PWM code crazy..!?
rafamar
PWM code crazy..!?
Post by rafamar »
Hi,
ive upload this in my memory
// Autogenerated file by RAGen (v1.2.1.158), (03/11/2012 21:13)
// Memory_031112_2113.ino
#include <avr/pgmspace.h>
RA_NokiaLCD e;
    e.Init();
    e.BacklightOn();
    InternalMemory.MHOnHour_write(14);
    InternalMemory.MHOffHour_write(0);
    InternalMemory.MHDelay_write(3);
    InternalMemory.StdLightsOnHour_write(2);
    InternalMemory.StdLightsOffHour_write(0);
    InternalMemory.StdLightsOffMinute_write(0);
    InternalMemory.ATOTimeout_write(60);
    InternalMemory.ATOHighTimeout_write(60);
    InternalMemory.LEDPWMActinic_write(100);
    InternalMemory.LEDPWMDaylight_write(100);
    InternalMemory.WM1Timer_write(200);
    InternalMemory.WM2Timer_write(354);
    InternalMemory.HeaterTempOn_write(780);
    InternalMemory.HeaterTempOff_write(791);
    InternalMemory.ChillerTempOn_write(810);
    InternalMemory.ChillerTempOff_write(785);
    InternalMemory.RFMode_write(Constant);
    InternalMemory.RFSpeed_write(140);
    InternalMemory.RFDuration_write(8);
    InternalMemory.PWMSlopeEndD_write(128);
    InternalMemory.PWMSlopeEndA_write(128);
    InternalMemory.IMCheck_write(0x5241494D);
    // display success screen
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*2, "Internal Memory Set");
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*4, "Now load your");
    e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, "   RA code file");
    delay(5000);
and this sketch
// Autogenerated file by RAGen (v1.2.1.158), (03/11/2012 21:21)
// RA_031112_2121.ino
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.Relay.On(Port1);
    ReefAngel.Relay.On(Port2);
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    // Specific functions
    ReefAngel.Relay.DelayedOn(Port3, 2);
    ReefAngel.StandardLights(Port5);
    ReefAngel.StandardLights(Port6);
    ReefAngel.PWM.SetActinic(PWMSlope(14,00,0,30,15,100, 60, ReefAngel.PWM.GetActinicValue() ));
    ReefAngel.PWM.SetDaylight(PWMSlope(14,30,0,00,15,90, 60, ReefAngel.PWM.GetDaylightValue() ));
    // accensione pompa dx  grande dalle 15:00 alle 0:00
    if (((NumMins(hour(),minute()) >= NumMins(15,00)) && (NumMins(hour(),minute()) <= NumMins(23,59))) )ReefAngel.Relay.On(Port7); else ReefAngel.Relay.Off(Port7);
    // accensione pompa dx piccola dalle 0:00 alle 14:43 e dalle 15:00 alle 21:15
    if (((NumMins(hour(),minute()) >= NumMins(0,00)) && (NumMins(hour(),minute()) <= NumMins(14,43))) || (NumMins(hour(),minute()) >= NumMins(15,00)) && (NumMins(hour(),minute()) <= NumMins(21,15))) ReefAngel.Relay.On(Port8); else ReefAngel.Relay.Off(Port8);
Led will be on 14.00 and off at 0.30 with 60 minutes of slope at 15%.
This morning at 8.00 ive found my light on at 57% instead they would have been off!!
what is the error?
thx and bye
Re: PWM code crazy..!?
I don't think the PWMSlope function can cross-over to next day.
Can you try to change it to within the same day and let me know if that works?
rafamar
Post by rafamar »
rimai wrote:I don't think the PWMSlope function can cross-over to next day.
how and where i ve to change?
thx
Right now you have it from 2:00pm to 12:30am and 2:30PM and 12:00am.
Change it so it doesn't go over to next day.
Try to end the slop at 11:59pm and let me know if that works.
If I remember correctly, the slope calculation doesn't allow for crossing to next day.
