ive get and customized this code
// Autogenerated file by RAGen (v1.2.1.158), (03/12/2012 21:21)
// RA_031112_2121.ino
#define SIMPLE_MENU
#define DisplayLEDPWM
#define wifi
#define VersionMenu
#define CUSTOM_MAIN
#define NUMBERS_8x16
#define COLORS_PDE
#define Heater 1
#define ATO 2
#define Skimmer 3
#define Pompa Sx 4
#define Bianchi 5
#define Blue 6
#define Pompa Grande DX 7
#define Pompa Piccola DX 8
//Cloud & Lightning effects
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
boolean ForceCloud=false;
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 0, " "); //Top Banner
ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 2, " Raffa's Reef "); //Top Banner
ReefAngel.LCD.DrawDate(6, 123);
// Display Temp Text
ReefAngel.LCD.DrawText(0,255,12,12,"Temp");
// Display the T1 temp value 10,22
//char text[7];
//ConvertNumToString(text, ReefAngel.Params.Temp [1], 10);
//ReefAngel.LCD.Clear(255, 0, 22, 50, 36);
//ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 10, 22, text, Num8x16);
//pingSerial();
// Display pH Text
ReefAngel.LCD.DrawText(0,255,100,12,"pH");
// Display pH Value
//ConvertNumToString(text, ReefAngel.Params.PH, 100);
//ReefAngel.LCD.Clear(255, 90, 22, 98, 36);
//ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 90, 22, text, Num8x16);
//pingSerial();
// Display Actinic Percentage Text
ReefAngel.LCD.DrawText(0,255,8,40,"Actinic %");
// Display the Actinic PWM channel value at 90,40
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_CORNFLOWERBLUE, 90, 40, 1);
// Display Daylight Percentage Text
ReefAngel.LCD.DrawText(0,255,8,50,"Daylight %");
// Display the Daylight PWM channel value at 90,50
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),COLOR_CORNFLOWERBLUE, 90, 50, 1);
// Display T2 Temp Text
ReefAngel.LCD.DrawText(0,255,8,60,"Ambient Temp");
// Display the T2 temperature value at 90,60
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp [2], COLOR_CORNFLOWERBLUE, 90, 60, 10);
// Display T3 Temp Text
ReefAngel.LCD.DrawText(0,255,8,70,"Sump Temp");
// Display the T3 temperature at 90,70
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp [3], COLOR_CORNFLOWERBLUE, 90, 70, 10);
// Display Vortech MP10ew Mode Text at 90, 80
//ReefAngel.LCD.DrawText(0,255,8,80,"EcoSmart Mode");
// Display EcoSmart Mode Value
//ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,90,80,"Storm");
//#if defined DisplayLEDPWM && ! defined RemoveAllLights
//ReefAngel.LCD.DrawMonitor(11, 60, ReefAngel.Params,
//ReefAngel.PWM.GetDaylightValue(), ReefAngel.PWM.GetActinicValue());
//#else // defined DisplayLEDPWM && ! defined RemoveAllLights
//ReefAngel.LCD.DrawMonitor(11, 60, ReefAngel.Params);
//#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
ReefAngel.LCD.DrawOutletBox(13, 97, TempRelay);
// ReefAngel.LCD.DrawGraph(5,7);
ReefAngel.FeedingModePorts = B00100001; //Ports 6 & 1 turn off
ReefAngel.WaterChangePorts = B00000111; //Ports 2 & 1 & 3 turn off
ReefAngel.OverheatShutoffPorts = B00011000; //Ports 4 & 5 turn off
ReefAngel.LightsOnPorts = B00110000; //Ports 6 & 5 turn on
ReefAngel.Relay.On(Port4);
// Delay Skimmer port 5 minutes whenever turned on
// From Curt - THANKS CURT!
ReefAngel.Relay.DelayedOn(Port3, 2);
//Heater
ReefAngel.StandardHeater(Heater,750,770); // Setup Heater to turn on at 77.5F and off at 78.0F
//Lighting schedule
ReefAngel.StandardLights(Bianchi,14,0,23,30); //Daylight schedule 14:00am - 23:30pm with 0min cool down
ReefAngel.StandardLights(Blue,13,30,23,59); //Actinic schedule 13:30am - 23:59pm
//ReefAngel.StandardLights(Refugium,19,0,7,0); //Refugium schedule 7:00pm - 7:00am
// Dosing pumps (OLD DOSING METHOD OF PUMP ONE ON THE HOUR, THEN PUMP2 5 MIN LATER - to use when tank is more mature
//From Roberto - THANKS ROBERTO!
/* if (ReefAngel.DisplayedMenu==255 && minute()==0 && second()<1) //Alk Doser - Only works if Main screen is showing
ReefAngel.Relay.On(DosingPump1); //Turn Alk Doser on
ReefAngel.Relay.Off(DosingPump1); //Turn Alk Doser off
if (ReefAngel.DisplayedMenu==255 && minute()==5 && second()<1) //CA Doser - Only works if Main screen is showing
ReefAngel.Relay.On(DosingPump2); //Turn CA Doser on
ReefAngel.Relay.Off(DosingPump2); //Turn CA Doser off
// Dosing pumps
// From Roberto - THANKS ROBERTO!
//if (ReefAngel.DisplayedMenu==255 && hour()%2==0 && minute()==0 && second()<1) // 1 sec dosing on even hours
//ReefAngel.Relay.On(DosingPump1); //Turn DosingPump1 Doser on
//else
// ReefAngel.Relay.Off(DosingPump1); //Turn DosingPump1 Doser off
//if (ReefAngel.DisplayedMenu==255 && hour()%2==1 && minute()==0 && second()<1) // 1 sec dosing on odd hours
// ReefAngel.Relay.On(DosingPump2); //Turn DosingPump2 Doser on
//else
//ReefAngel.Relay.Off(DosingPump2); //Turn DosingPump2 Doser off
// Cloud & Lightning effects - Calculate your regular sunrise/sunset PWM value
// byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
if (hour()>=01 || hour()<07)
ReefAngel.PWM.SetActinic(MoonPhase()); //Moon phase schedule between 7:00pm - 7:00am
ActinicPWMValue=PWMSlope(13,30,22,30,0,100,60,ActinicPWMValue); //Actinic turn on at 13.30am, off at 10am, and ramp up 0% to 50% PWM in 60 minutes
//ActinicPWMValue=PWMSlope(16,00,19,0,0,50,60,ActinicPWMValue); //Actinic turn on at 4pm, off at 7pm, and ramp up 0% to 50% PWM in 60 minutes
DaylightPWMValue=PWMSlope(14,00,22,59,0,90,60,DaylightPWMValue); //Daylight turn on at 14am, off at 5pm, and ramp up 0% to 50% PWM in 60 minutes
CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 6
#define Start_Cloud_After NumMins(16,30)
// In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(20,30)
#define Lightning_Change_per_Cloud 25
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen result could happen.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
//When cusotm menu Force cloud is selected
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
cloudstart=NumMins(hour(),minute())+1;
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.Clear(255,0,113,132,121);
ReefAngel.LCD.DrawText(0,255,12,113,"C");
ReefAngel.LCD.DrawText(0,255,18,113,"00:00");
ReefAngel.LCD.DrawText(0,255,52,113,"L");
ReefAngel.LCD.DrawText(0,255,58,113,"00:00");
ReefAngel.LCD.DrawText(0,255,93,113,"DUR");
int x=0;
if ((cloudstart/60)>=10) x=18;
else x=24;
ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart/60));
if ((cloudstart%60)>=10) x=36;
else x=42;
ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart%60));
ReefAngel.LCD.DrawText(0,255,114,113,cloudduration);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=88;
else x=94;
ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=109;
else x=112;
ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//End Cloud & Lighting
but when i try to compile it i recived this message
Binary sketch size: 31698 bytes (of a 30720 byte maximum)
processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
at processing.app.Sketch.size(Sketch.java:1651)
at processing.app.Sketch.build(Sketch.java:1570)
at processing.app.Sketch.build(Sketch.java:1546)
at processing.app.Editor$DefaultRunHandler.run(Editor.java:1845)
at java.lang.Thread.run(Thread.java:619)
could you help me?
thx
