my led fan should be set to auto and be turned on when the LED light power port turns on also. I thought I had them both set to 'standard lights' and set the standard light on/off at a specified time but the fan port is not on during auto. is there a way to check and modify these settings after the code has been set up and is running? also need to check my heater settings.
thanks
ok, set up and everything is running ok, but
Re: ok, set up and everything is running ok, but
You can see the memory settings with smart phone app or Client software.
I guess what I am asking is to see the Code that is currently on my RA. Is that possible? I want to check my PWM and ATO specifically to make sure they are correct as I am not seeing the Code work as I thought I entered it. Probably just did not enter it how i intended but would like to verify.rimai wrote:You can see the memory settings with smart phone app or Client software.
thanks
No you are unable to see the code that is currently installed on the controller. That's just not possible.
thanks, I think I just uploaded the internal memory differently than planned but the PWM slope worked nicely for me yesterday and everything else is fine now that I updated temperature requirements and light on/of settings from the client.binder wrote:No you are unable to see the code that is currently installed on the controller. That's just not possible.
thanks for all your help guys this has been the best investment in my first reef setup.
and the most fun...and the most frustrating...and...and
Thx to all for their help.
