ok, set up and everything is running ok, but
miked
Post by miked »
my led fan should be set to auto and be turned on when the LED light power port turns on also. I thought I had them both set to 'standard lights' and set the standard light on/off at a specified time but the fan port is not on during auto. is there a way to check and modify these settings after the code has been set up and is running? also need to check my heater settings.
thanks
Re: ok, set up and everything is running ok, but
You can see the memory settings with smart phone app or Client software.
miked
Post by miked »
rimai wrote:You can see the memory settings with smart phone app or Client software.
I guess what I am asking is to see the Code that is currently on my RA. Is that possible? I want to check my PWM and ATO specifically to make sure they are correct as I am not seeing the Code work as I thought I entered it. Probably just did not enter it how i intended but would like to verify.
thanks
No you are unable to see the code that is currently installed on the controller. That's just not possible.
miked
Post by miked »
binder wrote:No you are unable to see the code that is currently installed on the controller. That's just not possible.
thanks, I think I just uploaded the internal memory differently than planned but the PWM slope worked nicely for me yesterday and everything else is fine now that I updated temperature requirements and light on/of settings from the client.
thanks for all your help guys this has been the best investment in my first reef setup.
rossbryant1956
Post by rossbryant1956 »
and the most fun...and the most frustrating...and...and
Thx to all for their help.
