still cant generate internal memory
psyrob
Post by psyrob »
I have downloaded the new code, followed all the links for the most recent version of RAGen and the Installer, and still, after I generate with RAGen and upload, I keep getting the screen on my controller : "No Internal Memory Found" I first uninstalled the old RAGen and the old controller files then loaded all the most recent. When it still gave me the No Internal Memory found, I uninstalled again and re-installed and still the same message...
Here is the ino file:
Now what??
// Autogenerated file by RAGen (v1.2.1.158), (02/18/2012 23:19)
// RA_021812_2319.ino
// This version designed for v0.9.0 or later
/* The following features are enabled for this File:
#define DisplayImages
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <ReefAngel.h>
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
    // Specific functions
    ReefAngel.StandardATO(Port1);
    ReefAngel.MHLights(Port3);
    ReefAngel.MHLights(Port4);
    ReefAngel.Wavemaker1(Port5);
    ReefAngel.Wavemaker2(Port6);
    ReefAngel.StandardFan(Port8);
    ReefAngel.Portal("psyrob");
psyrob
Re: still cant generate internal memory
Post by psyrob »
OK, I found the post that told how to use the sample internal memory code, I uploaded that...however, I define port 8 to be standard fan, and it is now always on...see the code above, Port 8 is listed as Standard Fan, but it is functioning as always on...strange...
If you used sample memory file, the heater temp setting would be different than before.
Just generate a new internal memory file with RAGen.
psyrob
Post by psyrob »
I'm posting first and thinking second, LOL...I started the CLient, and saw that the memory was all different, the fan was coming on at a much lower temperature than I want it set for...I fixed values using the client and it is working as it should...
