AI sol blue
wijigong
AI sol blue
just for confirm thunderstrom working with RA
and for person i have AI and RA, please show me your configuration???
thank you
thank you
wolfador
Re: AI sol blue
Yes, I currently use an Ai Nano and my new tank is going to be live soon will be using two Ai Nano's controlled separately.
Just do the standard cloud function and use something like:
WhiteValue=PWMSlope(9,0,21,0,3,30,200,3);
BlueValue=PWMSlope(9,0,21,0,8,35,240,8);
RoyalBlueValue=PWMSlope(9,0,21,0,8,35,240,8);
CheckCloud();
ReefAngel.AI.SetChannel(White,WhiteValue);
ReefAngel.AI.SetChannel(Blue,BlueValue);
ReefAngel.AI.SetChannel(RoyalBlue,RoyalBlueValue);-
wijigong
Re: AI sol blue
and for call the thunderstorm and cloud fonction
is include on one .h or .cpp file
or i need to had on my pde file
thank you
thank you
wolfador
Re: AI sol blue
You need to have #include <ReefAngel_AI.h> in your .ino and have the #define AI_LED in your features file.
wijigong
Re: AI sol blue
ok butt if i need to change % of thunderstorm or cloud
where is the fonction, in what .cpp or .h file
thank a lot
thank a lot
wijigong
Re: AI sol blue
i try but receive this error
finalpasdeAI.cpp: In function 'void loop()':
finalpasdeAI:85: error: 'WhiteValue' was not declared in this scope
finalpasdeAI:86: error: 'BlueValue' was not declared in this scope
finalpasdeAI:87: error: 'RoyalBlueValue' was not declared in this scope
i define the #define AI_LED in the reefangel_features
//custom dysplay temp+on and off relay
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawDate(6, 2);
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "TEMP pH");
char text[7];
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16);
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y,text);
ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(10,InternalMemory.WM1Timer_read()));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port6);
ReefAngel.FeedingModePorts = B00110000;
ReefAngel.OverheatShutoffPorts = B00001110;
ReefAngel.WaterChangePorts = B11110001;
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Port7);
ReefAngel.StandardHeater(Port4);
ReefAngel.SingleATOHigh(Port1);
//wave maker fonction with night mode
if ( (hour() >= 22) || (hour() <= 8) ) // from 10p - 8a
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.On(Port5);
// during the day
ReefAngel.Timer[1].SetInterval(random(25,50));
wijigong
Re: AI sol blue
finaly i go with
i finish with no error
juste confirm everyting is ok
and what value is 9,0,22,0,0,30,240,0
9 am to 10pm and ?????
byte x = 6;
byte y = 2;
byte t;
x = 12;
char text[7];
x = 10;
ReefAngel.AI.SetPort(lowATOPin);
ReefAngel.AI.SetChannel(White,PWMSlope(9,0,22,0,0,30,240,0));
ReefAngel.AI.SetChannel(Blue,PWMSlope(9,0,22,0,0,35,240,2));
ReefAngel.AI.SetChannel(RoyalBlue,PWMSlope(9,0,22,0,0,35,240,2));
// during the day
wijigong
Re: AI sol blue
i try this but i have this error
finalpasdeAI.cpp: In function 'void CheckCloud()':
finalpasdeAI:168: error: 'ReversePWMSlope' was not declared in this scope
finalpasdeAI:205: error: a function-definition is not allowed here before '{' token
finalpasdeAI:226: error: a function-definition is not allowed here before '{' token
finalpasdeAI:260: error: expected `}' at end of input
//#include <Salinity.h>
//#include <RF.h>
byte WhiteValue=0;
byte BlueValue=0;
byte RoyalBlueValue=0;
byte x = 6;
byte y = 2;
byte t;
x = 12;
char text[7];
x = 10;
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
WhiteValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,WhiteValue,0,180);
else lightningstatus=0;
if (lightningstatus)
WhiteValue=50;
BlueValue=50;
RoyalBlueValue=50;
WhiteValue=0;
BlueValue=0;
RoyalBlueValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.Relay.On(Port2);
// during the day
if (hour()>=22 || hour()<9)
ReefAngel.AI.SetChannel(White,0);
ReefAngel.AI.SetChannel(Blue,MoonPhase()*0.06);
ReefAngel.AI.SetChannel(RoyalBlue,MoonPhase()*0.06);
ReefAngel.AI.SetChannel(White,PWMSlope(9,0,21,0,3,30,200,3));
ReefAngel.AI.SetChannel(Blue,PWMSlope(9,0,21,0,8,35,240,8));
ReefAngel.AI.SetChannel(RoyalBlue,PWMSlope(9,0,21,0,8,35,240,8));
