lukeluke »
ok...
i made it so:
void loop(){
if ( InternalMemory.read(ATO_Single_Exceed_Flag) == 1 )
ReefAngel.CustomVar[0]=1;
ReefAngel.CustomVar[0]=0;
if ( InternalMemory.read(Overheat_Exceed_Flag) == 1 )
ReefAngel.CustomVar[1]=1;
ReefAngel.CustomVar[1]=0;
Right ?
Hey Luca, I remember once a long time ago when you said you couldn't code....
Man, you the master of RA :)
lukeluke
Post by lukeluke »
I look at your script and replied :-P
Make sure you are putting the custom variable updating BEFORE the Portal() function. Otherwise the values will not be sent until the next time through.
  // modify custom variables
  ReefAngel.Portal("userid");
lukeluke
Post by lukeluke »
i don't use ReefAngel.Portal() is the server to get the value. i don't have space for send parameters... ;-)
lukeluke
Post by lukeluke »
work
<RA>
<T1>268</T1>
<T2>0</T2>
<T3>0</T3>
<PH>642</PH>
<R>11</R>
<RON>0</RON>
<ROFF>255</ROFF>
<ATOLOW>0</ATOLOW>
<ATOHIGH>1</ATOHIGH>
<EM>0</EM>
<REM>0</REM>
<PWMA>0</PWMA>
<PWMD>0</PWMD>
<C0>0</C0>
<C1>0</C1>
<C2>0</C2>
<C3>0</C3>
<C4>0</C4>
<C5>0</C5>
<C6>0</C6>
<C7>0</C7>
</RA>
lukeluke
Post by lukeluke »
i put this trigger:
T1 <= 24 Temp too less
T1 >= 27.5 Temp too high
RON > 0 Relay force on
ROFF < 255 Relay force off
C0 = 1 ATO Alarm
C1 = 1 Overheat Alarm
lukeluke
Post by lukeluke »
i try the ATO Alarm , C0=1... but i see that the alarm don't arrive.
so i try to connect to wifi of the controller... but not work. /wifi or /r99 nothing ......
i restart my controller, but nothing the web server don't respond....
i try to clear the ato alarm and..... magically the web server work!
there is some bug to customs ?
The alarm is only sent when the data is sent to the portal. If you are only sending the data every 3 minutes, then it can take up to 3 minutes for the alarm to be sent once it is triggered. Also, make sure you are setting the alarm / custom variable BEFORE the call to Portal() (or webbanner()). Otherwise, the value will not be sent until the next time it is sent (which could be another 3 minutes later).
lukeluke
Post by lukeluke »
the problem is not the alarm...but the internal web server of the RA.
When the ato alarm is on and the c0=1 the internal web server of the RA don't work.
when i write on my browser ip:2000/wifi o /r99 it not answer
I'll have to check on that.
This is the code I use to test:
  ReefAngel.Init();
  ReefAngel.SingleATO(true,Port1,4,1);
With this features:
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#define ENABLE_EXCEED_FLAGS
#endif  // __REEFANGEL_FEATURES_H__
When I pull the data without timeout, I get this:
HTTP/1.1 200 OK
Server: ReefAngel
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
Connection: close
Content-Type: text/xml
Content-Length: 257
<RA><T1>0</T1><T2>0</T2><T3>0</T3><PH>505</PH><R>0</R><RON>0</RON><ROFF>255</ROFF><ATOLOW>0</ATOLOW><ATOHIGH>0</ATOHIGH><EM>0</EM><REM>0</REM><PWMA>20</PWMA><PWMD>20</PWMD><C0>0</C0><C1>0</C1><C2>0</C2><C3>0</C3><C4>0</C4><C5>0</C5><C6>0</C6><C7>0</C7></RA>
When I pull data with the timeout, I get this:
HTTP/1.1 200 OK
Server: ReefAngel
Pragma: no-cache
Connection: close
Content-Length: 257
<RA><T1>0</T1><T2>0</T2><T3>0</T3><PH>504</PH><R>0</R><RON>0</RON><ROFF>255</ROFF><ATOLOW>0</ATOLOW><ATOHIGH>0</ATOHIGH><EM>0</EM><REM>0</REM><PWMA>20</PWMA><PWMD>20</PWMD><C0>1</C0><C1>0</C1><C2>0</C2><C3>0</C3><C4>0</C4><C5>0</C5><C6>0</C6><C7>0</C7></RA>
I could not get the same behavior you experienced.
Can you post your code and features?
lukeluke
Post by lukeluke »
this is my pde
// Autogenerated file by RAGen (v1.2.1.158), (02/21/2012 19:09)
// RA_022112_1909.ino
#define wifi
#define WDT
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define ENABLE_ATO_LOGGING
int DP3_Timer = InternalMemory.DP1Timer_read() * 4;
ReefAngel.LCD.DrawDate(6, 112);
ReefAngel.LCD.DrawMonitor(15, 10, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 10, ReefAngel.Params);
byte x = 8;
byte y = 45;
char text[7];
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x, y, "DP1:");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+25, y, InternalMemory.DP1Timer_read());
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+37, y, "DP2:");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+62, y, InternalMemory.DP2Timer_read());
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+75, y, "DP3:");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+101, y, DP3_Timer);
x = 6;
y += MENU_START_ROW+6;
y -= 3;
ReefAngel.LCD.Clear(COLOR_BLACK, x, y, 124, y);
y +=1;
ReefAngel.LCD.Clear(COLOR_BLUE, x+1, y, 123, y+10);
y +=11;
ReefAngel.LCD.Clear(COLOR_BLACK, x, y-11, x, y+16);
ReefAngel.LCD.Clear(COLOR_BLACK, 124, y-11, 124, y+16);
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_BLUE, x+40, y-9, "Alarms");
y += 6;
x += 2;
byte fcolor;
// This is for the LOW Ato switch
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+2, y,"ATO:");
// add in InternalMemory.write(700, 1) when ato is tripped
// add in InternalMemory.write(700, 0) when ato is cleared
fcolor = COLOR_RED;
ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+30, y, "YES");
fcolor = COLOR_GREEN;
ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+30, y, "NO ");
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, x+55, y,"OverH:");
// add in InternalMemory.write(701, 1) when overheat is tripped
// add in InternalMemory.write(701, 0) when overheat is cleared
fcolor = COLOR_RED;
strcpy(text, "YES");
strcpy(text, "NO ");
ReefAngel.LCD.DrawText(fcolor, DefaultBGColor, x+94, y, text);
ReefAngel.LCD.Clear(COLOR_BLACK, x-2, y+11, 124, y+11);
ReefAngel.LCD.DrawOutletBox(12, 95, TempRelay);
// ReefAngel.LCD.DrawGraph(5, 5);
ReefAngel.SetTemperatureUnit(1); // set to Celsius Temperature
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
// Specific functions
ReefAngel.StandardFan(Port1);
ReefAngel.MHLights(Port2);
// ReefAngel.DosingPump1(Port3);
//ReefAngel.DosingPumpRepeat(Port3, 0, 360, InternalMemory.DP1Timer_read());
ReefAngel.Relay.DelayedOn(Port4, 5);
// ReefAngel.DosingPump2(Port5);
//ReefAngel.DosingPumpRepeat(Port5, 10, 360, InternalMemory.DP2Timer_read());
ReefAngel.SingleATOHigh(Port6);
ReefAngel.StandardHeater(Port8);
ReefAngel.DosingPump(Port3, 1, 23, 20, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 05, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 11, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 17, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port5, 2, 23, 30, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 05, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 11, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 17, 10, InternalMemory.DP2Timer_read());
// ReefAngel.DosingPump(Port7, 23, 20, DP3_Timer); // Setup Dosing Pump 3 Oligo
with the new version the dosingpump repeat don't work.... or i' m not able.... :-D
if you want, this evening i retry it ;-)
Did you download 0.9.2 for the dosing pump fix?
I'll look over your code to see what I get.
