Feed mode.
Seedlessone
Feed mode.
I am going to set up my feed mode tomorrow and hada few questions. I would like a 15mins feed mode with all circulation off including my sump but I only want my power heads to be off of for 10mins. Is this possible?
Re: Feed mode.
Not with the standard feed mode.
Could be done with custom menu and a custom feeding mode function.
Seedlessone
Re: Feed mode.
Looking for control only with iPhone. So I assume that is out. The standard feed mode is 15 mins correct?
- Contact:
Re: Feed mode.
You could use the iPhone to activate the feeding mode but it would only be for the entire duration and it wouldn't be the staggered times like you are wanting unfortunately.Seedlessone wrote:Looking for control only with iPhone. So I assume that is out. The standard feed mode is 15 mins correct?
Seedlessone
Re: Feed mode.
What if I added something like this?
ReefAngel.Relay.DelayedOn (Port1, 5);
