wi-fi attachment set up
jgriffith
Post by jgriffith »
I went through the set up and everything looked good (slow blinking green light). But I entered the IP address I saw when setting up (from "view wi-fi settings" on the wi-fi utility). But, when I go to the portal to enter my IP it does not connect ("unreachable"). Not sure if I should post my IP on this (I dont know if you are supposed to do that or not?).
wolfador
Re: wi-fi attachment set up
Post by wolfador »
you should be using your "external" ip address not your internal (usually 192. or 10.)
If you go to http://www.whatismyip.com/ it will tell you your external ip. Make sure you are entering that. If that does not work your firewall is probably blocking port 2000.
You should be able to find a guide at http://portforward.com/ for your router.
John
ReefAngel and ReefAngel-HD developer
If the RA iOS app has helped please consider a donation
jgriffith
Post by jgriffith »
it is a 10.
I guess I need to check out the firewall settings on my router (its an apple time capsule router).
wolfador
Post by wolfador »
jgriffith wrote:it is a 10.
Check out http://forum.reefangel.com/viewtopic.ph ... g&start=20
I posted some screenshots of how my Airport Extreme (same as Timecapsule minus internal harddrive) is configured.
John
jgriffith
Post by jgriffith »
great, thanks!
jgriffith
Post by jgriffith »
now im even more confused. I use the address in the above link for my IP instead of the one I saw in the wi-fi utility setup? It was a 10. in the wi-fi utility. Also my airport utilty looks different than the one in the link above. Do I do a DHCP reservation? or Enable NAT Port mapping protocol? I am really confused.
jgriffith
Post by jgriffith »
Finally figured it out, now how do i give my attachment a static ip address (i think thats what i want, so it doesnt change?)
Edit: Ok i reserved a dhcp lease, but there is not an unlimited setting, for now i picked 365 days
Edit: changed it to a bunch of 99999s so i should be good!
rossbryant1956
Post by rossbryant1956 »
if you look up in the post I asked the same question and binder said instead to reserve the address it grabbed instead of using a static ip. I never did find a way to assign a static ip to the wifi device. thx
jgriffith
Post by jgriffith »
rossbryant1956 wrote:if you look up in the post I asked the same question and binder said instead to reserve the address it grabbed instead of using a static ip. I never did find a way to assign a static ip to the wifi device. thx
The ip to my wi-fi changed all the time, so I reserved an address for it using its MAC address, I reserved it for like 9999999999 days give or take a 9 or two.
The lease time on the reserved address shouldn't really matter. Mine are all set for 1 day. What I did with mine is have mine serve up an ip address outside the normal DHCP range. My DHCP range is from 100-150. And here's what my static IP leases look like.
static lease
static lease
