I try to use:
mode 1
ReefAngel.DosingPump1(Port3);
ReefAngel.DosingPump2(Port5);
mode 2
ReefAngel.DosingPumpRepeat(Port3, 0, 360, InternalMemory.DP1Timer_read());
ReefAngel.DosingPumpRepeat(Port5, 10, 360, InternalMemory.DP2Timer_read());
mode 3
ReefAngel.DosingPump(Port3, 1, 23, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 05, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 11, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 1, 17, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port5, 2, 23, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 05, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 11, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 2, 17, 10, InternalMemory.DP2Timer_read());
mode 4
ReefAngel.DosingPump(Port3, 23, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 05, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 11, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port3, 17, 00, InternalMemory.DP1Timer_read());
ReefAngel.DosingPump(Port5, 23, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 05, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 11, 10, InternalMemory.DP2Timer_read());
ReefAngel.DosingPump(Port5, 17, 10, InternalMemory.DP2Timer_read());
but nothing.... the pump never start...
what can i do ?
Dosometric don't work with 0.9.0
Re: Dosometric don't work with 0.9.0
There is a bug ![Sad :(](./images/smilies/icon_e_sad.gif)
I tried fixing it and it made it even worse.
I'll try to check on it this weekend.
the next time it think that is better create a post with bug list for the new version... for 2 days my balling is stopped ![Wink ;-)](./images/smilies/icon_e_wink.gif)
Please download the latest libraries using the update utility.
http://www.reefangel.com/update
can i update in other mode ? what do this app ?
i don't want install .net![Very Happy :-D](./images/smilies/icon_e_biggrin.gif)
thanks
thanks
Yeah, download from website:
http://reefangel.com/Download.ashx
Once you do the library update do you need to regenerate the memory file?
Yes, it is mandatory.
You will get a "No Internal Memory" message in the screen if you don't.
